Question about Kenmore 62602 Electric Dryer
Kenmore 110 66962500 have had problems with start switch and timer knob have to work knob back and forth for it to start, then this morning a small pop sound in the top and now nothing can i buy a timer and start and replace myself easily? any ideas
    President:
  • 1,554 Answers
It is apparent that the timer is gone even prior to the popping sound that started it to totally fail. The good news is yes you can replace it yourself because it is a pretty easy task. All you have to do is unplug the dryer then pull the time knob off with a string. Remove the console rear panel to access the timer and remove the screw attaching the timer to the console. Transfer the timer wires to the new timer one at a time and install the new timer in place. Secure the console back into position and put that timer know back into the timer shaft to complete the repair.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. But accepting the solution will not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 08, 2010
Kenmore washing machine modc1105230080 does not workonspincycle
Sounds like a lid switch. So the machine cycles properly all the way up till the spin cycle? If so, then its probably not your timer. One way to check quickly would be, when the washer stops at spin wiggle the knob back and forth. If it tries to come on during this wiggling it could be your timer.
Apr 20, 2013 | Kenmore Washing Machines
Removeing timer switch knob
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
See the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=d09053515715195798276a5664b79cf0
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If this is a basic top load, direct drive washer, these units may have one of two different timers. (See the Whirlpool PDF).
On models with a metal timer, you have to release the console, pull it forward and tilt it back in order to get to the back of the timer.
The knob screws onto a medal shaft that goes through the timer.
Usually, trying to un-screw the knob won't work by itself since the shaft will also turn.
I found that if you hold the back of the shaft with a thin needle-nosed pliers, you can unscrew the knob.
Then you simply have to disconnect the timer.
The Whirlpool PDF also has troubleshooting and testing procedures for the timer.
Jun 08, 2010 | Kenmore 24032\24036 Top Load Washer
The knob on my kenmore elite won't move the timer.
The knob itself turns the switch on . The skirt move the timer position. Try turning the skirt. You probably have a broken knob. On these the knob is held in place with a plastic rod inserted into it all the way. This spreads the tip and retains the knob. To get the knob off to yank out the skirt for a look see you need to pull that rod out a tad to release the knob. 88be11a.jpgThat shaft has a rounded end on it that spreads out and locks the knob on. Clever ain't it? These timers are cheaply made, if you cannot find fault with the knob or the skirt then you is gonna need a timer.
Jun 05, 2010 | Kenmore Washing Machines
The washer will not move to next cycle from aggitating and the water does not come out at the regular flow, sometimes it dripping and when the knob is turned to start over the water flows normal. We have a...
the timer motor itself is stuck or bad ! sometimes you can remove the top back panel to the rear of the timer area and there's a round small electrical motor that is fastened to the back of the timer with the unit unplugged take some WD 40 and spray inside the motor and use a toothpick to gently rotate it back and forth then plugg unit back it and check to see if it will cycle if not then replace the timer
Jan 12, 2010 | Washing Machines
Hi, I have a Kenmore Dryer Model 100.96591240. 15 years old (approx). Problem just started - I have to wiggle the Timer knob after pressing the Start button (sometimes I have to push the Start buttom and...
i took apart a dishwasher and in the timer switch there were some electrical contacts and over time they get a black burnt build up on them and need to be cleaned or replaced .might need a new switch
price one on ebay . or look at sears.com for a new part
Jan 10, 2010 | Kenmore 73952 Gas Dryer
I started my dryer one night i figured it would shut off but when i woke up the next morning it was still running and appeared to still be warm. The timer apparently was stuck on 70 minutes. the following...
Kenmore is a Sears brand and there isnt too much info on the net as for tech support. Youre best option is to call sears and see if they can give you any over the phone advice, but if the timer switch is getting stuck, it sounds like it may need replacing.
Nov 06, 2009 | Cars & Trucks
Tub fills with water......that's it.
This is probably a bad timer motor.
Two screws on right/left of head, flip head back. You will see a small motor on the timer that operates when the timer is set. If this isn't running, then you need to replace that or the entire timer. Probably easier to change just the motor.
Best luck in your repair
Joe
Aug 09, 2009 | Kenmore Washing Machines
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
My Kenmore 90's series washing machine will not move into the spin and rinse cycle unless we use a screwdriver to put pressure on the switch. Does this mean the switch is bad?
The timer you have has a bunch of small gears inside. The case is made of plastic. Yes the timer is most likely shot.To get the timer off you grab the black plastic rod in back out and this releases the knob. Then you can access the screws holding the timer on.ec1c7f4.jpg
Mar 14, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 62602 Electric Dryer Logo
83 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
