Question about Asko W6021 Front Load Washer
F6 CODE ASKO 20605 MODEL
  • Asko Master
  • 2,605 Answers
F6 on an asko washer means a fault was detected with the motor. What this means 99% of the time is the brushes in the motor are worn. As long as the armature isn't damaged, (visual inspection while turning motor shaft should identify damage) you'll be fine replacing the brushes.
part # 764414, 2 required, about $40US each (better than $400US plus for a motor).
hope that helps
good luck
Posted on Sep 29, 2009
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Model 20605; problem, F-3 fault in pumping out
Usually cleaning out the pump will correct the problem.
Posted on Oct 06, 2009
We have an ASKO W6451 flashing F6. appears to jump from 1 minute to go to 20 minutes to go then flashes F6. would it be something electical?
Asko F6 error is apparently a motor fault. The motor could be jammed, open circuit , burnt out?? It may just be a broken wire or connection come off. Check "Google" and type in Asko F6 error. There is a lot of info about it.
Dec 27, 2014 | Asko Washing Machines
Model 20605 Probably very old. First time using it in new home. How do I open the inside door? Is there a latch someplace? Is there a place I can get a manual?
Welcome to FixYa.
The Asko 20605 washer is an older model indeed, but not as old as you might think, the serial number would indicate it's actual manufactured date but it is in the neighborhood of late 90's early millennium.
Those particular electronic control models have a button on the front which unlocks the door if the power is "on".
For a more detailed explanation I've tried to copy & paste a clip from my service info.
The door can also become "stuck" closed if in-active for a period of time with the door in the closed position as it will stick to the rubber seal around the basket opening. You may need to pull slightly on the door as you push the lock switch to unlock it.
Let me know if this clears up the matter for you and I'll try and assist you in whatever manner I can going forward...if need be.
Thank you for choosing FixYa for your inquiry. Good luck.
Regards,
Macmarkus :)
Jan 26, 2011 | Asko W6641 Front Load Washer
Need to repair model 20605 washer, motor does not run, told the brushes were bad - replaced still wouldn't run, told that motor control circuit board could be bad - $600 to replace, how do you check a...
Welcome to FixYa.
Sorry to hear about your trouble shooting problems. I hope I can help move you forward in the right direction.
Have you run a self-diagnostic which is built into the Asko washer's control ? Furthermore, Did you initially receive an error code of "F6" ?
What led to the changing of the brushes in the motor, and was the motor windings ohm value checked to confirm or dismiss the motor was worth brushes ? The armature inspected ?
This how to run a fault tracing program ( in the event you don't know )
What you will/should see...
Let me know what you've done or found to this point and I'll try to help in whatever manner I can. It is possible the motor control board is the fault, but there is a means to get to that point first.
There was also a period of time during production some of the controls had the wrong fuse placed in them...se below for memo.
This is not very likely considering the age of your machine, however I felt it was worth mentioning. I'll watch for your next post.
Regards,
Macmarkus :)
Jan 09, 2011 | Asko W6221 Front Load Washer
Asko 20605 washer stopped mid-cycle, now no power?!
The ECU should be tested. Look for the service manual inside the chassis for troubleshooting procedures.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2010 | Asko Washing Machines
I stopped my Asko 20605 washer midcycle and it went dead. Can't turn it back on. Power turns on in the drier, but not the washer. If it's a fuse problem, where is the fuse? How do I get to it and what do I...
Do you still have washer? Where are you located? Give me a call i also have washer and i am looking for parts or might be able to give you parts.
410.926.7006
Dec 03, 2009 | Asko Washing Machines
Oct 06, 2009 | Asko Washing Machines
Re: Your answer to my problem (otr widow on 6/9)
Im finding more board issues with this model than expected.And I can't predict the future ,sorry,but, I do see a pattern and wanted you to know.
Jun 10, 2008 | Washing Machines
Motor Fault
check the carbon brushes on the motor or it can be a motor fault also change the belt at the same time
Apr 25, 2008 | Asko W6021 Front Load Washer
20605 Washer - portal door hinge is loose - so door vibrates and bangs loudly in the spin cycle... literally tearing itself apart. Where can I get the replacement hinge parts, including the clips, and how...
its a big job the door comes as a kit,you have to losen the front panel that the door sits on thers two bolts on the back of the front panel you get access from inside take off the back panel use 60 cm extension then remove door seal and ring the screws for the door are behind the hinge you will have to move the front panel forward and stick screw driver handel between so you can get access,but the kit does have instuctions.it will take about 1 hour or so.hopethis helps. model 20605 is an asko
Mar 26, 2008 | Washing Machines
Asko W6021 Front Load Washer Logo
436 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
