Question about Prince Castle 740T2 2Channel Single Function Electric Timer Bold LCD R
How do i programm 735 t6 timer prince castle timers
A search of prince channel site for 735 timer sent me to the 740 timer >> their other models wer 755 and 840
Here's the prince castle page:
http://www.princecastle.com/products/timers_740series_single-display.asp
Here's the 2 instruction guides:
740 horizontal
740 vertical
The timer is a multi-channel countdown timer which means it can control multiple electrical devices separate from each other
Set the french fry cooker to tun on for 5 minutes
Set the dryer to come on for 10 minutes
Set the blower to come on for 1 hour
Set each item for different lengths of time
The item with least amount of time left shows on the screen
To program timer
Press and hold Prince Castle logo for six seconds
Time displays will change from " ----" to "PROG"
Press timer channel to be programmed
LED indicator light will turn yellow and beep will sound
Current programmed time will display (for example it might show 5 minutes 20 seconds)
Time value will indicate either H:M (hours-minutes) or M:S (minutes-second)
Press SCAN/UP arrow or SCAN/DOWN arrow to change program time
These arrows are located next to Prince Castle logo
If you want H:M instead of M:S, then press and hold SCAN/UP button
When display reaches 59:59 it will automatically change to 1:00 Hour
LED indicator light switches from M:S to H:M
Now you programmed first channel, click next channel and repeat steps above
To FINISH programming, press Prince Castle logo for a moment, and programs are saved
Posted on Oct 09, 2010
Does the Defiant Daylight Adjusting Indoor Digital Timer also uses a battery?
No battery.
This single-pole or 3-way, programmable or dawn-dusk timer is same as GE 15312 sun smart timer, and requires a neutral wire to power the electronics.
GE renamed all their wall timers, or sold their timer business to Defiant in year 2013-4.
http://waterheatertimer.org/Programmable.html#15132
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
If you want a timer with same capabilities, that uses a battery, and does not require neutral wire, then choose Intermatic ST01 or Ei600 timer
http://waterheatertimer.org/Programmable.html#st01
Gene
Water Heater Timers Save Money
Dec 05, 2014 | Hardware & Accessories
How to programme UPM Model ETl30
More information is needed to find manual.
ET130 timer appears to have 6 buttons with 3 buttons on each row.
http://hkm888.com/upm-marketing-et130-indoor-programmable-timer-reviews.html
Review options below:
1) Add a comment and describe timer buttons in detail so I can match buttons with known timers.
2) Open following links and check if manuals for ET525, ET420C, ET420 might have same button and programming relationship.
http://waterheatertimer.org/UPM-timers-and-manuals.html#ET420C
http://waterheatertimer.org/UPM-timers-and-manuals.html#ET130
Add a comment please
Oct 02, 2011 | UPM Indoor Electronic Programmable Plug-In...
I have a hadco timer that needs to be reset....where can I learn how to do this?
Hadco T6 looks like Kitchler 15558WH
http://waterheatertimer.org/pdf/Kitchler-15558WH-timer.pdf
There are several brands of timer that look same-similar:
Open following link for images and manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Add a comment and say which manual matches Hadco timer.
Jun 15, 2011 | Hadco Digital Timer Model T6
I need the instructions for a UPM Model 100 indoor programmable timer...
UPM100?
Do you mean UPM RTC100 remote control timer set?
Smarthome usually posts manuals with their products:
See if this is your product:
http://www.smarthome.com/2046/Programmable-Receptacle-Timer/p.aspx
pdf manual
http://www.smarthome.com/manuals/2046.pdf
add a comment if this is not your timer
Nov 20, 2010 | UPM Indoor Electronic Programmable Plug-In...
I lost the installation & how to program infomation.
Woods in-wall 59018 is programmable timer:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
Woods 59203 plug-in timer is programmable:
http://waterheatertimer.org/pdf/Woods-59203.pdf
Woods 59337 plug-in timer is programmable:
http://waterheatertimer.org/pdf/Woods-59377.pdf
Older style Woods 49556 plug-in timer is programmable:
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
If your timer is not listed, add a comment with description of timer
Nov 15, 2010 | Woods InWall 7 Day Digital Programmable...
Leviton Programmable Timer 6124H-W installation problem
I Have a decora 24 hour lcd programmable timer switch 6124, when i set the timer it doesn't go on, but it goes one a 5:00 am. when there is nothing programed?
Apparently i need to set the time first and then program timer?
Can you please help. Thanks so much.
Apr 20, 2009 | Leviton 6124H 24 Hour LCD Programmable...
Prince Castle 740T2  2Channel Single Function Electric Timer Bold LCD R Logo
388 people viewed this question
Top Prince Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Prince Hardware and Accessory Expert? Answer questions, earn points and help others
