Question about Cameras
My camera says lens error when i turn it on. how do i make it go away
    Brigadier General:
  • 3,006 Answers
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the manufacturers service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the speedy and free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 08, 2010
I turn on my camara and then the lens makes a noise and it turns of right away,i charge the battery (fully) and it still turns off
maybe because you have a lens error trouble, Lens errors (system errors) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:wish you luck thanks
Feb 21, 2012 | Sanyo VPC-X1250 Digital Camera
Lens error
Lens errors with these types of point and shoots usually mean the camera is basically dead. The cost to repair a lens error is almost always more than buying a replacement.
However, there are a couple of things you can try out.
1. First try to use some canned air to blow out anything that might be caught inside the lens mechanism. Just spray a bit on the outer part of the lens when the camera is turning on.
2. Turn the camera off. Then try to insert a fingernail inside the lens cover (right on top of the lens glass). Turn the camera on and pull away from the camera with your fingernail. Sometimes the outward force can help unjam the lens.
May 07, 2011 | Nikon Coolpix S600 Digital Camera
When I turn on my camera, it comes up with "Lens error". What does that mean?
HI. One possible reason for this error is the camera has been switched on and the lens unit is prevented from extending itself. The camera will struggle for a second to extend the lens, then report the problem as a "lens error". I would start by Inspecting the lens for any obvious obstruction, then turn the camera off, then back on again. Usually, simply switching the camera Off and On again will correct this problem. If that doesn't correct the error, Remove and recharge and/or replace the battery. If the error does not clear up right away, leave the battery out of the camera overnight, and try again the next day. You are basically forcing the cameras micro board and chip sector into a reset mode when preforming this procedure.
  • NOTE_ If none of the procedures above produce positive results, I'm afraid that this unit will need to be sent to the manufacture for a serious repair detail, due to mechanical lens failure. There are no user serviceable parts on these units
Aug 16, 2010 | Cameras
I have a Nikon D90 with the 18-105 lens. Frequently, when attempting to take a photo, I will get an error message. If I turn the camera off and then on again the error message will go away. Any...
This is a common problem with D-90's. Nikon won't admit a problem, until they do not much can be done. I have to pull the battery to make my error message go away! I know this info doesn't help much, but your certainly not alone!
Jul 21, 2010 | Nikon D90 Digital Camera with 18-105mm...
Error message ''Lens error'' on nikon coolpix digital camera
Try cleaning any grit out of the lens mechanism with compressed air and a little wiggling of the lens. If that doesn't do it, the camera needs servicing.
Nov 15, 2009 | Nikon Coolpix S210 Digital Camera
Lens error won't go away
Sadly, the camera needs service.
Feb 28, 2009 | Nikon COOLPIX L18 Digital Camera
Will not stay on
Will the lens extend when turning on? , can you see any message on the LCD? it is possible there could be a system error or lens error (lens error if jammed all the way in closed position, usually makes the camera shut off right away)
Sep 02, 2008 | Nikon Coolpix L11 Digital Camera
Lens Error
Check the contacts in the battery case. You can stretch/bend the contacts further out and the problem seems to go away for a while.
Jul 08, 2008 | Nikon Coolpix L11 Digital Camera
Sytem error 10
Hi - I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Sort of like a Windows Restart to reset the memory.
Hope this helps.
May 09, 2008 | Nikon Coolpix 4600 Digital Camera
Won't turn on and lens is out.
Sounds like you might have gotten some pocket lint in the lens barrel. The following blog outlines some repair options for a lens error:
Dec 15, 2007 | Nikon COOLPIX L2 Digital Camera
Cameras Logo
16 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
