Question about Jensen XA2250 Car Audio Amplifier
How do I wire the system - Jensen XA2250 Car Audio Amplifier
  • 182 Answers
You would require an amplifier wiring kit which will contain all the wires to get power and signal to your amplifier; six feet of 14-gauge speaker wire for the subwoofers. Your speakers should have come with their own speaker wires.
The amp connects to your head unit via an RCA cable and often a "remote on" wire, and also connects directly to your car battery through a fused "hot" wire and to the car's chassis with a short ground wire.
The complete installation process is as follows
#1
Disconnect the ground (negative) cable from your battery first and foremost. NEVER work on the electrical system of your car with this connected.
#2
Install your new speakers. Start by removing the paneling of the speaker enclosure. Unscrew and disconnect the old speaker.
Ideally the speaker wire will be connected to the old speakers with a metal clip that can then slide right on to your new ones. If not, cut the wire off the old speakers, strip about half an inch of it, then cut the last 6 inches or so off the speaker wire that came with your speakers so you have the proper connectors with a little wire attached, strip a half inch of those wires and twist connect them to the existing speaker wire. Bend the twists so they are in-line with the wire and wrap each connection in electrical tape so no wire is showing to protect them.
Attach the connectors to your new speaker. Make sure to connect the negative wire (-/black) to the negative terminal on the speaker and the positive wire (+/red or white) to the positive one. Screw the speaker in place. If you have component speakers, and therefore a crossover, make sure the crossover is secured in the speaker compartment so that it does not bounce around while you drive.
Wait to put the speaker enclosures back together until you have installed the head unit.
#3
Follow the instructions you got for removing whatever part of the dash covers it and take out your existing head unit. Connect the car stereo wire harness to the connector that was attached to your old radio and attach the other end to your new one. Connect the antenna cable (the single wire with the big plug at the end) to your new head unit as well.
If the speaker wires are separate from the harness connect them using the method of stripping, twisting, and taping described above. Do this one at a time or use masking tape to label the wire to avoid confusion. If you are having trouble figuring out which wires go to which speaker or which is positive and negative read the tip at the bottom of this section.
Do not put your new head unit into the dash yet-you still need to connect the amplifier to it. Put the speaker enclosures back together now.
#4
Attach the thick positive (+/red) power cable for your amplifier to the connector on positive terminal of your battery. The kit you purchased should have come with an o-ring on one end of the wire (you may have to crimp it on yourself, if so do it on the end with the fuse), this ring can be sandwiched in the bolt on the connector that connects your car to the battery.
#5
Put the fuse in the fuse holder.
#6
Run the power cable through the firewall of your car (there is usually an opening on the drivers side) and along to the back of the car where your amp is. It is usually best to run this wire under the plastic molding that goes along the bottom edge of your car, you never want the power cable to come near any speaker wires. At the same time run the remote on wire (a really thin wire from the amplifier wiring kit), through the dash where the head unit will sit, along with the power cable to the amp.
#7
On the other side of the car run the RCA signal cable through the dash from the head unit to the amp (it's a pair of wires together with connectors on each end).
#8
In the back of the car pick exactly where your amp and subwoofers are going to go. Part of choosing this is that the thick black ground cable (negative) needs to have a place to connect to the metal frame of your car. This should be as short as possible, you never want the ground cable to be longer than 3 feet.
#9
Find a good screw or bolt, take if off and sandpaper the metal surface that the o-ring will make contact with, then screw it down tightly.
#10
Attach the RCA signal cable and the remote on cable to your head unit and attach the power, ground, RCA signal, and remote on wires to your amp.
#11
If you have not already done so, place your subwoofer box in the trunk and attach your amplifier to it if that is what you are doing. If you are not going to screw your amp to the subwoofer box then it must be secured to something else.
#12
Attach the 14-gauge speaker wires to the left and right channels of the amplifier and to the speaker connectors of the subwoofer box.
#13
Mount your head unit into the dash. Double check all of the connections on the back of it to make sure they are secure. Then slide your head unit into its slot in the dash and screw it securely in place. Before you re-attach the dash, reconnect the ground (negative) cable to your car battery and turn the stereo on and move around the car listening to each speaker to make sure everything is working properly. Then put the dash back on. You are all done!
Hope this helps
Thanks
Posted on Oct 08, 2010
CDBA3100 Hi, I found this part for $15 and for $6.50-One picture shows the loop not the wires that connect , my question is-can u buy this part without the wires? Any help would be appreciated.
Not sure of the question, but for $21.50 why not just buy both? or
buy the $6.50 without the wires and use your old wires or
buy the $15 with new wires which would probably be what I would choose.
Sep 08, 2015 | Sharp CDBA3100 Remanufactured Mini-System...
The kit includes a line plug with 2 screws for wires. assuming it is a phone wire that is to be used which of the 4 phone wires should be inserted into the line plug.
Usually the green and red, but best way to find out is pop the phone port box where you land line comes into the house, and check to see what wires are used. Some countries use 2 wire systems others use 4
Feb 16, 2015 | Visonic Security Systems Visonic POWERMAX...
Original speaker wires lost - can they be replaced with commercial speaker wire, and if so will longer wire lengths work just as well?
I checked my Sharp system and it uses ordinary wire for the speakers. The difference in length won't matter. $20 for replacement wire? They must be kidding.
Nov 26, 2013 | Sharp XL-HP500 CD Shelf System
I hav a Diva DV-603PG dimmer switch that has a black wire a red wire and a red wire with a white stripe. What wire is what?
This switch is for a 3 way system (2 switches controlling one light for a stairway or hallway). The black wire goes to the special coloured screw on the old switch (common). The common wire is either the original live wire feeding the 3 way system or it is the final wire that leads to the light fixture in a 3 way system. All 3 way systems have an either or wires called traveller wires that can be swapped from either end of the 3 way system. the red wire and the red wire with the stripe are to go to the 2 remaining wires that were on the old switch. Those are the traveller wires. If you have a green wire it goes to the ground (a screw at the back of the switchbox or any green or bare wire found in the box)
Jun 22, 2013 | Electrical Supplies
Getting a reading "Protect" when
Hi, This feature is designed to protect the unit from short circuits going to the speakers.
To test this,
1 Shut off the System
2 Disconnect the speakers from the back of the system.
3 Start the system with the volume turned completely down to 0.
4 If the system starts and does not go into protect. Do the following
a Turn off the system
b Check the wiring to each speaker and make sure none of the wires or wire strands are touching each other. Do this at the speaker end of the speaker wire and at the system end of the wire
c Connect the speakers back up observing not to have any strands of the wire touching each other
d Turn the power on and see if it plays OK.
e If it does not power up properly. Leave the system completely off for 45 minutes. Then turn it back on and see if it works properly.
If it does not at this point. Professional repair will be necessary.
Hope this helps,
Best,
Mark
Jan 04, 2011 | Sony Audio Players & Recorders
What does check sp wires mean on my yahama home theater system?
That mean the system is detecting a short in the wires. (somewhere they are touching) trace all the wires and make sure there is no cuts in the wire. (please rate me if this helps) Thank You.
Dec 24, 2010 | Yamaha YHT-340 System
I paid $20 last night to talk to someone. He told me how to hook up the Lux DMH110 but when i hooked it up this morning the heater came on when i put it on COOL and the fan just come on when i put it on...
If you have this type of system your thermostat will not work;
  • Multi-Stage Heat Pumps
  • 3 Wire Hydronic Systems
  • Line Voltage Systems (120/240 VAC)
  • This thermostat is only for this type of HVAC systems;
  • Most 24V Heating and A/C Systems
  • 1 Stage Heat/1 Stage Cool: Gas, Oil, Electric, or Single Stage Heat Pump Systems
  • 2 Wire Heat Only Hydronic Systems (Hot Water Baseboard & Radiator)
  • Millivolt Systems (Wall Heaters / Furnaces & Gas Fireplaces)
    1. Never connect a low voltage thermostat to line voltage.
    Two wires control a heat only system.
    1. Connect one wire to W and the other to RH.
    Two wires control a cool only system.
    1. Connect one wire to RC and the other to Y.
    Three wires for forced air heat only system, where the previous thermostat
    did not have a clock or timer.
    1. The previous RH or RC wire is the 24-volt transformer wire. Connect it to RH. Leave jumper connecting RH to RC. Connect the forced air heat system to W, and the fan wire to G.
    Three wires for a heat only, forced
    water system that did NOT have a
    clock or timer.
    1. This system employ 3 wire zone valves. Currently no Lux controls are compatible with this system.
    Three wires control a heat only, forced water system that DID have a clock or timer.
    1. Tape off and do NOT install any clock or timer wire. Often they are labeled C or TC. Install the remaining two wires, one to RH and the other to W.
    Four wires control a heat only system,
    and two of the wires operate clock or timer. The other two wires operate the heater.
    1. Tape off and do NOT install any clock or timer wire. Often they are labeled C or TC. Install the remaining two wires, one to RH and the other to W. The jumper connecting RH to RC may remain or be removed.
    Two wires control heating AND cooling.
    1. Currently no Lux controls are compatible with this system.
    Three wires control heating and cooling. One wire operates heat, one operates cooling and the third provides 24 VAC.
    1. Connect the 24-volt power wire to RH. Install a jumper connecting RH to RC. This jumper is usually pre-wired. connect the heat wire to W, and the cooling wire to Y.
    Three wires control a cooling only system. One wire operates the compressor, one operates the fan and the third provides
    24 VAC.
    1. Connect the 24-volt power wire to RC. Connect the cooling wire to Y and the fan wire to G.
    Four wires control a heating and cooling, electric, gas or oil, forced air system that
    is NOT a heat pump.
    1. Connect the 24 VAC transformer wire to RH or RC. Install a jumper connecting RH to RC This jumper is often prewired. Connect the heat wire to W, the cooling wire to Y. and the fan wire to G.
    Four wires control a Single Stage Heat Pump. They were labeled: G, Y, R or
    RH or RC, With either B or was used.
    1. Do not connect wires to both B and O. Connect the reversing valve wire to B or O, just as the previous thermostat. Install a jumper wire from RH to RC. Connect 24 VAC wire to RH too. Install a second jumper wire from W to Y. Connect compressor wire to Y and the fan wire to G.
    More than 4 wires are connected to the
    old thermostat
    Jun 27, 2010 | Heating & Cooling
    Electrical wiring diagram
    the gray wire is the common or red or yellow wire
    Aug 25, 2009 | Vehicle Parts & Accessories
    Speaker wire problem
    Yes you can splice the ends onto the existing wires, but first make sure the ends are labeled + or - and make sure you hook the other ends to the speakers the correct way. Before you cut the connectors off of the speaker wires mark one of each of the pairs of the wires with tape, on each side of where you cut it so you can match the wires back up. Are the pre-wired, wires labeled + and -? or red and black? Or one of each pair is a different color wire ie silver and copper? If they aren't labeled its going to be hard to get the correct polarity (+ and -) for each speaker. I hope this helps post back if you have any problems.
    Aug 19, 2009 | Philips HTS-3565 Theater System
    Stock stereo wiring diagram for 2003 cadillac cts
    there are 2 diagrams listed, one is correct, match the listed wire colors to your car to choose the correct one.
    Car Radio Battery Constant 12v+ Wire: Pink
    Car Radio Accessory Switched 12v+ Wire: Blue
    Car Radio Ground Wire: Gray
    Car Radio Illumination Wire: Red/Blue
    Car Stereo Dimmer Wire: Red/Yellow
    Car Stereo Antenna Trigger Wire: N/A
    Car Stereo Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: N/A
    Car Audio Front Speakers Size: 6 1/2′
    Car Audio Front Speakers Location: Doors
    Left Front Speaker Positive Wire (+): Pink
    Left Front Speaker Negative Wire (-): Blue
    Right Front Speaker Positive Wire (+): White
    Right Front Speaker Negative Wire (-): Black
    Car Audio Rear Speakers Size: 6′ x 9′
    Car Audio Rear Speakers Location: Side Panels
    Left Rear Speaker Positive Wire (+): Light Green
    Left Rear Speaker Negative Wire (-): Purple
    Right Rear Speaker Positive Wire (+): Blue
    Right Rear Speaker Negative Wire (-): Pink
    2.
    Car Radio Battery Constant 12v+ Wire: Yellow
    Car Radio Accessory Switched 12v+ Wire: Green/Black
    Car Radio Ground Wire: Chassis
    Car Stereo Dimmer Wire: Gray
    Car Stereo Amp Trigger Wire: Green/White
    Car Stereo Amplifier Location: Under the Passenger Front Seat.
    Car Audio Front Speakers Size: N/A
    Car Audio Front Speakers Location: N/A
    Left Front Speaker Positive Wire (+): White
    Left Front Speaker Negative Wire (-): Black
    Right Front Speaker Positive Wire (+): Yellow
    Right Front Speaker Negative Wire (-): Brown
    Car Audio Rear Speakers Size: N/A
    Car Audio Rear Speakers Location: N/A
    Left Rear Speaker Positive Wire (+): Brown
    Left Rear Speaker Negative Wire (-): Black/Red
    Right Rear Speaker Negative Wire (-): Black/White
    Jun 04, 2009 | 2004 Nissan XTerra
    Jensen XA2250 Car Audio Amplifier Logo
    176 people viewed this question
    Top Jensen Car Audio & Video Experts
    xxxxxx xxx
    Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
