Question about E-Machines eMachines Desktop PC
My e-machine computer won't acknowledge anything plugged into the USB ports all of a sudden. My printer was plugged in and my phone charger w/ the usb cables and was working fine, but now for some reason it stopped working. When I unplug or plug in the usb cable it doesn't make the sound on the computer like it is acknowledging it was just plugged in like it used to. It is a W series desktop, serial # XC67C40016464
  • 707 Answers
1 a damaged USB cable if you are having difficulty with a single device
which you've tried on a number of ports, or equally in this scenario the
connected device might be faulty. Try another known working USB cable
and/or device. You've probably taken this step already.
2 a Windows automatic update has been applied which is causing the
problem. Try and identify the culprit and uninstall it, or revert to a
previous system state at a time when the USB ports were all working using
System Restore. Backup any important data first.
3 You have some kind of virus or Trojan activity present on your system
which is disabling the services. Check the state of which Windows services
are enabled at start-up and also check which are active. Run a decent virus
scanner and spyware detection programs to try and eradicate the problem. I
don't know of any specific viruses that would do this but you never know
these days.
4 Your USB ports are for some reason not supplying power to external
devices - very unlikely that all ports would fail simultaneously though.
5 Something has changed in your PC's BIOS settings. Reset the BIOS
values to their default settings and try again (after making a note of any
key settings that will need to be re-applied). Power spikes can sometimes
cause the BIOS settings to become corrupt - as I know only too well from a
slightly alarming experience two weeks ago when I was in the middle of
recording a band with Cubase SX at a live event when the power went off and
back on again rather quickly because the lighting rig tripped the mains
power out momentarily. The PC wouldn't boot. A quick side panel removal
and BIOS reset thankfully brought the system back on line. My own fault. I
should have taken a UPS with me :-) More importantly, the attached Firewire
multi-channel sound card wasn't damaged.
6 You have a faulty board and it should be replaced. I think this
unlikely though unless a device that has been plugged in at some point has
shorted the 5v power supply and possibly blown a fusible link on the board -
most boards have some form of protection like this to prevent damage to
connected peripherals (very small and hard to spot unless you know exactly
which board component to look for and can be similar in appearance to one of
the tiny surface mounted resistors).
Try and see if any USB port will operate outside Windows perhaps by
attaching a bootable external hard drive or memory stick (USB drive) and
reviewing whether or not the device is detected at POST
Check your internal power connection to the board and make sure no pins have
worked loose from the multi-pin power plug which 'might' cause power not to
be present on your USB ports
Try booting the PC in Safe Mode and checking whether your USB device is
detected. This will probably be a bit hit and miss I'm afraid as Safe Mode
may cause the device not to be detected anyway depending on any specific
drivers being needed.
If you have a spare hard disk lying round that is big enough to take Windows
XP, you could perform a clean OS install on this and see what happens
As a last resort if you have any way of borrowing an identical board and
attaching all your drives etc.. to it, see if the problem still exists.
Obviously if the problem disappears it is more than likely to be a board
related issue, but not necessarily hardware based. It could still be BIOS
related and resetting or reflashing may cure the issue.
FWIW though, my gut feeling is that I suspect your problem is OS related
and/or driver related. XP SP2 can sometimes have unexpected effects on
hardware - something I have also experienced once or twice with a particular
Gigabyte board one of my clients has. If you have just updated to SP2, I
would say that it's almost certainly caused the problem you have and you
might need to update your BIOS to resolve the issue anyway.
hope one of these helps
Posted on Oct 29, 2010
EXPERIA E15i wont charge batt, plug or usb,
the port where you plug the usb or the charger is damaged go and replace with spare part
May 24, 2013 | Sony Ericsson Xperia X8 (E15I)
Samsung galaxy s2 not charging
Either your battery needs to be replaced or charging port is damaged
Jan 14, 2013 | Cell Phones
Computer does not acknowledge the usb connection can't find driver on disk Using Vista
Make sure you're plugging the USB cable from the machine intoa USB port in the BACK of your computer, not one of the front ports or a porton a USB hub. The cable and machine need more power than most of those portsprovide, a technical detail that Singer doesn't realize. Good luck!
Mar 26, 2011 | Singer CE-200 Quantum Futura Computerized...
I have no idea what is wrong with my scanner. My computer won't even acknowledge it's existence anymore. But the printer function on my HP 2355 works fine.
1. Verify electricity
2. Verify connected to computer still. (USB assumed)
Unplug it and plug it back in at both ends of the wire. Make sure USB is not in a network port.
3. Pull electric from printer 3 min. Restart computer.
4. Test; if no joy reinstall printer, but do not plug in USB until asked for it.
Please vote if helpful!
Oct 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
I want to download ring tones from the web using my computer and a USB cable plugged into my phone. I think I need to download software so my computer acknowledges my phone plugged into the USB.
If there are two USB ports on the back of you computer try both, i tried mine the other day and one said "unused port" so i switches and it worked.
Oct 29, 2009 | Pantech Slate Cell Phone
Windows vista does not acknowledge Opal M4002a
If the player is not recognize try to connect the mp3 player ona different usb port and check if it will be detected if still not detected better connect this mp3 player to another pc and check if it will be detected on that second pc if not detected there's a possibilty that the mp3 usb functions is not working fine.
Jun 20, 2008 | RCA OPAL M4001 MP3 Player
Lexmark 1270 all in one
First try plugging into a different USB port. I have seen several machines have a port suddenly die for no apparent reason. If that dosent work, try a different USB cable. Assuming the printer is working, the only thing left is either the cable or the port you have it plugged into.
Feb 07, 2008 | Lexmark X1270 All-In-One InkJet Printer
E-Machines eMachines Desktop PC Logo
121 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
