I have an old and I do mean old satellite dish and reciver and I.m trying to get it to work and Im having a hard time doing it on the reciver it says that it is a president and it is also a ps600xl do you know anybody that can help me with it is so they can contact me at jreed139@juno.com thank you
  • 11,800 Answers
Here's the user manual for it
http://www.uniden.com/pdf/PS600XLom.pdf
But i don't understand why do you want to use it - it's a C/Ku band analogue receiver, there aren't many satellites emitting this way left. Actually all professional ones have been retired so you can't use it to view tv channels.
Posted on Oct 08, 2010
I need the code for a maganavox blue ray player
If you still have this remo than that means you have outdated recivers. Also dish will not promise you that the remo will program to all devices so if you have already called a call center and no luck than your SOL. Best bet is to do a DIU (Dish N Up ) upgrade and get brand new equipment. If your equipement is more than 10 years old.
Apr 04, 2014 | DISH Network IR Remote Control
Plasma tv connections
What you need is a device called a multi-switch. Here's a page which details some of the switches available with different satellite setups. You would hook up your sat recievers, your TV and your recorder up to the multiswitch:
http://www.satellite-connection-systems.com/Multiswitches.html
Jan 08, 2008 | Computers & Internet
Sharp lc32h9
you cant do that.. im sorry to say but its Programmed just for Japanese programs ... The only way to watch ur Philippines channels is to get a Digital satellite reciver and a satellite dish , and good luck.
Dec 18, 2013 | Sharp Televison & Video
Dish Network 322 will not work both TV's at the same time. If TV1 is on it works fine, but TV2 says aquiring satellite signal. If TV2 is on it works fine, but TV1 will say aquiring satellite signal. Both...
Hello! Dan Busa with Dish Netywork here intermittent signal loss like that is usually caused by some sort of glitch a hard reset ( unplugging it for ten seconds ) will usually resolve this. If your signal strength is at or above 80 that should be fine, but keep in mind you need good signal strength on both the 119 and 110 satellites ideally you should be at 70 .
Jun 25, 2010 | DISH Network 322 DTV Receiver
My dish dvr remote only works on satellite from zero inches away from reciever. The remote works on the tv from 20 feet away. Have tried wiggling the antenna, etc. Any other ideas?
Check your batteries.. Trust me on this it happens lol..Also do you have anything on top of the tv like a VCR or DVD player? That can cause that also. If your able too control the reciver with the remote than it could be a number of these things. Just check ubstructions anything that can be blocking it. Some newer model tv's have a light censor that causes the remo too stop working as well. If its a newer model like an HD tv this could be your issue as well
Nov 15, 2009 | DISH Network IR Remote Control
Does the dish network 322 receiver require two lines from the satellite to the receiver?
It does require 2 lines form dish unless you have a switch installed such as a dp34 or you have Dish Pro plus LNB"S on your dish and you can use 1 feed to the reciver and use a separator to separate the signal into sat 1 and sat 2 (note: a standard splitter is NOT a separator) a separator is dish brand equipment.
Oct 15, 2009 | DISH Network 322 DTV Receiver
Picture quality
The output from your sat reciver is not HD unless it says right on it that it is . The signal your getting now is a digital signal from the dish to the reciver, but from the reciver to the TV set, it is analog. To answer short and sweet, Yes, you will need an HD reciver for the satallite to get the most out of your HD TV set. Good Luck Ps and please dont forget to rate this.
Oct 16, 2006 | Hitachi 57S715 57" Rear Projection HDTV
Satellite Receiver Malfunction
Go into the menu and check the signal strenth to see if its going up and down or if its a stead as a rock. I have seen this problem be the reciver as I was a satillite contractor for 5 years in the past and I have installed 1000's. I have also seen your poblem be a small brance in the distance cause the freezing, also a bad connector from the lnb on the dish to the multiswitch, or a bad connector on the back of the reciver or even a pinch in the wire but the most common thing I have found would be a loose connection on the back of the reciver with the fitting wasent screwed on all the way.. If the signal is rock steady, the reciver will need to be replaced as the recivers dont pay to be repaired. good Luck
Jul 31, 2006 | RCA DRD485RG DirecTV DTV Receiver
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
