Question about Motorola Mobility RAZR V3i Cellular Phone
Help pleaase the screen is showing with line in it like the ribbon gone but its not the ribbon it the board as in wen u press on in the key pod light up back and the line like gone rit now i cant see anything on it well and wen it charging nothing dont wrong wit it do u know the problem wit my phone the number is 18763519376
Hw can i solve the problem nah
Posted on Jan 25, 2013
My hand set not dispaly on time screenserve
Posted on Jun 01, 2008
Turned on sound coming through, but screen showing vertical multicolor lines. could not turn off at first finally did and screen would not come back on. Unplugged overnight and tried again the next day...
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them.
Hoping this will help in solving the problem...
Aug 06, 2011 | Westinghouse TX-42F430S Television
My samsung tv will only show blue vertical lines. It also shows multicolored lines when i hook up anything 2 it. What would cause this> ?
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken, Good luck in solving the problem.....
May 21, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a yellow vertical line on the left part of the tv screen and the tv cuts of and light blinks 7 times and then pauses.
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken because the panel board contains high voltage.
May 14, 2011 | Panasonic TH-42PX75U 42 in. Plasma...
I have dell vostro 1000 labtop an the screen is just black wen i turn it on there is no light but i can here the sound so i no it is on i just can see anything can anyone help. pleasurezone74@yahoo.com
It sounds like the laptop is set to use an external monitor.
Check the function keys for an icon that looks somewhat like a monitor
turn the unit on and wait until it is started
then press and hold the function (fn) key
While holding the fn key press the function key with the icon (it is a stepping control)
this should, after one or two presses bring up your on-board screen.
Good luck, I hope this helps
Apr 04, 2011 | Dell Computers & Internet
My WESTON TV is showing grey n white vertical n horizontal lines all over the screen the images comes for 5-10 min and again shows same lines.......but sound part is good. plz help me
All plasma an lcd TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Aug 04, 2010 | Televison & Video
Verical lines on half of the screen
I have the same prob. Please help my *** out here!
May 25, 2010 | Toshiba REGZA 52RV530U LCD TV
Dell latitude d360 has aproblem on screen,wen i start it it brings alot of lines on screen.
Try these steps :
  • turn off the laptop and unplug all the peripherals.
  • take out the battery
  • press and hold the power button for 30 seconds without the battery and the adaptor.
  • after that put the battery back and press and hold the Fn key and then press the power button to turn on the computer it will take you to dell diagnostics.
  • If you see colour bars on the screen press y for yes from the key board it will then do a small diagnostics and restart your computer.
  • If in this process u still see the lines on the screen that indicates the lcd screen failure and will need a replacement.
Mar 23, 2010 | Dell Latitude Cpi D366XT PII Notebook
Cell phone hangs wen call comes
Power off your phone and press * and # key both and while pressing those keys power on the phone. Some information will show on screen about your phone. Check if it is R4517 or R4513 then you need to reflash the phone. You can do that easily with RSD Lite and a cable. If you can't get the flashfiles ask here as we can help you.
May 19, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Blue Vertical Line- Akai PDP4298ED
I have an Akai PDP4273M that developed the same problem. Checking around some of the av forums, I found a couple of threads that indicated it could be dust or bad contact around the ribbon cable connections on the video control board. I removed the back, loosened the ribbon cables on the board and used my small compressor with an air gun to blow out the dust all around the board and the ribbon connectors. Reconnected everything, turned on tv and stripe did not come back. Problem fixed! Nice and cheap solution.
May 28, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Motorola Mobility RAZR V3i Cellular Phone Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
