Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Loud buzzing sound when you turn tv on. - Philips Magnavox 50ML8105D 50" HDTV DLP TV
  • 1 more comment
  • cagoldenboy Oct 08, 2010
    DO YOU KNOW WHAT MODEL NUMBER IS FOR THE EXHAUST FAN
    50ml8105d17
    could i tell where the problem is by where the noise is coming from. side exhaust fan or back of tv light engine?
  • 10,594 Answers
Host probably buzzing sound would be exhaust fan inside tv to throw hot air of lamp.
Is it Philips 50ML8105D tv or any other model?
Model number would written on sticker pasted at back of tv.
Thanks
Posted on Oct 08, 2010
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Oct 08, 2010
    Please confirm your tv model
    I assume that it is Philips 50ML8105D tv model.
    Exhaust fan can be cause of buzzing sound in tv and/or color wheel can also be one of cause for said symptoms. For bad color wheel, you need to replace light engine by experienced tv repairman.
    Click Exhaust Fan and Light Engine for price details.
    And if tv model number is other than above mentioned then do not follow these info and get back to me.
    Thanks.
    OK, I already posted possible cause of problem for that model and replacement parts info.
    Thanks.
    You can guess either noise is coming from fan or light engine while sitting at back of tv, remove lower back cover for better guess.
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
3 lights blink and a loud buzzing sound.
Color wheel you can get one at the following link with instructions on how to replace it
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Loud buzzing sound
It is the color wheel. They are usualy less than $150. I recommend having a Samsung authorized service center do the work as it is very difficult for someone without the experience doing this particular job. Labor cost should be $300 or less.
Sound has turned into a loud buzz
check,probably you change the sound module or if you can work efficiently on the module ,u change the sound ic & the entire electrolytic capacitor within the circuit.
Oct 05, 2008 | Akai LCT3285TA 32 in. LCD Television
Buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Mar 15, 2008 | Proview PA-32JK1A 32 in. LCD Television
Buzzing sound from my tv
tv makes a buzzing sound when i turn on the set, than stops.
Dec 10, 2007 | Harsper HP-4200VPM Television
Loud Buzzing Sound
since you changed the lamp my next thought is that the color wheel has failed,,,most good road techs can replace it in the home..the cost would be between 220.00 and 350,00 depending on the company...
Nov 27, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Buzzing after 1 hour
Is the buzzing coming from the back of the TV, staying loud even when the volume is turned all the way down, or is it coming from the speakers?
Sep 04, 2007 | Mitsubishi CK-35306* TV
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
178 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
