Question about Bushnell Cameras
Bushnell trophy cam. Mod-119405. I have only had this cam for 1 1/2 to 2 months. When I turn on to the setup mode, the screen light comes on but nothing else, It woun't take pictures or vids. I have put in 2 new sets of Energizer batteries and still nothing, the sd cards are the same 4 that I have been using in it, and they work fine in my other camera and Bushnell scout. What is the problem
SOURCE: NEW Batts but keep getting low batt indicator and....
Sorry, no solution. Same problem here. I am very unhappy because initially it took great pictures. The first one I tried only worked a couple of days and I returned to store and they replaced. Second worked a couple of months and now immediately draws down power and won't work on new batteries. I was told to use NH-10 batteries (rechargeable). I did this from the beginning. Still won't hold charge.
Posted on Feb 13, 2007
SOURCE: S2 suddenly draining batteries rapidly
I have the same exact problem. I just now read a possible solution: try opening the battery compartment door and then closing it again to "trick" the camera into thinking it just got new batteries. There is definitely something wrong with the way the camera senses dead batteries.
Posted on Aug 01, 2007
bunnykinjoe
  • 3 Answers
SOURCE: Camera stuck when using memory card
hi, i had a problem with my camera where i put in memory card and it said 'out of memory' i took the card out turned on camera went to set up mode and found one that said 'rest to factory defaults' pressed that and then put card in and all ok, might be worth a try :-)
Posted on Aug 15, 2007
jerryg50
  • 1689 Answers
SOURCE: SD card rejection
I have seen SD cards go defective. Also, enquire to the manufacture of the camera or at least the dealer to make sure that the model of SD card that you have is compatible. I have seen compatiblity issues with particular SD card types on specific models.
Jerry G.
Posted on Jun 06, 2008
DUMPLINS559
SOURCE: i733 Polaroid camera will not turn on
well I HAD THE SAME PROBLEM ALL I GOT WAS A BLACK SCREEN & 3 BEEPS,SO GOT A LETTER OPENER AND STUCK IT IN THE SPACE BETWEEN THE ZOOM LENS A FEW TIME VERY CAREFUL PUSHING DOWN THE POWER BUTTON AT THE SAME TIME AFTER A FEW TIMES THE LENS BECAME UNSTUCK..JUST JIGGLE IT A ROUND A LITTLE BACK AND FORTH WITH A LITTLE FORCE.I HOPE YOUR CAMERA WILL START TO WORK AGAIN LIKE MINE DID.
Posted on Feb 05, 2009
Is there a factory reset
Normally you have to send it in to Bushnell and have them do it for a fee but in the past I used the following to reset a similar Bushnell trail cam and it may work for you:
1. Turn camera on and wait for the password screen.
2. Press and hold the enter button until the camera switches to the 5 digit password mode. "Trail Sentry cams will not indicate a 5 digit mode on the screen, but it will show "-----".
3.Press enter to confirm 5 digit mode.
4. Enter the 5 digit code "66214, then press enter. *Note it will accept a 5th digit.*
5.Camera should display "PASS" and go into the operating mode.
From here you can program a new password from the setup mode.
Nov 08, 2014 | Bushnell Trail Sentry 11-9200 Digital...
My cam acts like its working but the number doesnt go up its says 0
Issue with Software Try to Re-Install Software then Set Menu Setup utility ..
Sep 30, 2010 | Bushnell Trophy Cam with Text LCD
I have the 8.0 bushnell trophy cam. When I run it in video mode the time stamp is not on the screen but durning set up it is set to on. The video is also worse than my 5.0, you can see trails behind the...
Hi when making any changes during the set-up you have to OK every step of the way, like entering on a keyboard.
The light trails are refelctive infra coming of the animal/prey from other light sources, a bit like the lens flare effect you will get when shooting into the sun.
also set the resolution to high for the video mode.
have a go and let me know.
Regards
Mr Yoda
Sep 01, 2010 | Bushnell Trophy Cam with Text LCD
I HAVE A BUSHNELL TROPHY CAMERA, AND ONE OF THE BATTERIES LEAKED. AFTER CLEANING IT UP, IT WILL TURN ON, BUT KEEPS BEEPING AND CYCLING THROUGH THE PROGRAMMING AND WONT LET ME PROGRAM IT.
sounds like you may have scorched the connection and it's bled into the PCB, looks like you may have to get it replaced, if the batteries are at fault as in they should not have leaked then they battey firm will replace the item. check warranty terms on batts and the t/cam.
Regards
Mr Yoda
Cameras Logo
215 people viewed this question
Top Bushnell Cameras Experts
Johnny Massengill
Johnny Massengill
Are you a Bushnell Camera Expert? Answer questions, earn points and help others
