Internet not connected on second computer which is routed from first which is connected
  • Agugua  Lims
    Agugua Lims May 11, 2010
    what error message do u have then. try runing a ping command between the 2 systems n see. possibly restart yr systems then conect again
Go to control panel then select network connection then select the network connection u have then right click and goto properties then instal all the requirements
Posted on May 30, 2008
    Problem Solver:
  • 19 Answers
Check network adapter status in Device Manager.
Check network connections (local and internet) from control panel menu options.
Folow the diagnose steps if necessary.
I'm using TP-LINK TD-W8101G ADSL Modem Router to connect internet, I'm trying to connect it with Linksys WRT120N Router Wirelessly. I want to use WRT120N as access point to extend TP-LINK...
Unfortunately, you can't use two routers together in that manner. You must have a device in between them such as a switch or bridge or you'll have to disable the DHCP server settings in the second router. The second router then pretty much becomes a switch you may then use all the ports on the second router with the exception of the WAN port it must remain unoccupied. However, if you need wireless connectivity in another location far away from your main router then your only solution would be to indeed purchase an actual access point/bridge device
Sep 06, 2011 | Linksys WRT120N Router
Tip
VPN in Microsoft Server 2003
The full form of VPN is Virtual Private Network. VPN gives extremely secure connections between private networks linked through the Internet. It allows remote computers to act as though they were on the same secure, local network. Allows you to be at home and access your company's computers in the same way as if you were sitting at work.
Almost impossible for someone to tap or interfere with data in the VPN tunnel. If you have VPN client software on a laptop, you can connect to your company from anywhere in the world. VPN goes between a computer and a network (client-to-server), or a LAN and a network using two routers (server-to-server). Each end of the connection is a VPN "endpoint", the connection between them is a "VPN tunnel".
When one end is a client, it means that computer is running VPN client software. You can use a virtual private network (VPN) to connect components to one network by using another network. VPN do this by "tunneling" through the Internet or another public network. With a VPN, connections across the public network can transfer data by using the routing infrastructure of the Internet, but to the user, the data seems to travel over a dedicated private link.
A VPN gives you the benefit of a dial-up connection to a dial-up server, plus the flexibility of an Internet connection. Using an Internet connection you can connect to resources all over the world. If you have a high-speed Internet connection at your computer and at your office, you can communicate with your office at full Internet speed. This is much faster than any dial-up connection that uses an analog modem.
VPNs use authenticated links to make sure that only authorized users can connect to your network, and they use encryption to make sure that others cannot intercept and cannot use data over the Internet. A Tunneling Protocol is a technology that helps make the transfer of information over the Internet more secure from one computer to another.
VPN technology also permits a corporation to connect to its branch offices or to other companies over a public network, such as the Internet, while helping to maintain secure communications. The VPN connection across the Internet logically operates as a dedicated wide area network (WAN) link.
VPN in Windows 2003 Server: You need a high speed Internet connection to configure and run VPN server. Two individual lan card must be present in a single system where you want to configure a VPN Server. The lan cards should ping each other. Also need a User which's Dial in allow access should be enable. Microsoft 2003 server two tunnelling protocols for a secure VPN connection, one is PPTP (Point-to-Point Tunnelling Protocol) which Provides data encryption using Microsoft Point-to-Point Encryption. The other is L2TP (Layer Two Tunnelling Protocol) which Provides data encryption, authentication, and integrity using IPSec.
Steps to create VPN Server in 2003 Server: At first I go to Start and point to Administrative Tools, then click Routing and Remote Access. Then I click the server icon that matches the local server name in the left panel of the console. If the Routing and Remote Access service was previously turn on, you may want to reconfigure the server.
To reconfigure the server Right-click the server object, and then click Disable Routing and Remote Access. Click yes to continue when you are prompted with an informational message. Then Right-click the server icon and then click configure and Enable Routing and Remote Access to start the Routing and Remote Access Server Setup Wizard. After that click Remote access (dial-up or VPN) to turn on remote computers to dial in or connect to this network through the Internet. Then I have Click to select VPN. In the VPN Connection window I click the network interface (Lan) which is connected to the Internet and go the IP Address Assignment window, then I click Automatically because there was present a DHCP server in network. However, if DHCP is not available, you must specify a range of static addresses.
If you use from a specified range of addresses, open the Address Range Assignment dialog box and Type the first IP address in the range of addresses that you want to use in the Start IP address box. Type the last IP address in the range in the End IP address box. Windows calculates the number of addresses automatically. After that I have accept the default setting of No, use Routing and Remote Access to authenticate connection request and finally Click Finish to turn on the Routing and Remote Access service and to configure the server as a Remote Access server.
For the remote access server to forward traffic properly inside your network, you must configure it as a router with either static routes or routing protocols, so that all of the locations in the intranet are reachable from the remote access server. It also need for security purpose.<SPAN style="LINE-HEIGHT: 115%; FONT-FAMILY: 'Verdana','sans-serif
on Mar 22, 2011 | Microsoft Windows Server 2003 Enterprise...
My computer will not connect to the internet when I hook up to the Linksys wrt150n I don,t understand It because it use to work this is about to drive up the wall I have tried resetting the router but it...
If you can connect to the Internet using the LAN cable then your Internet connection is OK.
If you are trying to connect to the Internet using the wireless connection, then your problem is the wireless settings in either the Linksys or the wireless card in your computer.
First check the wireless settings in the Linksys, ie. the SSID and encryption key.
Second check the wireless settings in the computer's wireless card, this must match the route's wireless settings. If it matched then do a Repair connection. this will get the Linksys to issue a new IP address to the wireless card.computer.
If the Linksys wireless settings were changed then configure the wireless card in the computer with these new settings.
Please click on this link for further diagnostic procedures on network problems :-
http://www.fixya.com/support/r4229966-network_diagnostic_procedures
Nov 03, 2010 | Linksys Wireless-N WRT150N Router
How do you connect a Linksys NH1005 v2 hub and whats the difference between a hub and a router?
A router takes an Internet connection, routes it to several other computers and provides each of these computers with their own IP address.
A Hub, on the other hand, will split the Internet, but the various ports on the hub will all have a single IP address. Makes it hard to use a computer for much of anything, if it is the second computer, you'll have trouble getting access.
Nov 13, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
USING BELKIN F5D7230-4. WEAK SIGNAL TO SECOND
All PCs must be on the same subnet unless you have routes set up! 192.168.2.1 and 192.168.22.xxx are not on the same subnet
Apr 01, 2009 | Belkin (F5D7230-4) Router (587009)
Netopia Router - No Connection, Clicking
Yes, you need to swap the router out.
This is assuming you dont have the netopia in bridge mode with another device behind it.
spin
Jun 26, 2008 | Netopia 3346N-ENT Router (3346NENT)
Windows 2003 server standard edition
You have to enable routing and remote access in win2k server to share your internet connection
Follow these steps
Goto start--> programs-->administrative tools --> routing and remote access
Just click it
In the action menu click add server and select your server in the list
Once routing and remote access is properly installed in the server
Go to the client give gateway address to your server address and any internet DNS server addresses , and you can now acccess the internet
You can also use any internet sharing software , In this case i sujjest to use Sygate Internet sharing software
Good Luck
Jan 27, 2008 | HP Compaq ProLiant ML330e Server
Lap top problem
Wireless network adapters require an associated wireless receiver (such as a wireless router or wireless access point) to recieve the radio signals from the adapter and eventually route them to a wire and in you case it would be the wire providing internet services to your desktop computer. If there is no wireless receiver there is no device to convert the radio communications of the wireless adapter and rout those signals to the internet.
I hope this helps.
Dec 08, 2007 | Computers & Internet
Route 66 sat nav
Had the same problem with my Route 66 mini - Their customer services gave me this link to download some sync software and mine now works a treat
http://www.microsoft.com/windowsmobile/activesync/activesync45.mspx
Regards
Andy b
Dec 07, 2007 | GPS
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
