Question about Samsung HLN467W 46" Rear Projection HDTV
I have a samsung hln467w. when i hit the power button, i hear sound (cant raise or lower it though) but no image. the light on the bottom flashes but eventually the tv cycles off. i called samsung and they had me try a bunch of things, but nothing helped. what's wrong with it? what's the ball park for repairing it?.
  • Samsung Master
  • 6,993 Answers
your TV is having a power problem. The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the TV might not come on.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
I wish you good luck.
Posted on Oct 08, 2010
My Samsung tv turns on but has no sound or picture ... how do i fix that
Some Samsung tv's have a common fault of capacitors breaking down.
Especially the 32" flat screen model.
If you are not happy changing components your self send for an expert.
However, you may look up Samsung TV repairs on Youtube, there are several step by step tutorials there.
Dec 02, 2014 | Samsung PN51D450A2D Plasma TV
Hi I have a Samsung HLN467W, a 46" DLP TV. And after 50-60 minutes, it starts to flicker white, like lightning flashes. But the whole screen is not blank white, it's more like the images are...
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with PartStore.com (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Thanks.
Mar 15, 2011 | Samsung HLN467W 46" Rear Projection HDTV
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Lamp Light on the front is flashing green.
www.pdfee.com/.../Toshiba%20rear%20projection%20training%20manual - United States
www.pdfee.com/search/panasonic+rear+projection+tv - United States
www.scribd.com/.../Hitachi-Training-Manual-Projection-Television-DLP-1 -
Those links should help you understand what's going on. You need to get a service manual, like those supplied, but for your exact make and model.
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=02010300&prd_mdl_cd=&prd_mdl_name=HLN467W
May 07, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Driver side passenger window won't raise back up
It is either the motor of the switch. Operate the switch while listening where the sound is coming from in the door. Then while you are trying to raise the window, hit the interior door panel with some force, not enough to break anything, but hard enough to contact the motor. If it is binding it should allow the window to raise. If it is trying to raise it is probably the motor.
Sep 28, 2009 | 2002 Chevrolet TrailBlazer
Screen goes completely out.
when it blanks out, tuen the lights out in the room, and shine a flash light at the screen, see if you can see the picture, if you can, it is the inverter moard blamking out, thats the board that lights the back lights, if you cant, hit the input button on the remote, if the TV comes back with a picture, it is a problem with the main board, in paticular the componant input on the main board
Jan 10, 2009 | Samsung LN-R268W 26 in. HD-Ready LCD...
Samsung HLN467W Flashing "LAMP" LED
remove the lamp and visually check if inside looks broken.if visually do not see any thing wrong,check if you have 300 volts dc supply on the ballast which starts the lamp.if you do then the ballast may be defective.if you do not then the power supply should be checked.
the lamp should always be tried first especially if is older than two years.
note - be aware about the switch at the door lamp.the door should be closed,otherwise tv will not work.if you remove the back cover,make sure to bypass the switch temporarely so you could work on the set.
Sep 03, 2008 | Samsung HLN467W 46" Rear Projection HDTV
No picture no sound
this is most often caused by a faulty lamp or faulty ballast. try resetting the tv by unplugging and leaving it unplugged for 5-10 minutes or so, plug it back in and check it.
you should be able to find the replacement parts via partstore.com
ballast is part number BP4700017A
lamp is part number
BP9600224A
compatible cheaper lamp part number
BP96-00224ARL
hope this helps,
trin
Nov 19, 2007 | Samsung HLN467W 46" Rear Projection HDTV
White Flashing
DMD Control Module is flaking.
Could be getting hot if the fan has been compromised by dust. Take the back off. Clean everything with a brushy on the vac hose. Tape the cover switch shut and power up. Check for proper fan operation. Both should spin equal and quiet. May be too late for DMD Control board, though.
Oct 30, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Hdtv-dlp has no sound or picture
This sounds like an o-so familar problem. It sounds like the Switching IC or the MICOM has failed
Nov 10, 2006 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HLN467W 46" Rear Projection HDTV Logo
53 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
