Question about Cameras
The film doesnt roll on - Cameras
    Brigadier General:
  • 3,006 Answers
Please state the make and model.
Posted on Oct 08, 2010
Suppose a film roll is said to be useless if at lest 2 defects are found per 80 feet of film roll
dude...really? if it's film for a camera....you need to get digital....I'd say that as for the 2 defect rule....someone has yanked your chain pal. ....
It's 3 defects per 2 inches...If you unroll 80 feet of film meant to be used in a calculator.......a calculator......it must be an MI6 calculator that snaps photos of the user every time he hits the = key......let's say you did unroll 80 feet of film....and you were in a dark room doing it.....there might be a problem rolling the film back up correctly after unrolling 80' of the super 100,000 snap shot roll. Ya think?
Don't take this wrong....it really is a jab to your kidney....
Mar 12, 2015 | Office Equipment & Supplies
Two rolls of film developed at CVS - apparently not exposed???
it is not unknown for film developing sites to with hold good photos so take another practice roll and have it developed somewhere else
That will prove either the camera or the developer
Apr 23, 2017 | Pentax K1000 35mm SLR Camera
Do i need to rewind film after taking a picture on my diana f+ ??
If you are using 120 film (medium format) you only need to advance the film as far as possible. Then remove the film from the camera and wrap the excess paper around the roll and seal.
When you finish all the pictures on the roll of 35mm film you will need to rewind the film completely before exposing it to light. You can do this by taking the camera in a pitch dark room, removing the film and turning the knob on the top of the film roll until the film has been completely wound back into the the roll.
Mar 29, 2011 | Lomo Diana F+ 35mm Film Camera
I don't know how to roll up the film after it's done. I ruined the last one. How do I roll up the film?
There is a crank located on the top of the camera. Some Lomo's Ive seen have it located on the left, but it will always be on the side of the camera where you placed the film. Many cameras will also have arrows indicating what direction to turn it in order to wind the film back in. If there are no arrows, place your ruined roll of film (or a new roll of film) into the camera, and try winding it with the back open (if you're using a new roll of film, don't roll it all the way in, or you'll waste another roll).
If there is no crank, or it is broken, you can always unload your camera in perfect darkness (no red lights), and wind it back into the canister by hand.
Mar 10, 2011 | Lomo Fisheye 35mm Film Camera
Can you tell me how to thread a Graphic III laminator?
5-2 THREADING the LAMINATOR
1. Remove the supply roll mandrels and the feed tray. The supply roll mandrels are now ready to accept
loading of the film rolls, wound with the polyester (shiny) side out. When viewed from the front of the
machine, the core grippers on both the top and bottom supply roll mandrels should point toward the
heat shoes (and toward each other). The tension control knobs should be positioned on the right. Notice the
knobs are labeled "Top Right" and "Bottom Right". If you have rolls of film on which the material is wound
in the opposite direction (adhesive or dull side out) exchange the top and bottom supply roll mandrels so
the core gripper positions are reversed.
2. Slide a roll of film onto the top supply roll mandrel, turning the roll slightly to slide the gripper inside the
core. Center the roll. Make sure the dull side of the film is facing up and the shiny side is facing the
heat shoes during the threading. Scored marks on the supply roll mandrels provide a guide for proper
alignment of the two rolls of film to each other.
NOTE: The pointed metal pieces protruding from the body of the supply roll mandrels grip the cardboard core of the film supply roll to prevent slippage. When placing a roll of film on the mandrel, twist the film supply roll to
accommodate easier film loading.
3. With the roll aligned with the scored line on the right side of the mandrel, place it in the top bracket.
Place the left side of the shaft in its slot first then place the right side of the shaft in its slot, turning it as
needed. FOLLOW THE RECOMMENDED LOADING PROCEDURES CAREFULLY WHEN THREADING
FILM IN THE LAMINATOR. ACCURATE ALIGNMENT OF ROLLS WILL MINIMIZE WASTE AND HELP KEEP
THE LAMINATOR CLEAN.
4. While the machine is still cold, review the threading diagram. With the bottom roll of film centered on
the mandrel and the shiny side facing down, run the film under the bottom idler bar and pull towards
you.
5. Load and thread the top roll of film in the same manner as the bottom roll. Refer to the threading diagram. The
film should run under the silver stabilizer bar and over the front of the top heat shoe. Remember, the shiny
side of the film must always go against the shoe. The dull (adhesive) side must face away from the shoe.
Make sure the two rolls are aligned with each other before going to the next step.
6. Turn machine on and heat to the desired temperature.
7. With both rolls threaded and installed in their respective brackets, unwind enough film from the top roll
to reach the bottom of the bottom heat shoe. Next, unwind enough film from the bottom roll to reach the
top of the top heat shoe.
8. Now drape the film from the bottom roll against the film from the top roll on the top shoe. If the laminator is
hot, the exposed adhesive on the top web will hold the bottom web and make it easy to stick the two rolls
together. If you are threading the machine while it is cold, use tape to stick the bottom web against the top
web.
9. Tip the safety shield down into the laminating position. With the film draped over the two heat shoes, push
one edge of the threading card between the heat shoes so that the film is firmly positioned against the
laminating rollers. If a threading card is not available, any piece of card stock or poster board will work.
10. Make sure there is still enough slack in the web. Turn the drive switch to FORWARD, permitting the film and
feed board to pass through both sets of rubber rollers. Carefully monitor initial threading to be sure the web
reaches and passes through the pull (back) rollers. When the threading card has cleared the back of the
machine, move the drive switch to the center position (off). Whenever you want to remove the film and/or
laminated material from the back of the machine, use the zippy cutting tool provided with the laminator.
11. Slide the feed tray into position.
12. If the machine has the slitter option, make sure the slitters are disengaged (blades in the raise
position) and moved all the way to either side of the machine.
CAUTION: The laminator is designed to be run with the operator directly facing the
control panel and feed tray, not at an angle or from the side of the machine. For
operator safety, the safety shield must be in position over the upper heat shoe
when the machine is ON, or when the drive switch is in the forward position.
Dec 21, 2010 | Office Equipment & Supplies
Why is the film automatically rewinding around 15 shots instead of the end of the 24 shot roll? The batteries are fresh.
the roll sensor is not reading the silver code on the film roll.
Open the camera when you have no film in it.
Clean the film roll slot where the "fingers" are.
These fingers touch the case of the film roll to determine the film type, which includes the number of exposures. You nmay have to "adjust" the fingers so that they make good contact with the film roll case.
Look at different rolls of film, notice the silver blocks are different. If the roll has a "dent" on it, it can't be sensed correctly.
Hope this helps!
Sep 15, 2009 | Canon Sure Shot Classic 120 35mm Point and...
I may have loaded film roll that has already been taken?
Usually when you finish exposing a roll of film, you rewind it until you are sure it is all wound into the cassette. There is a change in the sound as the end of the roll leaves the camera. An exposed roll would have no film sticking out of the cassette. A new unexposed roll will have a bit of film sticking out of the cassette to pull across the ack to the take up roll.
May 26, 2009 | Canon Elph LT APS Point and Shoot Camera
Film doesn't "snap" into place in film compartment - Olympus is-1
You have a broken spring in the film holding end. I would get it repaired so the roll of film doesn't pop out of place and ruin the whole roll or damage the shutter.
Jan 30, 2009 | Photography
Film will not load
Took out the battery, then put it back in. The film then loaded properly.
Jul 21, 2008 | Kodak Vivitar KV270 Film Camera
Cameras Logo
12 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
