Question about Toshiba Satellite M35X-S163 Notebook
I have Toshiba satellite M35X-S163 when press power cpu fan start and hdd run for 2-3 seconds then gose off nothing on the screen internal or external ; in addition no battary charging . battary and the charger are ok ; please help thank you .
  • 393 Answers
In the pic that is not m35x that is m30 ... if u have m35x ...and no display open the laptop near the power jack there is maxiam ic ... jsut heat that ic.. hope that will work .. if not let me know thanks
Posted on Oct 08, 2010
SOURCE:
Missing windows 7 drivers?
FREE - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1039005&rpn=PSA72U&modelFilter=M35X-S163&selCategory=2756709&selFamily=1073768663
BRITISH $9.95 http://www.user-guides.co.uk/os/Toshiba-Satellite-M35X-S163/#ToshibaSatellite-M35X-S163win7driverdisk
Sep 20, 2012 | Toshiba Satellite M35X-S163 Notebook
I have a Toshiba-M35X-S163 lapyop which worked fine for years, now when I try to boot up, the hdd light comes on, the fan turns on, but after 2-3 seconds, the computer shuts down. The battery, power supply...
Hi having hard time with your Toshiba laptop conserning your HD.
let me help you.... First wile you turn on your laptop press and old F8 Key then on the screen choose safe mode that will start your laptop on safe mode., to perform a disk cleanup... Also check your bios battery see if it dead.. again you re start your laptop this time you press and hold F1 or F2 key that bring you on the bios of your laptop., now look carefully in your bios .. press on default setup that will reset your bios for now.. then restart your laptop
then at the begining it will ask you wich mode you want ...then chose last good start.. If that solution dont work ..Then you may have to re install your windows again in your laptop, due to missing file in your startup windows., To install a new window,, again.. insert a valid windows with a serial key into your laptop.. wile your start your laptop press and hold F12 then wait for instruction...
good luck
Oct 20, 2010 | Toshiba Satellite M35X-S163 Notebook
I cant find audio driver for m35x-s163
http://www.drivershq.com/Drivers/TOSHIBA/SATELLITE/M35X-S163/4183/9941/10772/44239/ModelDrivers.aspx
Aug 23, 2010 | Toshiba Satellite M35X-S163 Notebook
My toshiba m35x-s161laptop has issues
may be the procesor unit(cpu) is too bot because a dust.....
Mar 06, 2010 | Toshiba Satellite M35X-S161 Notebook
My Toshiba Satellite m35x-s163 needs a dvd driver.
I don't know If I'd trust the site totally. It's a little fishy, but judge for yourself: http://www.driversupdated.com/exact/toshiba.php
Jun 09, 2009 | Toshiba Satellite M35X-S163 Notebook
My usb flashdrive is not recognized on any of my usb ports on my Toshiba satellite m35x-s163, can you help?
Test usb port with another device,
check in my computer for the drive,
Test usb flash in another Pc,
Manufacturers website for a possible driver.
if still not working then it's faulty,
Regards
Rpf
Apr 14, 2009 | Toshiba Satellite M35X-S163 Notebook
Is the cpu in a toshiba satelitte m35x-s163 laptop upgradeable ?
hi
You need to check if the model of your motherboard and the specs, that will tell you if you can.
Good Luck
Mar 27, 2009 | Toshiba Satellite M35X-S163 Notebook
Toshiba Satellite M35X-S163 wont start
send me ur email and I'll send u software to repair hard disk.
it seems your hd has bad sectors.try to install new copy first(xp)may give you more insight.
many reasons for no screen from worse case scenario proccessor fried to damaged hd.
Feb 03, 2009 | Toshiba Satellite M35X-S163 Notebook
Need to replace toshiba satellite m35x-s163 fan
Unless you are really comfortable with opening laptops to upgrade parts, I won't recommend doing this. Rather get a notebook cooler. It does the job of cooling the notebook pretty well.
Nov 05, 2008 | Toshiba Satellite M35X-S349 Notebook
Toshiba laptop wont boot up
It sounds more like your power supply isn't charging the battery.
I would first check to see if the power supply is working properly (you can do this with a regular volt/amp meter, or by taking to your local electronic repair shop). If the power supply turns out to be ok, then next have your battery tested, even new batteries sometimes go dud.
These are both inexpensive (if not free) things to check before you just throw it away or get into a motherboard/processor.
Let me know if this works or not.
Mar 27, 2008 | Toshiba Satellite M35X-S163 Notebook
Toshiba Satellite M35X-S163 Notebook Logo
204 people viewed this question
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
