Question about HP Pavilion 8860 (P2941A) PC Desktop
Blank screen i have power the disk drives open and close its reading the mouse but not the keyboard if i unplug the monitor it turns in and says no signal detected when i plug it in the screen goes blank and the light goes from green to yellow
  • 1 more comment
  • Agugua  Lims
    Agugua Lims May 11, 2010
    the problem might be from the cable of yr monitor so try using a diff monitor for yr system if it works then yr cable may be bad or possible the monitor itself. its possible
  • Jonathan
    Jonathan Apr 09, 2014
    I'm having a similar problem where I plug the computer into the wall, it turns on, it shows me the startup, but after the windows logo, the monitor goes into standby and displays no image. I get a message saying that there is no source detected.
  • Christophe Thompson
    Christophe Thompson Apr 09, 2014
    Video card went out on ya its mother board video card it means attached to mother board or your screen finnally took a dump these are majors in screen going yellow on the button
    Genius:
  • 1,224 Answers
Was it working before
check all your cables and lines make sure a pet didnt get behind there also if you have kids make sure they didnt put liquid into your comp
cause if it was sounds like you got hit by a virus that effects all major compartments of comp
green to yellow is standby mode
Posted on May 30, 2008
  • 2 more comments
  • Jonathan
    Do a safe mode reboot and do a restore from a week ago then once working down load for free kapersky virus scanner you been hit by a video bug safemode is f8 or run from disk
  • Jonathan
    Jonathan Apr 23, 2014
    I found out the problem... no virus, I just had to find a video displaying device that had a s-cable connection.
    Christophe Thompson Apr 23, 2014
    The S cable shouldnt effect functions of comp it should improve it your video card was not updated from the sounds of old software
Blank screen when Gateway GM5664 turned on
How do you know your mouse and keyboard work if you have a blank screen?
What motherboard did you put in it? Did you install a video card or using a built in video card? How many beeps? Do you have a spare video card to put in the system and try that?
Feb 19, 2013 | Gateway GM5664 Desktop PC
Blank screen with blinking cursor on Dell desktop
First step is to make sure that nothing is plugged into the computer except a power cord, keyboard, monitor, and mouse. If it still does it, even unplug the mouse, because a mouse going bad can easily cause what you describe. If it still does it, try a different keyboard.make absolutely sure that nothing else is plugged into the computer.
Feb 01, 2012 | Dell Computers & Internet
I have an LG 21" monitor. The screen went blank
Without the model number, it is not possible to research this issue. However... My first suspect would be with the software driver. Some system settings do not like to be oscillated too quickly. (I.E.Going in and out of sleep mode for the computer too quickly, or to and from power save for the monitor too rapidly.) This was a problem especially for older versions of windows. (Vista and prior.) Increase power-save to more than 5-10 mins, and check for driver updates. Being that you were able to get it running without unplugging or turning off the monitor, I do not believe it is a monitor issue. (Outside of the RARE possibility of a hardware or firmware conflict between the monitor and video card/chip set.)
Sep 19, 2011 | LG 22" FLATRON LCD Monitor
My LG Flatron W2453SQ monitor is connected to my laptop. Since two days ago, when I dont touch the keyboard/mouse for 30 secs the monitor goes blank and enteres power saving mode. I have chyecked the cable...
HI kissakiwi,
In the control panel's power option , you need to change the SYTEM STANDBY settings to never , and then the problem would be solved.
There are three options , turn of monitor, turn of hard disk and , system standby , if you select all of these three to 'never' then you won't have this problem.
Remember you can also change the settings via the screen saver tab when you right click and select properties on the desktop.
Let me know in case you have any queries. Hope this helps ...:)
Jul 01, 2011 | LG 22" FLATRON LCD Monitor
Power on but dead screen just blank and black
Unplug all periphials from the computer with the exception of keyboard, mouse, and monitor. If it does not power on at all it's time to look for a new machine.
Mar 02, 2011 | Computers & Internet
We have a Benq FP767. when we start the moniter than the screen appear blank and blinking LED light near on/off switch. what i do?
Have you attempted to enter the on-screen menu system for the monitor? There should be a reset system reset option somewhere in the menu selections. If not give that a try.
Also you might want to check your monitor cable. Unplug then replug it in. If you still have a blank screen you might want to try the cable on another monitor if that's possible.
If the cable is not the problem then that leaves the monitor itself or the video card if your system is equipped with one. Check the back connectors and locate the video output plug. If it is located close to the keyboard, mouse, Ethernet and usb plugs it is what's known as on-board video. If it is located below those other plugs it is a video card. Shut your system off and disconnect the power cable. Open up your case and make sure that the video card is seated correctly. They can come loose.
Your only other option is to try your monitor on another system.
I really hope something here helps. Good luck
Dec 29, 2009 | BenQ FP767 17" LCD Monitor
Hp pavilion a705w. no peripheral response
The fact is *********** board is very likely the matter. See all devices that do not need the motherboard to respond are all working (cd/dvd tray opens and closes, fans are on etc). On the other hand all devices that need the motherboard to respond are not working (keyboard, optical mouse, etc). It is more or less conclusive.
Dec 04, 2009 | Computers & Internet
Black screen
Sounds like your screen is being switched to "Power Save" mode due to inactivity. This should switch back when the mouse is moved. This can take several seconds on a laptop. You can remove this "Power Save" by right clicking anywhere on blank desktop, select "Properties", "Screen Saver" and "Power Settings" then select "Always On" for the monitor.
Sep 13, 2009 | Toshiba TECRA 8000 13.3" TFT LCD Display...
Trubleshoot Motherboard
More than 70% of all computer problems are related to cabling and connections. Ensure all cables are connected and connected firmly. IDE and floppy ribbon cables and power cables can often go loose. Ensure microprocessor, memory modules, and adapters such as video card are inserted correctly and didn't "pop-up" due to vibration.
System has no power at all. Power light does not illuminate, fan inside the power supply does not turn on, and indicator light on keyboard does not turn on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Power cable is unplugged. Visually inspect power cable. Make sure power cable is securely plugged in.
Defective power cable. Visual inspection, try another cable. Replace cable.
Power supply failure. Power cable and wall socket are OK, but system is still dead. Contact technical support
Faulty wall outlet;circuit breaker or fuse blown. Plug device into socket know to work and test. Use different socket, repair outlet, reset circuit breaker or replace fuse.
System inoperative. Keyboard lights are on, power indicator lights are lit, and hard drive is spinning. PROBABLE CAUSE DIAGNOSIS SOLUTION
Expansion card is partially dislodged from expansion slot on the motherboard. Turn off computer. Take cover off system unit.
Check all expansion cards to ensure they are securely seated in slots. Using even pressure on both ends of the expansion card, press down firmly on expansion card.
Defective floppy disk drive or tape drive. Turn system off.
Disconnect the cables from one of the floppy drives. Turn on the system, check to see if the keyboard operates normally. Repeat until you have located defective unit. Contact Technical Support.
Defective expansion card. Turn computer off.
Remove an expansion card. Make sure expansion card is secure in expansion socket.
System does not boot from hard disk drive, can be booted from floppy disk drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Connector between hard drive and system board unplugged. When attempting to run the FDISK utility described in the HARD DISK section of the manual you get a message, INVALID DRIVE SPECIFICATION. Check cable running form disk to disk controller on the board. Make sure both ends are securely plugged in; check the drive type in the Standard CMOS Setup (in your motherboard manual).
Damaged Hard Disk or Disk Controller. Format hard disk; if unable to do so, the hard disk may be defective. Contact Technical Support.
Hard Disk directory or FAT is scrambled. Run the FDISK program, format the hard drive(See HARD DRIVE section of manual). Copy your backup data back onto hard drive. Backing up the hard drive is extremely important. All Hard Disks are capable of breaking down at any time.
System only boots from Floppy Disk. Hard Disk can be read and applications can be used, but booting from Hard Disk is impossible. PROBABLE CAUSE DIAGNOSIS SOLUTION
Hard Disk boot program has been destroyed. A number of causes could be behind this. Back up data and applications files.
Reformat the Hard Drive as described in the Hard Drive section of the manual. Re-install applications and data using backup disks.
Error message reading "SECTOR NOT FOUND" or other error messages indication certain data is not allowed to be retrieved. PROBABLE CAUSE DIAGNOSIS SOLUTION
A number of causes could be behind this. Use a file by file backup instead of an image backup to backup the Hard Disk. Back up any salvageable data. Then do a low level format, partition, and high level format of the hard drive( see Hard Disk section of your manual for instructions). Re-install all saved data when completed.
Disk formatted on IBM PS/2 will not operate with this system. PROBABLE CAUSE DIAGNOSIS SOLUTION
The IBM PS/2 uses a different format than other computers. IBM PS/2 disk format will not work in an AT type computer. Format disk in the AT type computer insert disk into the IBM PS/2 and copy the files you wish.
After install an expansion card (network card, tape drive card, etc.) the system no longer works properly. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. All or part of the system may be inoperable. The new card may work but a mouse or COM port may not work. Change the interrupt or RAM address on the new expansion card. See the documentation that came with the new card in order to change pin settings. many expansion devices come with proprietary software that will assist you in doing this.
Screen message says "Invalid Configuration" or "CMOS Failure." PROBABLE CAUSE DIAGNOSIS SOLUTION
Incorrect information entered into the configuration (setup) program. Check the configuration program. Replace any incorrect information. Review system's equipment. Make sure correct information is in setup.
Screen is blank. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. Power connectors may be loose or not plugged in. Check the power connectors to monitor and to system. Make sure monitor is connected to display card, change I/O address on network card if applicable.
Monitor not connected to computer. See instructions above.
Network card I/O address conflict. See instructions above.
Problem PROBABLE CAUSE DIAGNOSIS SOLUTION
Memory problem, display card jumpers not set correctly. Reboot computer. Re-install memory, make sure that all memory modules are installed in correct sockets. Check jumper and switch settings on display card. See display card section for information of settings.
Computer virus. Use anti-virus programs (McAfee/PC-cillin, E-port, etc) to detect and clean viruses.
Screen goes blank periodically. PROBABLE CAUSE DIAGNOSIS SOLUTION
Screen saver is enabled. Disable screen saver.
Keyboard failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is disconnected. Reconnect keyboard. Check keys again, if no improvement, replace keyboard.
No color on screen. PROBABLE CAUSE DIAGNOSIS SOLUTION
Faulty Monitor. If possible, connect monitor to another system. If no color, replace monitor.
CMOS incorrectly set up. Call technical support.
Floppy drive lights stays on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Floppy Drive cable not connected correctly. Reconnect floppy cable making sure PIN1 on the Floppy Drive corresponds with PIN1 on floppy cable connector.
Error reading drive A: PROBABLE CAUSE DIAGNOSIS SOLUTION
Bad floppy disk. Try new floppy disk.
Floppy disk not formatted Format floppy disk(type ENTER)
C: drive failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
SETUP program does not have correct information. Boot from drive A: using DOS system disk. Input correct information to SETUP program.
Hard Drive cable not connected properly. Check Hard drive cable.
Cannot boot system after installing second hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Master/Slave jumpers not set correctly. Set master /Slave jumpers correctly.
Hard Drives not compatible / different manufacturers. Run SETUP program and select correct drive types. Call drive manufactures for compatibility with other drives.
Missing operating system on hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
CMOS setup has been changed. Run setup and select correct drive type.
Certain keys do not function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keys jammed or defective. Replace keyboard.
Keyboard is locked, no keys function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is locked. Unlock keyboard
If a problem persists, please search for a solution or post a question in our tech support forum in our Help Desk.
Oct 19, 2008 | Computers & Internet
Blank screen and no lights on keyboard and mouse
*check the power cables
*check the power outlet
*check smps is fine
*check power switches are properly connected
*check in bios hdd is enabled
*open the case wheather the connections are properly connected
Jun 27, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
HP Pavilion 8860 (P2941A) PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
