Question about Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Professional series - stainless Start the cycle and it seems normal, clock ticks down but a few minutes in, it engages in the "wasH' cycle (seems to have filled some water in the tub at this point which is hot) and does nothing.... the timer just ticks away.... thoughts?
  • jeremy_gordo Oct 09, 2010
    well the water level sensor seems to move freely, what can i do to check the switch?
  • Frigidaire Master
  • 3,247 Answers
Is it please possible to provide the model number of your dishwasher.
When you say water in the tub is hot, is it because the dishwasher is connected to the hot water inlet connection? Do you hear the drain pump at any time trying to run?
Posted on Oct 09, 2010
  • 11,896 Answers
Could be the water level sensor if the machine is not filling up enough it won't engage. Or if the door switch is bad it won't start washing. if water is hot, that is a good start
Posted on Oct 08, 2010
  • Nate Stansfield
    Nate Stansfield Oct 10, 2010
    You can take the wires off the switch. Then use an ohmmeter and put it on the rx1 setting. Then place a probe on each connector of the switch. You should have a high reading with the swich in and no reading with the switch out.
Moffat washer (mcch6110hww GE?) trips breaker shortly after start of cycle. Can this be repaired?
Sounds like your drum brake is engaging. Fixing it is fairly cheap. YouTube it and watch a few videos on how to do it if your fairly handy.
Feb 01, 2013 | Washing Machines
The blue indicator light will no longer come on at the end of the cylce
Hello Loucinda Stanley - Try resetting the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. Select a normal cycle let it run and then the indicator light should display at the end of the cycle. If it proves to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues.
Jan 16, 2013 | Electrolux 24 in. EDW5500DSS Stainless...
Front loader won't start on certain cycles
Hello sidneyskiss - From what you have described if only the normal cycle is working, then there seems to be a communication problem coming from the main control board or wiring failure. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart washer. If it proves to be ineffective, I would suggest contacting a professional technician to move forward accurately.
Jan 08, 2013 | Frigidaire GLTF2940ES Front Load Washer
The normal and economy lights are blinking and cannot get to wash through a full cycle. water is in the bottom of the washer
You will have to check if the dishwasher is stuck in the drain cycle or wash cycle.
The normal and economy lights flashing means there is flooding in the unit.
Reset the unit by pressing START button for 4 secs. If the flashing does not stop then you have to call the technician. There may be a leakage which is causing the flood switch to activate.
May 21, 2011 | Viking 24 in. Professional Series VUD040...
GE Profile WPRE6100G Top Load Washer My washer is 2 yrs old and has started to make a loud metalic banging noise during the wash cycle. It does not during the spin cycle. Doesn't seem to matter whether...
Hi!!
The "Metallic banging/clicking" sound you hear is the Shifter mechanism engaging or disengaging.
The drive system will engage at the start of the Agitate Cycle and disengage when the Agitate Cycle is complete. This occurs multiple times during the wash. GE claims this is a normal sound and should not be concerned about it. Check page 10 of your Operating Manual, if you do not have a manual, click on this link to download one http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90323.PDF
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 03, 2010 | GE Profile WPRE6100G Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Cycles improperly
hi there,
please let me know the make and full model # off your d/w.
thanks
Mar 26, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
76 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
