Question about Dymo LetraTAG Thermal Label Printer
WHAT DOES IT MEAN WHEN THE DISPLAY JUST SHOWS BLINKING EXCLAMATION MARKS. AND IT WILL NOT PRINT
3 Suggested Answers
SOURCE: Not printing at all. Screen appears as series of exclamation marks
I had the same problem with my label marker. Changing the batteries fixed the problem
Posted on Jun 28, 2008
This is probably due to a broken nylon pinion gear, the one which meshes with the capstan drive motor. Due to poor design, the gear is only marginally heavy enough to stand the strain of being press-fit onto the shaft that runs through it. The failure mode is that the gear splits along one of the seams between the teeth and then simply spins on the shaft. This appears to be a common problem with the LabelManager 300, which is really too bad because the printer is otherwise an excellent machine. Anyway--
Replacement parts are not available, and the design is a ***** to repair but it can be done. The short story on the repair trick is to:  1. unscrew the two fasteners (one near the print head accessed from the front and one accessed from the rear once the back is off the unit) that hold in the motor and gear assembly, 2. pull off the motor worm gear 3. unclip and push motor back
4. remove the mating gear/shaft assembly by extracting the shaft running through (broken) mating pinion gear and associated 2nd stage worm gear 5. clean gears and shaft with pure iso alchohol 6. drill out split pinion gear with #47 (.078") bit 7. superglue pinion gear back onto shaft, centered on spline (i.e. where it was before). Use pliers or clamp to hold gear snugly against shaft for 12 sec or so while glue sets 8. press fit 2nd stage worm gear back on the other end of the shaft (again, centered on spline where it was in the original assembly) 9. modify motor assembly plastic baseplate by cutting narrow "V" **** in plastic "tunnel" that shaft previously went through, so that shaft can be pressed into place without disassembly/reassembly of gears. This is the trick... 10. when shaft assembly is back in place, reassemble worm gear onto motor shaft and press motor back into position. Worm gear should now mate with pinion gear on shaft assembly and the motor shaft should be readily turnable with fingers. 11. reassemble motor/gear assembly onto label printer metal baseplate and test.
Be certain, for Step 7, that the gear and shaft mating surfaces are grease-free and use a good-quality superglue. Epoxy does not work for this repair!!
Have fun and good luck. crd
Posted on Aug 07, 2008
What does the symbol !! mean at the end of a sentence
The exclamation mark (British English and Commonwealth English) or exclamation point (American English) is a punctuation mark usually used after an interjection or exclamation to indicate strong feelings or high volume (shouting), and often marks the end of a sentence. Example: "Watch out!" Similarly, a bare exclamation mark (with nothing before or after) is often used in warning signs.
Nov 26, 2016 | Cars & Trucks
What does it mean when you're printers exclamation mark is blinking
Many things.Maybe there is toner/ink cartridge problem, paper jam, electrical problem and many more. If you tell us what is the model of your printer and is this blinking is repeating .
Jul 13, 2012 | HP Office Equipment & Supplies
My dell 1710 cant print it keeps showing or blinking " !" sign
http://support.dell.com/support/edocs/systems/1710n/en/om/1710_en.pdf
There is a link to your printers manual that includes troubleshooting error codes. The blinking exclamation point means that the printers cover is not closed all the way. If there are any other pictures on the printers display that are also blinking like an ink drop or a sun then it can mean something else.
Oct 14, 2011 | Dell 1710 Laser Printer
My printer dell 1710 has bee blinking "!" and
Please take a good look at the front of your printer and make sure that the only thing blinking is the exclamation point. If it is then it means that the cover to your printer is not closed all the way. Try opening and closing the printer to cancel this error.
If there is a picture of a sun, an ink droplet or anything else along with the blinking exclamation point then the error can mean different things.
The printer cant print it keeps showing "!" or
The blinking exclamation point means that the cover to the printer is not closed all the way. Try opening and closing the cover to get rid of this error. If there is another picture like an ink drop or a sun that is also blinking at the same time then the error can mean something different.
Here is a link to your manual for your printer that includes troubleshooting erorr codes:
Oct 14, 2011 | Dell 1710n Laser Printer
What does the button on the the 1320n that has a triangle with an exclamation mark mean? The light next to it is blinking and we don't have a manual.
Attention light is blinking
This state can be reached in the following circumstances:
? Paper tray is empty
? Door open
? Paper jam
? Misfeed from tray
1. Verify that the print cartridge is present and that the print-cartridge door is closed correctly.
2. Verify that media is present in the input tray.
3. Clear any jams and perform paper-path functional checks.
4. Make sure that the interlocks are operating correctly.
To reset the printer after a jam, press the GO button.(Green Button)
Sep 21, 2011 | HP LaserJet 1320n Printer
What does the (!) symbol mean on the dash? I looked in manual but just says tire issue? I have a 2010 Corolla
It is a sign of exclamation.
An exclamation mark, exclamation point, shout pole, or bang (!) is a punctuation mark usually used after an interjection or exclamation to indicate strong feelings or high volume, and often marks the end of a sentence.
Dec 15, 2010 | Microsoft Office 2010
My Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
May 22, 2009 | Dell 962 Photo All-In-One InkJet Printer
The blinking light
Hi, The problem your having with the two circles and the squiggly line mean you have a paper jam. Hope this helps!!!!
Dec 05, 2007 | HP LaserJet P2015dn Printer
Dymo LetraTAG Thermal Label Printer Logo
109 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
