Question about Hotpoint WMA58 Front Load Washer
The hot water pipe dont shut off and the machine keeps filling up with water
  • Hotpoint Master
  • 3,463 Answers
You need to replace the hot water inlret alve.
Posted on Oct 08, 2010
Water keeps filling
if it's filling all the time with the machine electrical supply turned off the problem is the water supply solenoid valve is faulty could be hot or cold solenoid,
if it's constantly filling with the machine switched on it's possible the water pressure switch that is faulty or more than lickly the small rubber pipe that connected to it ,is blocked find it disconnect pipe blow down pipe to clear ,replace test not forgetting to disconnect electrical supply before removing any covers.
Nov 13, 2016 | Washing Machines
Drum fill with water
If your machine outlet pipe is connected to the sink trap (many are these days) it could simply be that water from the sink is draining into the washer if it is connected like this ensure that where the outlet pipe leaves the the trap it goes up and does not run level or down if the water in the is dirty this is the problem failing this water vavles are passing water when the machine is off
Mar 03, 2014 | Whirlpool 3.5 Cu. Ft. White Front Load...
Hot water barely comes out,
If you switched the feed hoses over and the problem reversed itself, cold has gone from fast to slow useing the hot water pipe and hot from slow to fast useing the cold water pipe then this would indicate a fault in the water supply from the hot pipe. What sort of pressure is coming from the hot pipe when not connected to the machine but filling in to a bucket? Are there any shut off valves before the pipe that supplies the hot water? Are they fully turned on? Any kinks in the feed pipe for the hot water? Has the hot water feed pipe collapsed internally? Change the pipe to check this and not just at the machine side.
Dec 31, 2012 | GE Spacemaker Washer and Dryer Electric...
Will not fill with hot or cold water and is connected
You need good water pressure on hot for these machines to work, gravity fed systems may not be enough. I had to attach a pump to mine to improve the hot water pressure (UK)
Switch over the inlet pipes ie hot to cold and cold to hot and try filling the machine when switched to fill with hot water, (machine will fill will cold). proving the valve is opening and it is a pressure issue on you hot water.
Nov 29, 2010 | Admiral AW22 Top Load Washer
Whirlpool top load washer makes noise on filling
Its mainly caused by back pressure when the inlet valve suddenly shuts off the water to the machine. The pressure causes your plumbing pipe work to shake inside the walls.
You can turn down the pressure by closing your water tap and only having it slightly open. Or you can get pressure limiters which join on the hose.
Regards
Ash
Oct 26, 2009 | Whirlpool Washing Machines
I have a hot point aquarius wf321 and it wont come out of the last spin cycle it just keeps filling up with water and keeps going been doing this for the last 8 hours
it may be sucked out by siphoning through your sewer pipe .Probably a siphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from coming out the drain pipe , go to home depot or an appliance parts house , and get a siphon break . When a washer fills , but water level doesn't rise in the machine , it must be going down the drain
Aug 25, 2009 | Washing Machines
Drum is filling with water after each wash
There is only 2 possibilities for the drum to fill with water after it has finished.
Firstly, if the empty pipe is connected to the sink outlet pipe, the water can syphon back into the washer if the pipe is too low, thereby slowly filling the washer when not in use.
Solution is to lift the outlet pipe higher.than the bottom of the sink.
The other reason is the inlet valve is not shutting off properly.
To prove if this is the case, turn the water off at the valve, if it is hot and cold fill, then turn the hot off only, and wait and see if water comes in over a period of time, if it does not then you need to replace the hot valve.
If water stills comes in with hot turned off, then you need to replace the cold valve.
If cold fill only , turn off cold and wait to see if any water comes in, if it does not, then replace cold valve.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Washing Machines
WASHER WON`T FILL FULLY WITHOUT RE OPENING TOPLID SEVERAL TIMES?
water valve should be a single unit consisting of a hot and cold solinoid assembly. This whole valve assembly should be replaced.
Jul 20, 2008 | Washing Machines
Water will not shut off
Usually there is a thin pipe from the bottom of the drum to a pressure switch at the top of the machine. As the machine fills the water goes up the pipe from the drum and increases the air pressure in the pipe to a point where it's enough to switch the switch inside. If the pipe gets blocked with washing powder it will not switch off and the machine will keep filling. The pipe is connected to a sort of flat round box with a few wires on it. If you can take the top or back off the machine you should see it and be able to clean the pipe out yourself.
Jun 26, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Hotpoint WMA58 Front Load Washer Logo
35 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
