Question about Toshiba Satellite L305D-S5881 Notebook
I have a Cy27 model laptop. Since I redid it - when I start the computer up it will not turn the wireless on. I have to manually push the wirless button once it is booted up to get the wireless to activate. Is there something in the bios or a command missing that is making it function this way now? I have looked online to no avail to find a soultion.
sandrew
  • 2961 Answers
SOURCE: Motherboard, processor or other??
the two issues you mention, the first, no cmos battery fitted, why not?, there should always be a cr2032 cmos battery fited as this is how all the settings for your initial P.O.S.T and all saved bios settings are saved so as to boot into windows, so you must have the battery in, thats why there is a problem with thepower settings, again because the motherboard needs the settings to know what to start looking for. Secondly i would say that there is a driver issue, either with any peripheral that may be connected via usb or because of a motherboard driver problem with the network connector on the motherboard, so check all your drivers.
Posted on Jul 13, 2007
yourpc
  • 190 Answers
SOURCE: Toshiba M45-S165 startup issues
This is normally a motherboard issue. I had one with the same symptoms and I had to replace the motherboard. Worked great after the board was replaced. I had to replace the board because unlike your issue mine stopped working all together. It did take a while before it quit though. Just a note: I have had to replace several of these motherboards for customers as well. If your LCD is broken, you may be better off to save your data and put it in a new laptop that would include a warranty unless your super fond of the machine or you have access to inexpensive parts.
Hope this helps...
Posted on Feb 15, 2009
SOURCE: looking for wireless on switch on laptop
Right Side, underneath your volume control. If it is switched on and still cant access the internet wireless give this a try.
Use Control Panel's Add or Remove Programs utility to uninstall the Toshiba Hotkey Utility, and then reinstall it.
This program is called E-Key Utility on the Toshiba Satellite M30X/M35X Recovery and Applications/Drivers DVD. It's called Toshiba E-Key Utility for Windows XP on the Toshiba Support website.
Unistalling the Toshiba Hotkey Utility:
  1. Click Start.
  2. Click Control Panel.
  3. Double-click Add or Remove Programs.
  4. Select TOSHIBA Hotkey Utility.
  5. Click Change/Remove.
  6. Click OK to confirm that you wish to completely remove the selected application and its features. The InstallShield Wizard will begin the removal process.
  7. Click Finish to exit the InstallShield Wizard.
Re-installing the Toshiba Hotkey Utility using the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD that shipped with the computer:
  1. Insert the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD into the CD/DVD drive and close the tray. The setup program on the DVD should start automatically.
  2. When the Toshiba Recovery and Applications CD window appears, verify that "Install applications and drivers" is the selected install type, and click Next.
  3. Select E-key Utility from the list, and click Install.
  4. When the WinZip Self-Extractor window appears, click OK.
  5. Click Unzip.
  6. Click OK to acknowledge that the files were successfully unzipped.
  7. When the InstallShield window appears, click Next and follow the prompts to complete the installation.
  8. When the installation is complete, click Exit and then OK to close the Toshiba Recovery and Applications CD window.
  9. Remove the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD from the optical drive and close the tray.
Reinstalling the Toshiba Hotkey Utility using the file downloaded from the Toshiba Support website:
  1. Download the Toshiba E-key Utility for Windows XP from the Toshiba Support website, and save it to your computer. See also the bulletin Obtaining downloads and support docs from the Toshiba Support website.
  2. Navigate to where you saved the file and double-click it.
  3. Click Run.
  5. Click Unzip.
Posted on Feb 22, 2009
hacker8499
  • 74 Answers
SOURCE: Limited or no conectivity. Can't get signal.
check your network provider and the set up of your modem router.
Posted on Oct 05, 2009
  • 236 Answers
SOURCE: I have a Toshiba A75-S2112
The computer starts but, when you press a key, nothing happens.
You are probably in Standby mode and have a software or
resource conflict. When this happens, turning the power on
returns you to the problem instead of restarting the system.
To clear the condition, press Ctrl, Alt, and Del simultaneously
then select Shutdown, then Restart to restart the computer.
Posted on Mar 25, 2011
Gateway user manuals
Make sure that the wireless is turned on. Some have a switch on the unit, others If you would have listed the model number, I could have provided a better answer. Good luck.
Jan 06, 2014 | Computers & Internet
How to enable Wirless in VPCEB35FX/WI ?
push the wireless button on your laptop probaly near the power button
Jun 01, 2011 | Sony VAIO VPCEB35FX/WI notebook PC
Dell Latitude E5500 says wireless is on and working but when I go to the internet it says its not...?
switch wireless off using the function and wirless symbol button restart computer and turn wirless back on, then reconnect to wireless network. and open your browser, if this doesnt work post exact error message and operating system
Feb 20, 2011 | Dell Computers & Internet
I have a laptop computer, and a wirless no internet
your internet gateway (the modem)if you have att you must turn on the the wireless inside your 17XXhg gateway modem if you don't then you have another system I gave you a example to clear your question if you need more help please repost with more information
Jan 14, 2010 | Computers & Internet
Wireless Router not working
Try turning off your wireless connection, wait a few minutes, then turn it back on to see if you connect to it. Also, if you're using another wireless utility to connect to the router other than the base Windows Wireless Utility, they may be interfering with each other and one may need to be turned off.
I hope this helps.
Oct 17, 2009 | Computers & Internet
For wirless drivers
Go to the HP website, and go to their software/ drivers update page. There should be a search box on that page. Entr your computer information, such as your model...etc....All of the drivers for your specific comouter should come up, and from there you can download/ install any drives that you need and/or any that need to be updated. You can also try to take out your wireless card, if internal. Then wait about 20 seconds, and put it back in. Do this while your computer is shut down and turned off of course. After you have placed it back in and securely reconnected it, turn your computer back on. Your computer should automatically search and detect the drivers. Try this first, and if that doesn't work, Then go to yout computer manufacturer's website and sach, download, and install your needed wireless drivers. Hope this helps.
Sep 05, 2008 | Dell Inspiron™ E1505 PC Notebook
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Wirless internet
we'll need a bit more information on the model number to help you out..
Mar 25, 2008 | NEC Versa LX Notebook
Karen
Would you be Please More Specific about you laptop.
what brand and what model is your laptop. if it says it came with the wireless card. that is built in. there should be a model for that wireless card. if there is one you will need to turn it on from the laptop. there should be a switch on or around the side of the laptop. if you need more guidance. do not hesitate to reply back.
Thank you
Dec 26, 2007 | Computers & Internet
Lap tops modems
I can try ... for solving the problem....
Nov 10, 2007 | HP Compaq Presario V2000 Notebook
Toshiba Satellite L305D-S5881 Notebook Logo
195 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
