Question about Sharp Office Equipment & Supplies
Sharp MX-6201n get e7-06 error when scanning to thumb drive
  • 4,323 Answers
Hi
Error E7-06 means Image data decode error. This appears due to Image expansion error. It has been caused due to MCU PWB abnormality or USB cable trouble
Try using a different USB cable. If this doesn't help then try the reset procedure---
Sharp ram clear -- Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Note the other maintenance mode options displayed on the screen when pressing # or *.
Hope this helps...
Daniel
Posted on Oct 09, 2010
What's your question?my sharp prinrer mx 6201n not coming . no power light
check the electrical connection and power plug, mite have a bad power supply board
Aug 18, 2015 | Sharp Office Equipment & Supplies
How do I fix error code F2-41 on Sharp mx-6201N?
Hi
This appears to be related to the toner sensor or harness connector. The details are given here:
Error Codes Sharp MX6201N Code F2 41
where you can also look at all the error codes for your machine or change the make & model number by using the drop down menus along the top of the page:
You can also obtain a full service manual in pdf format from this site.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 29, 2014 | Sharp Office Equipment & Supplies
Mx-2300n firmware
The firmware is only available from a dealer. You can make an arrangement to get it on a USB thumb drive and update the machine using SIM 49
Apr 19, 2014 | Sharp MX-2300N Color Copier
Print from USB on Sharp MX-M363U
The MXM363U cannot print from a USB stick.
It can scan to a USB, but not print from one since it does not have a hard drive, unfortunately.
How To Scan in Black and White or 2 Sided on Sharp Scanner And Other...
Sep 30, 2013 | Sharp Mx-M363u mx-M363u
I have a Sharp MX-6201N copier that is showing error code U2-10. Does anyone know what that means and how to fix it ? Any advice greatly appreciated !
U2-10 is 'SRAM user authentication check sum error'
Press P * C * to enter the service 'simulation' mode then enter 16 on the key pad and press the start button.
You will be in U code clear.
Press 'execute' on the screen.
The machine should reboot.
It may start to work again.
If not you will need to replace either SRAM chip or the main board.
Oct 31, 2010 | Sharp Office Equipment & Supplies
Scanning setup
When you use the Network scanning expansion MX-NSX1 it comes with only one license for the software (scanner tool). To set up the scanning to more then one computer you need additional licenses to install the software onto other PC that you want the images sent to. But you can set the MFP up to scan to e-mail for FTP. You can even scan documents to a thumb drive which on the right side towards the back of the MFP is both an A and B port for USB.
Oct 07, 2009 | Sharp MX-2300N Color Copier
1,044 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
