Question about ASUS K8N-LR Motherboard
K8n-lr motherboard New setup. 1st time power up and you can get to the bios (205), After that 1 long, 2 short beeps. Power down and repeat. When I get to the BIOS, I see 2 potential problems. 1. It shows the opteron as a single when it is a dual. 2. the power monitor shows all the voltages in red and they're all wrong. (ie) 5V shows 6.1V, 2.7V is 2.9V, etc.. This with 2 different new atx supplies. Any help before I get an RMA?
  • marshc50 May 11, 2010
    The voltages out of tolerance can be fixed by clearing the CMOS. This also fixes the boot beep problem however when restting the CMOS date, etc., the problem again returns.
    Tried several different ram sticks without being able to fix it.
    Scholar:
  • 187 Answers
1 long beep and 2 shorts beeps indicates a problem with your RAM. If you have more than one RAM chip, remove one of them to rule out a faulty chip. If you only have one chip, remove and reseat it. For clarity, you can find the manual for your board at; http://support.asus.com/download/download.aspx?SLanguage=en-us&model=K8N-LR And the Asus general motherboard troubleshooting manual at; http://support.asus.com/images/document/ts/E2437_MB.zip
Posted on May 31, 2008
Long beep continuous
here is a list of beep code for Award bios chip, which is the one present on you memory card:
repeated beeps - DRAM error
repeated short beeps - Power error
Repeated high & low beeps - Processor is damaged/Overheated
1 short - System boot successfull
2 short - CMOS setting error
1 long 1 short - DRAM or M/B error
1 long 2 short - Monitor or display card error
1 long 3 short - Keyboard error
1 long 9 short - BIOS ROM error
I don't remember the speed of the repeted beeps for the award bios.
But in your case if this is not a DRAM issue, you might try to check if the beeping remain the same once the cmos battery removed (the flat batterie that looks taken out of a watch).
If so this means that it needs to be replaced.
Oct 20, 2013 | MSI PM8M-V Motherboard
MSI K8N Neo V2.0 beep code problem is continous beeps.
That's usually a bad ram stick. Shut down the pc & remove one stick at a time starting with the one furthest from the cpu & work your way down to the first one. When it boots without the constant "beep", you found the bad one! You can also check www.msi.com & look in the support area for a solution if mine is wrong.(I'm never wrong though,lol)
May 16, 2010 | MSI K8N Neo Platinum, 601-7030-010,...
K8N mortheboard no signal screen
HI,
In this new tower you are swttching to, does it have it's own power supply? And if so, what are the amps, and what are the amps on your old power supply? I have the K8N, and it needs at least 450W to run decent. Let me know?
Mark
Jan 03, 2010 | ASUS K8N-DL Motherboard
System not booting, k8n
Have you tried resetting the bios? turn off the computer and remove the power cable connected to the power ATX power supply, look for the "clr_cmos" jumper and change the settings from 1-2 to 2-3 for approx. 10 secs, then return the jumpers to original settings and reconnnect the power cable and turn on the computer. This was the solution when i had the same problem before. Hope this helps you too.
Oct 01, 2009 | ASUS K8N-E Motherboard
Continuous short beeps on power up.Then shuts down and trys again, then repeats beep sequence. 21 beeps in total before attempts to reboot. Power - 550W Q9400 Intel ESC 9600GT Video card 8 Gig DDR2
enter bios setup and check the temperature of your mobo and cpu if it's above normal and also check the cpu fan's speed if theres no problem with these three then try to remove all the expansion cards you have then reset the memory modules if the beeping continues try a different PSU and memory modules.
Jul 12, 2009 | Gigabyte GA-EP43-UD3L Motherboard
Motherboard live then 1 beep followed by 4 beeps then nothing.
The one beep is usually normal for most computers. Is your Video card seated correctly?
4 beeps Refresh error RAM is not refreshing correctly. Reset the refresh values in the BIOS or reset the BIOS.
Jan 14, 2009 | ASUS K8N-VM Motherboard
I am getting 1 long beep and then 6 short ones
Hi canturob,
When a system reports a check sum error the bios is telling you the information stored from the last working boot does not match the current settings stored in the bios. Please power down your MSI system, unplug the power cord. Open the case & clear the bios. Location of JBAT1 on page 3 in manual.
Clear CMOS Jumper: JBAT1 page 10 in the manual. Remove the battery/cmos. Check it's voltage with a volt meter. It should test to 3volts DC. Anything less & the battery needs to be replaced.
While in the case re-check all data cables & power cables for good connection.
The MSI board uses the Award bios. Your current beep code of 1 long & six short is not a common beep code for the Award bios. See bios beep codes here: http://www.bioscentral.com/beepcodes/awardbeep.htm
If the battery checks out ok, you may need to update the bios. Go to MSI: http://global.msi.com.tw/index.php?func=downloaddetail&type=utility&maincat_no=1&prod_no=205
To update your MSI bios (Option only if bios clear fails to resolves the check sum issue).
Good luck canturob!
Mike
Dec 03, 2008 | MSI PM8M-V Motherboard
I have an Asus p4s533-mx motherboard which boots and runs fine (sometimes). But when I perform a warm boot, it often won't pass POST. The beep code is one long and two short. If I power it down and let it...
The response from ASUS tech support - It's a standard Award BIOS, so they're the standard beep codes.
So I wrote the following on page 3-4 of my user guide:
1 long + 2 short = Video adaptor error
1 long + 3 short = No video card or bad video RAM
high freq beeps while running = Overheated cpu
repeating high/low = cpu problem
repeating (endless loop) = memory error
Sep 29, 2008 | Computers & Internet
K8N motherboard
Have you tried a secondary PSU? (though it sounds like your motherboard needs replacing)
May 23, 2008 | ASUS K8N Motherboard
Asus K8N-LR power problem
This is a problem within your ATX power supply . Better to get it repaired or replaced , otherwise each switch-on surge would damage your comp components eventually .
Apr 14, 2008 | ASUS K8N-LR Motherboard
ASUS K8N-LR Motherboard Logo
169 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
