Question about Honeywell Programmable Thermostat Heater
I have a Honeywell thermostat. The heater comes on but the room temp on the thermostat doesn't reach the programed temp on the thermostat. The heater still runs but doesn't catch up to programed time.
    Problem Solver:
  • 10 Answers
Sounds like the btu rating isnt enough to heat the room you are useing it in.
Posted on Oct 09, 2010
Heater problem
Is the unit a heat pump? If so then check the aux heat relay to see if the electric heat strips come on.
Feb 05, 2014 | Honeywell PRO 4000 5-2 Day Programmable...
Trying to set temp on honeywell t-stat
I believe what your experiencing is the 75 degrees is the hold temp position...the display then reverts back to the actual room temperature...it doesn't mean the set temperature changed back to 65 degrees. Try to reprogram the thermostat schedules, and try not to use the hold function...just the temporary hold. (which is bumping the programmed temperature up or down until the next programmed period)
Dec 09, 2013 | Honeywell Programmable Thermostat Heater
Honeywell rlv430 is wired in correctly, yet one baseboard heater is always on, regardless of the temp Its set at
Need to start with comparing the temp in the room to the temp the heater is set to. A t-stat will read +/- the actual temp. If their not even close, then the heater will run trying to reach the temp the t-stat is set to.
Mar 06, 2011 | Honeywell Programmable Thermostat Heater
Honeywell CT500 Electronic Thermostat showing 73 deg room temp when room temp is actually 77 degs. Can thermostat be calibrated?
Yes,
Most all the Honeywell t-stats can be calibrated...
check out this tip to find the manual for your t-stat and then how to get into the installer setup program...
Manual Honeywell How to Find Honeywell Manuals
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
heatman101
Aug 13, 2010 | Honeywell CT500 Digital Heat / Cool Manual...
Temp is ten degrees lower than temp called for
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 20, 2010 | Honeywell Programmable Thermostat Heater
The thermostat is not shutting off boiler when the
on electronic stats check that the temp is in sync with the room temp on touch pad push the menu button the two temps should be the same if not touch temp till reads correct
Oct 18, 2009 | Honeywell Electronic Programmable...
Honeywell thermostat won't regulate temp properly
check to differential setting in the thermostat and are you saying the temp in the room and the set temp is being read from the thermostat or is there another thermometer in the room your looking at
Jun 25, 2009 | Honeywell Electronic Programmable...
I have installed a honeywell programable thermostat that has been working well until the outdoor temp reached higher temps. Now it continuously blows like a fan and does not cool the home.
Sounds like the t-stat is wired wrong or if you bought a honeywell from home depot didn't set up correctely. You could also have other issues, like low on freon, dirty filters. You might need to call a Service company to take a look at it.
Apr 25, 2009 | Honeywell Electronic Programmable...
Cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
Heater comes on at 5:10 am prior to the programmed setting
Access the installer setup menu (You will need the installation manual from the t'stat to do this) and turn off the "intelligent recovery" feature. This feature turns the equipment on in order to bring the conditioned area up to temp at the set time. Or you could set the "wake time" to 6:50!!!
Dec 15, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
166 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
