Question about RCA 27F530T 27" TV
Where? where is eeprom located? how it looks like?
  • 85 Answers
It is the cpu,a big one
Posted on Jun 11, 2008
Eeprom location samsung tv le26a457c1d
EEPROM can be located very near to the main system control IC, at the control board.
Sep 03, 2013 | Televison & Video
Where is the eeprom located on le40r74bdx
EEPROMs [Memory ICs] can be located very near to the main system control IC. Will be very small in size, having up to 8 solder terminals.
See pictures
Mar 02, 2013 | Samsung Televison & Video
Dude, Can you send me a Bootable ISO CD of Dell Asset/Service Tag BIOS Reset Tool........Please
Hello, you can download this tool here:
http://www.cgsecurity.org/wiki/CmosPwd
Dell
The official method is to contact Dell Technical Support. Dell Technical Support will request the Service Tag and Express Service Code from the bottom of the Latitude. If the current user is not the original Latitude owner, Dell will transfer the used Latitude's registration from the original owner with only the Service Tag and Express Service Code from the tag on the laptop.
  • Dell Inspiron 5100: eeprom 93lc46, password in scan code at 0x310
  • Dell Inspiron 7500: eeprom 24c164
  • Dell Inspiron 8100: eeprom 24c02
  • Dell Latitude C600: eeprom 24c02, password in scan code at 0x00, 0x10 and 0x90
  • Dell Latitude C610: eeprom 24c02, password in scan code at 0x00, 0x10, 0x80 and 0x90
  • Dell Latitude C640: eeprom 24c04, password in scan code at 0x100 and 0x180
  • Dell Latitude CPI: eeprom 24c02, password in scan code at 0x00, 0x10, 0x80
  • Dell D600: eeprom 24c04, password in scan code at 0x110
  • Dell Optiplex: Remove the PSWD jumper
  • For most Dell Dimension desktops, the steps to reset a BIOS password and clear all CMOS settings are:
    • Locate the 3-pin CMOS password reset jumper on the system board.
    • Remove the jumper plug from pins 1 and 2.
    • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
    • Replace the jumper plug on pins 1 and 2.
Try the backdoor password: Dell
The another method is: by Using the Motherboard Jumper: In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off, and remove the battery and power cord
( if it is a laptop ) before you continue.
Here is a picture how it looks like:
The default setting is:pin 1 to 2, to clear cmos: 2 to 3.
Best of luck :-)
Feb 05, 2013 | Computers & Internet
Can't change channels with remote
You are in need of replacing the eeprom. Location of the eeprom on the TV board is IC002. To determine the correct eeprom, you must know the numbers on IC 1001 which is a stereo decoder and the numbers on IC001 which is the microprocessor. This will determine which eeprom part number for your TV, as three different ones are available. Thanks for asking and show a few hands of support!
Jan 12, 2011 | Philips Magnavox 27MS343S 27" TV
Hi I accidentaly actiivate the child control on my tv and turned it off, I don't have the original remote any longer and I can not turn on my tv. Please help Mike
Concerning the problem...it is extremely likely that you have a corrupt EEPROM. A very common problem with this TV.The correct EEPROM (IC location IC 002) is dependent on which microprocessor (IC location IC001) and which stereo decoder (IC location IC 1001) are present on the board being repaired. Take this info to a TV tech and they will find the correct EEPROM to replace. Your TV will come back to life. If not, give me the numbers of ICs IC001 and IC1001. I will forward the correct EEPROM part #. Then the tech will repair your TV. Thanks for asking and show all hands of support!
Dec 01, 2010 | Philips Magnavox 27MS343S 27" TV
Older tv dont know our smartlock code how do we reset?
You have a corrupt eeprom. This is a case of mistaken identity.The eeprom is located on the TV board as IC002. Locations are labled next to each tv part. This eeprom [IC002] is dependent on which microprocessor [IC001] and which stereo decoder [IC1001] is used. There are three different eeproms, and you will need the correct one for your TV. Check the number on the actual IC . For example IC001 may be MCU A22V01-T0 and IC1001 might be MSP3440. If this is the case you will need eeprom part number [location IC002] 4835 310 57593. Philps/Magnavox parts have twelve numbers and that is the correct part number for this particular example. Thanks for asking and show your hands of support!
Sep 20, 2010 | Philips Magnavox 27MS343S 27" TV
No power on no image
You have a corruted EEprom...very common problem for this TV. Have a tech look at this...he will need numbers from IC001 and IC 1001 to determine which EEprom you need! EEprom location is 002.
Jan 13, 2010 | Philips Magnavox 27MS343S 27" TV
Magnavox televison will not turn on,it has a green flashing power light
You have a corrupt EEprom! Location IC002 is the EEprom. And you must see the numbers on IC 1001 and IC 001, to determine which EEprom you will need!
Dec 28, 2009 | Philips Magnavox 27MS343S 27" TV
I have a GE Television that was manufactured in Nov 1995. I can't get it to turn on. I know the power source is good. I suspect that the internal fuse blew and I am looking for the schematic so I can...
The chassis series used in that set was notorious for bad solder connections around its tuner and a few other places. (They used the tuner shield to provide a number of ground connections, and these cracked and went flaky.) These connections would cause a variety of problems including a set that won't turn on.
The fuse is located right near the AC mains cord connections on the board. You will probably find it's good. Not much went wrong on this chassis to blow that fuse unless it was power line troubles or shorted parts on the power supply primary side.
Check for 5 volts at one of the 3 pins on the the remote sensor. If the power is there, you probably have a bad EEPROM IC. Operating parameters and TV settings are stored in that chip, and the bad solder connections I mentioned above can lead to the data getting scrambled and a "dead" set. To repair this, you need to resolder the connections at the tuner shield and a few other locations, then replace the EEPROM.
If you Google "RCA tuner solder problems" or something similar, you should find all kinds of information about where to solder. The replacement EEPROMs are available from MCM (www.mcminone.com) and you order the appropriate IC for the chassis. I'm not home now, but when I get home later I'll check my files for the service bulletin RCA released, and look up the EEPROM you need in case that turns out to be the trouble.
Apr 27, 2009 | GE Televison & Video
Need to locate eeprom.
Hi there.
EEPROM stands for Electrically Erasable Programmable Read-Only Memory. An EEPROM is like an EPROM chip since it can be written in or programmed more than once. Unlike the EPROM chip, however, an EEPROM chip need not be taken out of the computer or electronic device of which it is part when a new program or data needs to be written on it.
The BIOS is the EEPROM chip, so you have to note what BIOS version it is AMI, Pheonix for example, this chip is located on the laptop motherboard and will be clearly marked.
Good luck and thanks for using FixYa!!
Mar 24, 2009 | HP Compaq 6710b Notebook
RCA 27F530T 27" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
