Question about Emerson MW8987B/W Microwave Oven
Light not working
The light inside doesn't go on when the door is opened, only when it is running. Is this normal or is there a separate lightbulb for when it is open? I would look it up in the manual but I don't have one. Thanks!
  • Mailchk Jun 02, 2008
    If there was a switch stuck in the open position, wouldn't the light be on all the time instead of not on when I open the door?
    Champion:
  • 254 Answers
Check around the perimeter of the door housing for a switch that might be stuck in the open position.
Posted on May 30, 2008
  • burzerko
    burzerko Jun 02, 2008
    By open position I meant that the circut feeding the switch would be open making it to where the current would not be able to pass through.
How do i change the lightbulb
Sometimes you change them from the inside, but more often, there is a small door on the outside which is fixed by a single screw. It is on the outside of the case which corresponds to the place inside where the light is at the back or on the side.
Jan 08, 2016 | Microwave Ovens
I had a power surge in my house and my EMERSON 900W MICROWAVE OVEN MW8999RD control pad is not working. The lightbulb works and the tray spins slowly when I open the microwave door. However, nothing
I hope it's still under warranty. Think about getting a replacement, and about next time: Get a surge protection device between the oven and the wall plug! I have suffered from power surges in my house as well, and a surge protector is the only cure.
Dec 07, 2014 | Emerson Microwave Ovens
Microwave will not run a cook cycle. Touchpad functions until door is opened or start button is pressed. When door is opened display goes dark. When door shuts display lights all characters and then says...
BEFORE DOING ANYTHING DISCONNECT OVEN FROM POWER. I do NOT recommend doing repair by yourself, if you NOT are really very familiar with electric repair, or have at least basic training in electric device repair and maintenance.
"When door is opened display goes dark. When door shuts display lights all characters and then says "touch clock"."
Obviously, by opening door, oven gets disconnected form power line.
This is mostly caused by loose connections on wiring socket, and can be anywhere inside. Check security micro switch on door latch. This switch normally disables only running the oven when door is open, for security reasons. In your case, it seems that opening door disconnects oven from input power. Sometimes the switch is loose, or wires are not firmly pushed in the socket. If the power line wiring is loose, and by opening door looses contact with socket, it can touch metal housing inside, cause short, electric shock, serious even mortal injury and fire. This is dangerous high voltage switch, and to access it one must open oven from the back and take off the cover. I do not recommend doing it by your self.
Rem: Replacement micro switch is couple dollars.
Oct 24, 2014 | Microwave Ovens
How can I replace lightbulb in my kenmore microwave?
If there is alight you can open the oven cover and move around sideways the cover will open
Sep 13, 2014 | Kenmore 69109 Microwave Oven
Why does light comes on turntable turns when door opens nothing lights on display or nothing works ?
Normally faulty micro switch which needs replacing: Caution: hight voltage may be present so best left to service person
Jul 23, 2014 | Oster Microwave Ovens
Advantium 120 Interior light is out. How do I replace?
Here ya go... this fella did a good job and replaced the bulb for $4.95 vs $180.00 for the service call parts and labor. This is With pictures and how to steps down the page.
http://www.instructables.com/id/GE-Advantium-Microwave-Halogen-Lightbulb-Replaceme/
Thanks for using FixYa.
Kelly
Apr 09, 2010 | GE Advantium 120 Convection/Microwave Oven
Samsung microwave oven turntable doesn't turn now. Is it ok to still use to heat/cook food ? What is the problem with it ?
Yes it just will not cook or defrost very evenly. It is not dangerous however.
Probably the motor or gears that make the turntable go are worn or burnt out.
May 01, 2009 | Samsung MU3250W Microwave Oven
Door latch and Screen
This is because of the broken latch. There are switches inside the oven that are operated by the door latches to make sure you're not trying to use the oven with the door open. With the new door, your oven should be back to normal.
Feb 06, 2009 | Whirlpool Microwave Ovens
Emerson MW8987B/W Microwave Oven Logo
83 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
