Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Hc-p4752w will not turn on.
Bought from sams a couple years ago and has worked fine ever since. no problems with picture or anything until now. when unplugged and plugged back in, the red indicator light on the front blinks a couple of times, t.v. makes a little noise in the rear for a second or two, then light in front stays on steady and nothing else happens.
  • Samsung Master
  • 8,617 Answers
You will need to trouble shoot the power supplies most likely a low voltage regulator isnt functioning.
Posted on May 30, 2008
I'VE HAD THIS TV FOR 4 1/2 YEARS-THINK IT'S THE BULB-REPLACE?
The HC-P4752W doesnt have a lamp. Thats a rear projection it has three picture tubes.
Oct 10, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W Does Not Turn ON
The proble you have is an intermittant power supply or sweep power supply. Unless you can find a bad connection on the power and deflection board, this could be a very difficult problem to find. I have ran across this problem a couple of times, and after spending countless hours troubleshooting, I replaced the main board and all the problems were taken care of. The board part number is at samsungparts.com and I found the board for you. it is located here: http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP94%2D01266A&search%5Fmodel=HCP4752W Good Luck
Jul 04, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" projection TV distortion & yellow?
I think you have a fault on the chroma board and on the picture frame board. If you can trace it yourself try these two locations otherwise call out a competant technician. hope this helps.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
TV problem
It sounds like there is a fault on the chroma panel of some kind.
Jul 23, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47in", is showing double picture
your Convergence ICs need to be replaced you will need two STK392-010 ICs you can get replacements at the following link, and they provide free instalation instructions with pics so you can do the repair yourself and save about 400 dollars. They also have free online instant messageing while you do the repair in case you need additional help when doing the repair. Heres the link.
http://servicemanuals.vstore.ca/
May 21, 2008 | Televison & Video
Akai LCT3201AD 32 in. LCD picture stretched around the corners
This set has several differant aspect ratios, could you have unwittingly change it to a zoom or expand by mistake?
Feb 07, 2008 | Akai LCT3201TD 32 in. LCD Television
2 1/2 years new Samsung HC-P4752W from Costco, Canada
Samsung makes a great product and has one of the best pictures out there. I have had mine for a couple of years and only experience a slight convergience issue on left and right sides of the screen after twenty minutes of run time. I am currently trying to figure out how to fix it.
Jan 26, 2008 | Samsung HC-P4752W 47" Rear Projection...
Distortion at the outher left an right positions? approx 2" each side
If it's an HCP4752W it's a 47" but what's the problem it's having cables or dish box?? No picture, no sound, poor reception, please elaborate.
Bill
Nov 24, 2007 | Samsung HC-P4752W 47" Rear Projection...
Sansung HC-P4752w 52 in. Rear Projection
you require a deflection board replacement the board cost around $150/
Aug 02, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W Blurred
im sorry for this not being a solution, but I have the exact same issue Jose. It just happened 3 days ago. When I run auto focus it says check factory default settings. Will replacing the 2 CI's help cure this problem.
Jul 28, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
96 people viewed this question
Henry  Thomas
Henry Thomas
