Question about Brother PE-150V Computerized Sewing Machine
My PE150 will sew about 1/2 way through a name and then stops picking up the bobbin thread. I have rethreaded,changed needles. and made sure that the machine is clean. Can you give me a suggestion on how to fix this problem? the name that I am working on is "Conner" Thank you for your time.
  • dbld1 Oct 08, 2010
    Thank you for your prompt response. When I tried your suggestion i found that the machine will not pick up the bobbin thread at all now.
    thank you
    Once again, thank you Tim. We have a service person here in Lubbock that we will take the machine to.
    President:
  • 2,777 Answers
That is a very strange problem... is there a way you can do a test of another name with equal characters... even better a test of the same letters in different order, for example Corenn and see if it stops half way or if it is a letter related issue? Obviously on some scrap piece you hopefully have... not on the same piece
Thanks
Tim
Posted on Oct 08, 2010
  • Tim Grayson
    Tim Grayson Oct 08, 2010
    Ok it's definitely getting worse here.. something is malfunctioning with the actual controller module inside the machine. Your best bet unfortunately is going to be to have this machine serviced. Do you know of any local places that can service it? If not I can find the contact information for who need to get ahold of here..
    Tim
Machine saying to rethread the upper thread but not picking up bottom thread from bobbin. Constantly rethreaded upper thread still won't sew.
Consult the owner's manual to make sure it is threaded correctly. Install a brand new needle making sure it is installed properly. Also, be sure to RAISE the presser foot BEFORE threading the upper thread.
If it is still not picking up the bobbin thread, the machine may be out of time.
Jan 20, 2016 | Brother InnovIs QC1000 Electronic Sewing...
Why won't it pick up bobbin thread
Try changing the needle--make sure the needle is inserted correctly
Try rethreading the machine top and bobbin
Make sure the bobbin is turned the correct way In the bobbin case
It's possible that the machine needs to be checked for a timing problem
Aug 11, 2014 | Sewing Machines
Upper thread gets jammed in bobbin area
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Dec 12, 2012 | Brother Sewing Machines
Needle goes down but don't pick up the bobbin thread. It come up and tell me that my upper or lower thread is cut.
try changing the needle
try rethreading the machine top and bobbin
make sure to use every thread guide-this is improtant for the
thread tension
make sure the bobbin is turned correctly in the bobbin case
also could be a problem with the computer motherboard
or there could be a problem with the timing
Dec 03, 2012 | Brother PE-150V Computerized Sewing...
Threading the bobbin thread
try rethreading the machine top and bobbin--make sure to use every
thread guide
try changing the needle--make sure the needle is turned the right way
and inserted correctly into the needle holder
make sure the bobbin is turned the right way in the bobbin case
and if the machine still will not pick up the bobbin thread it would be a
good idea to have the machine checked to see if the timing is ok.
here is a link for a free manual just incase you don't have one
http://www.singerco.com/uploads/download/617_7258-instruction-manual.pdf
Nov 06, 2012 | Singer 7258 Sewing Machine
Hello! My reliable 1222 has hit a snag. When try to sew, the top thread is not being picked up by the bobbin thread. How can I fix it? Pavla
clean under the needle plate & in bobbin area for loose threads & lint
try rethreading the machine top & bobbin, make sure to get every thread guide
make sure the bobbin is inserted correctly in the bobbin case
Mar 11, 2012 | PfaFF Sewing Machines
Singer sewing machine won't pick up bobbin thread
Make sure that the area is clean and free of lint. Change the needle and rethread the machine.
Nov 24, 2011 | Singer 7426 Mechanical Sewing Machine
Needle is not picking up thread from bobbin it was working fine and just stopped sewing then I noticed the bobbin thread was not being picked up .
Check your needle, it may need to be changed (make sure you insert it flat side away from you), now totally rethread, Another thing, is your thread old, tangled? If, all of this does not fix it, take it in for professional service.
Apr 16, 2011 | Brother LS-2125 Mechanical Sewing Machine
Brother pe150 won't pick up bobbin thread
Hi. This may sound silly, but the most likely reason the upper thread doesn't pick up the bobbin thread is that the needle is in backwards. (Sounds silly, but it's true!)
Needle shanks have a flat side and that flat side has to go in a particular way for your machine. With most modern machines, the flat side goes to the rear, facing away from you. Check your manual to be sure.
The second most likely reason is that your needle may be bent. Check that your needle is straight (or just use a new one).
Hope this helps!
Happy Sewing,
Robbie
Mar 14, 2010 | Brother PE-150V Computerized Sewing...
Needle does not pick up thread from bobbin
rethread the bobbin and/or check the bobbin is placed correctly, rethread upper thread
Feb 11, 2010 | Sewing Machines
Brother PE-150V Computerized Sewing Machine Logo
114 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
