My air conditioner is leaking water. help! - Heating & Cooling
  • hart0502 Jul 30, 2008
    My ac unit is leaking out the front (on the same side that the drain is on, but coming out the front instead of through the drain). I am not an expert installer, and I noticed this morning that it's not level, that it's leaning forward. I need to unscrew it from the window and put a piece of wood under the front or something to make it level (or should it lean slightly back?), right?
I'm haveing the same problem, I see you wrote this in 2008, so how did you fix it?
Posted on Aug 29, 2010
Being a window unit all that I could tell is that it was draining somewhere around the bottom and draining down the front of the window pane
Posted on Jul 06, 2008
    Champion:
  • 254 Answers
Where is it leaking water? Need more information.
Posted on May 30, 2008
I have a Fujitsu air conditioner, model # ASUI8CI serial # ACA010576. It drips water into the room from the right side. After switching off the air conditioner and wiping the water, I switch it on again...
chances are either the unit is not level or the drain hose is not pitched properly going through the wall when water is leaking is there water coming out of the hose outside
Jul 11, 2011 | Fujitsu 24R1 Air Conditioner
My unit is leaking tons of water only when a/c is on for a while. It leaks out of base and I have to drain tank every day. Help!!!
It is supposed to "leak" water into it's reservoir and it needs to be dumped when it gets full. That water is the humidity that the a/c is pulling form the air inside your home. As long as it's going into the reservoir and not leaking onto your floor then it is working properly.
Jun 24, 2011 | Windchaser PACR10 Portable Air Conditioner
My AC unit leaks an inordinate amount of water into the apartment. Most of the times it happens when the humidity is high. I have to put rags inder the unit to absorb the water & change the rag after...
Check your air filter, the unit may be freezing up because of not getting enough air...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 06, 2010 | Emerson Quiet Kool 10NW16K Air Conditioner
Water leaking from indoor unit against the wall.
It's probably the insulation around your refrigerant pipes. If it is too thin or missing in a section they will condensate.
Jan 16, 2010 | GE Quiet-Aire Ductless Split System Air...
Leaking
Please check the water container for leaks. Normally,
it does not leak, since the water is supposed to evapo-
rate due to compressor heat. The water that the aircon produces goes to a containing pond near the compressor. So that if there is a leak, it emanate from
this area. May this tip help you.
Jan 10, 2010 | DeLonghi PAC C100 Air Conditioner
The air onditioner leaks water, can't remember if
Mine is a different brand, but it has a "bucket" in the back I have to empty every day.
Jul 24, 2009 | Danby DPAC8020 Air Conditioner
Water leaking all over
The water leaks all over the floor instead of running into the water containner. if that is right then your condenser drain pan tubing is blocked or the pan is rusted out that cause the water leaks all over instead of running down the tubing into the water containner . You've to dismantle the panels to get into this condenser drain pan to have a good clean out . Hope this will help . God Bless.
Jul 23, 2009 | Heating & Cooling
Mitsubishi Air Conditioner FDKN Series leaks water after 30 mins
It could be one of two things -
1) The unit is not hanging level (assuming this is a wall mount, through the wall, or window unit), or
2) The condensate drain or trough to the drain is plugged/clogged/filled with trash.
Jan 22, 2009 | Heating & Cooling
Air conditioner is leaking but lights not blinking
Make sure the drainage port is closed as per the instructions. If you continue to have leakage you may have a leak in the tank.
Jun 15, 2007 | Sharp CV-P09FX Air Conditioner
Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
716 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
