Question about DeLonghi CTH4003 4-Slice Toaster
Dial for the darkness on each side does not function.....seems the cable is off? have to guess at setting
    Champion:
  • 248 Answers
Should be able to reconnect cable through access panel on bottom of toaster
Posted on Oct 09, 2010
Got a brinks EZ- dial timer model42-1034B @ Walmart a few days ago can not seem to get it to work, Inst, seem so easy too. I read on some forum online someone thought the am/pm may be backwards to how it...
1) This Brinks timer is a bit lightweight for an appliance (unless for coffeemaker or tiny gerbil-feeding motor)
You might need 1/3 HP (horsepower) appliance timer like Woods 59201
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
Intermatic HB113C is for heavier appliances
http://www.amazon.com/Intermatic-Hb113c/dp/B000GHKO6C
http://waterheatertimer.org/images/Intermatic-HB114C-plug-in-4.jpg
2) How to set the Brinks:
I will use lamp as example since you can easily test the timer using a lamp.
Turn lamp ON. Make sure bulb is good.
Leave lamp turned ON and plug lamp into timer.
Move slide switch one direction.
Plug timer into outlet.
Manually rotate timer dial clockwise and see if lamp turns on-off
Move slide switch other direction, and rotate dial clockwise again to see if lamp turns on-off.
Now you know which way switch has to be moved.
Push down trippers and rotate around dial until they line up with 1:00 on dark part of dial and 5:00 on dark part of dial. Dark is for pm hours.
Last step: Set current time: rotate dial clockwise until current time lines up with arrowhead located on inner dial
Dial rotates at time passes, trippers push lever that turns circuit on-off.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 29, 2011 | Hampton Technologies Brinks Timer
I just bought a GE 24 hour mechanical time # 15152. How do set it? The dial is very confusing. I understand that I must first pull all the buttons up and push down the ones I need. If I set it to go...
GE 15152
http://waterheatertimer.org/GE-timers-and-manuals.html#15152
Light side of dial is am hours
Dark side is pm hours
Set timer ON from 5pm to 11 pm:
When segments are down, timer is ON.
Lift all segments, except segments between 5 and 11.
Rotate dial until current time lines up with arrowhead located on inner dial.
Move switch to TIMER ON
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 16, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
Explain in plain english how this works. Set time on face rotating dial clockwise.. push in pins to on and off positions. It seems to screwy unless timer runs counterclockwise, Set time at 5:30 AM amd go...
For starters, disregard which way the timer runs. Push in the pins for when you want it to power your lights. Turn the dial to set the time of day that it is now. That should be it.
Dec 04, 2010 | Woods 2C 24 Hour Indoor Mechanical Timer...
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
Manual ON/TIMER switch located on inner dial.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
Clear instructions for power plus 24 hour timer. What is meant by slices ?
I can't identify 'power plus' timer specifically.
I'm going to guess at answer based on other manuals.
Your timer has a dial on it's face. You rotate dial to set time of day. And the time of day lines up with a triangle marker usually located on center part of dial on right side.
The dial has 48 plastic pieces around outer edge of dial, and each one of these 'slices' or pieces of plastic represent 1/2 hour.
So the dial has 48 'slices' around the dial, and each 'slice' can be lifted up to set timer on-off functions. Sometimes they lift up and out instead of straight up.
Usually when slice is up, timer is ON, and when slice is down, timer is OFF.
Oct 02, 2010 | Hardware & Accessories
Can't seem to figure it out. Directions are not specific enough. We set "the time now", but the white/AM, dark/PM is weird. Please help w/ directions. We need the light for chicken house. Light on 5:00 AM...
What kind of Woods timer do you have?
Is the dial turning? The dial is the clock. And the clock needs electricity to work, just like alarm clock. If dial is not turning, the wiring is not right.
Does the manual override turn on the lights? Maybe the slider switch set to OFF? Set slider to "Timer" for timer functions to work.
Wall timer:
If you have 59017 wall timer, it has dark PM white AM. You rotate dial until correct time lines up with little triangle located on right side of center knob.
There are 48 plastic pins on dial ... when pins are moved out, the lights are off. For timer functions, set slide switch to 'Timer'
Correct wiring is needed for timer to work:
Timer black attaches to Hot wire from breaker box
Timer red attaches to wire going to Load (lights)
Timer white must attach to white Neutral (or if your box has no neutral, connect white to bare ground)
Timer green connects to bare ground
If wiring seems right but dial on front of timer is still not rotating, then reverse Timer red and Timer black and see if that sorts out problem.
If this is wrong Woods timer, please re-post question.
Oct 02, 2010 | Woods Hardware & Accessories
I have a panasonic kx-t7731...having trouble setting the speed dial...any help would be appreciated. the users guide information doesn't seem to work. thank you!
A 7731 phone will function on any one of 18 or so different Panasonic system cabinets. Now, which "user guide" are you looking at? SYSTEM speed dial is set from the first extension or the maintanance console of the phone system. PERSONAL FEATURE (speed dials on the right side of the phone) are pretty much universally programmed by PROGRAM button, 9+ number STORE.
What do your instructions say?
Carl
Sep 15, 2010 | Panasonic KX-T7731 Corded Phone
Setting MF Dial Function
Sorry, I have no manual for that one :(
Jan 14, 2010 | Lands Phones
Dark Pictures in Auto setting
I had the same problem before. Did you check to make sure your exposure compensation wasn't set at a negative number? half press the shutter and rotate the large dial on the back of the camera to change the exposure to 0. If this just changes your auto focus points, you have to change your custom function 13 from a value of 2 to 0 and then try half pressing the shutter and rotating the large dial in the back again. This fixed my problem with shooting in P mode (which I only used when absolutely necessary) and I hope it helps you.
Nov 09, 2007 | Cameras
DeLonghi CTH4003 4-Slice Toaster Logo
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oloyede Monsuru
Gerry Harvey
Gerry Harvey
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
