Question about Vizio L32 32 in. LCD HDTV
My 32 inch Vizio TV will turn on but within about 5 - 10 minutes, the screen goes to nothign but vertical lines. The T V makes a very high pithced noise and ten turns it self off.
  • 11,361 Answers
The high pitch sound may be coming from the power supply module or from the backlight inverter boards.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Oct 09, 2010
Vizio 55 inch T V/ model # SV470M
The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details about flat panel TV repair then check the following link.
http://electro-medical.blogspot.com/
Jul 24, 2016 | Vizio 8 Feet High Speed Hdmi Cable Model...
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
Vizio 32 inch thin black vertical line on left side of screen
it is very likly you have problem with the buffer boards, sometime help to unplug conector and reconect, also check the smd fuse located on one of the boards since there are 2 buffer E&F.
Jan 09, 2013 | Vizio 32" Lcd Hdtv E320VA Hdmi Hd Tv Flat...
Vizio 32 Inch, turn on completely fine for about 20-30 minutes. Then sound goes out accompanied by high pitch noise and picture has varying lines or colors through it. Won't power off, have to un
Are you a decent do it yourselfer? It sounds like it is the capacitors. What happens is they get hot and expand (the top of the Capacitor). The top will be dome shaped and it will look like the top is splitting open. You can buy (about $1.50 ea.) the capacitors at your local electronics store (not Radio Shack they usually don't have a high enough amp).
You will need to take the back off and look at all of the capacitors to see which ones are bad. Usually it will be 2 or 3 of the larger ones but there could be more. Next you will need a soldering iron with a fine tip and some wicking material. How could are you at soldering and de-soldering? before I go on.
If you let me know the model # of your set I can be a little more detailed also.
Sep 24, 2012 | Vizio L32 32 in. LCD HDTV
I have a vizio e320va that when turned on the backlight flickers repeatedly with picture in and out then starts blinking with vertical lines then the screen goes black and the power stays on, This is all...
The tv is having a problems with the board called T-Con board it is dying and the problems.That why the tv is not sustancening the tv pictures for those coded pictures pixels by the T-Con board to stay on to the tv LCD screen panel.This tv problems only causes by the tv T-Con board it is dying only if the tv problems came on to the tv by itself only.If these problems causes by u or an object by outer forces by hitting to the tv LCD screen panel itself.Now the tv LCD screen panel itself it is dying and the causes.Than the tv it is not repairable,tv now only can it to do a replacement of the tv whole LCD screen panel itself only.Not practical because the tv LCD screen panel are 90% important to the tv and the cost of the tv.If u replacing the tv LCD screen panel itself will cost the same as a new tv.The tv is under a year old,why don't u just call Vizio corp. and take ur tv warrenty repair.
Sep 26, 2011 | Vizio E320VA 32 in. LCD HDTV
I have a vertical black line on the middle of the
You have A buffer board out if the line goes up and down then its the long board going left from right look were the line is and see what board the line lines up on the screen and replace that one
these boards are the closet to the edge of the tv
same process if the line goes across the screen
look for the part number on the board and search with google or go to shopjimmys.com and seach there or call them
Oct 19, 2009 | Vizio Televison & Video
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Discolored lines within picture 32 inch LCD TV
I have the same tv, if you turn up the brightness and turn down the contrast that should help a little bit.... Hope this helps
Aug 15, 2008 | Vizio L32 32 in. LCD HDTV
Vertical black line on screen
Your set has either a bad driver board or more likely a bad plasma panel.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 18, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio L32 32 in. LCD HDTV Logo
191 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
