Question about iRobot 5800 Scooba Vacuum
My iRobot 5800 Scooba only goes in circles! How do I fix this?
KOakaKO
  • 135 Answers
SOURCE: Scooba 5800 Power button Red Blinking
You probably have the manual, but here's the link to the Scooba 5800 manual anyway - just in case this would be useful to you: --> http://www.irobot.com/images/homesupport/5800_Scooba_Manual.pdf You could use a voltmeter to check the battery, but only a few months use shouldn't be enough to wear it out. If you don't have a load-tester to verify the battery's load-capacity, then you can check the voltage drop. (Assuming you can get it to contact the Scooba's circuits.) To do this, just check the battery voltage, apply a load by inserting it in the machine and turning it on, then check the battery voltage again. An excessive drop in voltage may indicate the battery needs replacing. However, the red blinking light is Scooba's indicator that it doesn't detect the battery at all. The first thing to do in this case is to clean the electrical contacts on the battery and in the Scooba. Use a damp cloth and a bit of toothpaste to rub the contacts clean on the battery and in the machine. (Toothpaste has mild abrasives in it and will clean the electric contacts without damaging them.) Make sure that both the battery and the Scooba are clean and dry before re-inserting the battery. Also, if the electric contacts in the machine are flexible matal tabs then verify that the tabs are standing up high enough to make good contact with the battery contacts. Hopefully the battery just needs it's contacts cleaned for your unit to work, but test the battery if you are sure that they are clean and seated properly to the contacts in the machine. If the battery appears to be failing, then contact www.irobot.com to cheack and see if they are still covered under your machine's warranty. Hope this helps! :)
Posted on Aug 06, 2007
  • 18 Answers
SOURCE: Scooba doesn't put watter. Pump not working?
Check and make sure the vaccume port is properly installed. I also went on their website, and they do have a faq about this. I have included the link to the site for your convenience: http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=2&p_created=1153319315&p_sid=DCawHwJi&p_accessibility=&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTEmcF9wcm9kcz0zMSwzMyZwX2NhdHM9JnBfcHY9Mi4zMyZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX2ZubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PXdhdGVy&p_li=&p_topview=1
Posted on Aug 19, 2007
  • 416 Answers
SOURCE: Scooba in diagnostic mode
If it is not on a warranty there few options for you are to disassemble it down to the control panel and either replace it or if you do not feel comfortable with doing the repairs you can ship to do the repair work for you. You can buy parts or trade it here
http://www.roombaexchange.com/proddetail.php?prod=903492&cat=40
But might be the "Clean" button just stuck on because of water damage to the button contacts. Try to pull it. Or you will need to disassemble the control panel and carefully seperate the mylar sheets that make up the contact using a box cutter. After that use isopropyl alcohol to clean the contacts
But it is only in case if you can do it.
And dont forget TO UNPLUG THE DIVICE FOM POWER OUTLET
Good Luck
Posted on Jan 24, 2009
  • 61 Answers
SOURCE: Irobot scooba 5800 spins quickly then sets off backwards
Remove and clean all of the wheels, and make sure the cliff sensors under the bumper are clean. Tap the bumper with your hand-- really smack it a couple of times. It sounds like the Scooba believes it's stuck against an obstacle.
Posted on May 13, 2009
  • 5 Answers
SOURCE: Scooba circles and only goes backwards.
ours did that, the other persons post helped, we took everything apart and cleaned every inch of it. there was some dog hair trapped inside of it right in front of the sensor. we put everything back together and it works great now! we just google "how to take apart a scooba" and followed the description and pictures, just be careful when you do it, we still had 4 screws left over afterwards, dont know what we missed but it works so that works for me! good luck!
Posted on Jun 28, 2009
IRobot Scooba 5800 "check tank" light
Why buy something used that is not in perfect operating condition? There may be other problems yet to be discovered.
Dec 31, 2013 | iRobot 5800 Scooba Vacuum
Hello. My scooba 5800 had a check tank light on. I used a straw on the valve and that fixed the problem. Now the scooba runs like nothing is wrong, but there is no actual cleaning going on! It goes the...
Hello, Take the battery out and hold the switch down for 30 seconds, to reset the curcuit board, then charge back up for 12 hours. this should take care of it. If I can help future please call @ 1561-848-3387 Thank you, Teresa. Clean Sweep Vacuums
Aug 10, 2010 | iRobot 5800 Scooba Vacuum
When I turn it on it doesn't start out in the circle motion but starts and than stops and than starts and than stops and moves erratically and than totally stops.
Try a different battery. If no go, you might have bad board or sensors. Basically, if the battery replacement doesn't fix it, get rid of it. Borrow a battery from someone else so you're not wasting your money for testing.
-=/ Daft Tech /=-
Oct 25, 2009 | iRobot 5800 Scooba Vacuum
Have Scooba 340 that won't power on after battery fully charged!
No repair services anywhere, unfortunately. It does sound like you might need a new battery, but the issue could also be the power button. I suggest giving us a call at 1-877-855-8593 so that we can more accurately determine what the problem might be and how we can most efficiently help you to solve it.
Fembot
iRobot Tech Support
Aug 15, 2009 | iRobot 5800 Scooba Vacuum
May 10, 2009 | iRobot 5800 Scooba Vacuum
When i charge,the service light is on and beeping
get back to the person that you bought it from i would think they would give you some kind of waranty.i don't trust buying from ebay .i hope you didn't pay a whole lot for it.send an email to ebay themselves.please leave feedback
May 04, 2009 | iRobot 5800 Scooba Vacuum
Scooba runs for a short time then the service light comes on
have you emtied it and cleaned it good.take the battery out and let it stand for 30 minutes then try again
Feb 22, 2009 | iRobot 5800 Scooba Vacuum
Battery door will not open
You have to push down on the plate to open the door. Make sure Scooba is on a flat surface, then push down. If the door doesn't release, try again. It sometimes takes a few tries, but that should work. If not, call iRobot Support. They are great and have helped with everything. I love my Roombas and my Scooba!
Jan 05, 2009 | iRobot 5800 Scooba Vacuum
IRobot 5800 Scooba Vacuum dirt not going into the fliter basket
You can try rinsing the tank very thoroughly with warm water. Be very sure that you rinse the four ports on the underside of the tank (one round, two oval, one curved like Scooba's filter) very thoroughly, because all the dirt and dirty water moves through those openings and can clog things up.
Fembot
Jan 02, 2009 | iRobot 5800 Scooba Vacuum
try cleaning the cliff sensors under bumper
Dec 13, 2008 | iRobot 5800 Scooba Vacuum
iRobot 5800 Scooba Vacuum Logo
55 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
