Hello I have a frigidaire washer ltf2140fs and I having issues with it starting. All the light light up and ready for the start button except for the lock door light? What is wrong?
SOURCE: Frigidaire Front load washer FTF2140FS
I HAD THAT TOO I UNPLUNG IT FOR 30 MINTUES AND WHEN PRESS START AND CANCEL TOGETHER AND PLUNG IT BACK ON IT SHOULD BLINK A FEW TIME THEN STOP . IF THIS DOESNT WORK THEN REMOVE IT AND MAKE SURE NOTHING CAME LOSE AND PLUG IT IT AND IF THEN NOTHING HAPPENS SORRY ITS BROKEN REPLACE CONTROL PANNEL.
30-50 $$ NOT MAD AT ALL
Posted on Nov 10, 2008
  • 240 Answers
SOURCE: accessing the door lock switch
spring clamp around boot (spring at bottom) pop off with screwdriver, pull boot off groove.
Posted on Mar 16, 2009
erickg
  • 116 Answers
SOURCE: The washer door wont shut or lock on my frigidaire affinity
in the rubber seal around door to washer tub ensure there is nothing inbetween rubber.
Posted on Apr 21, 2009
dblred
  • 68 Answers
SOURCE: my Frigidaire affinity washer doesn't
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Posted on May 06, 2009
localwonder
  • 6784 Answers
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
Posted on May 29, 2009
How do I repair my front load washer that seems like the water pump will not allow the water to drain?
did you check the water filter on the lower part of the machine to be sure it isn't stopped up?
Sep 25, 2014 | Frigidaire Washing Machines
Frigidaire LTF2140ES0 washer lights come on but doesn't start
Hello friend, thanks for your post!
If your Frigidaire washer, LTF2140ES0, is not starting it could be a possible issue with your control panel or door latch. Is your washer showing you any error codes? Double-check to ensure that the door is closed. If it is secure, reset the power to your washer for roughly ten minutes. You can do this by either unplugging it or flipping your circuit breaker into the off position. If the issue continues, it could either be the door lock assembly or a communication problem with the control board. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. I hope these troubleshooting tips help you in some small way. -Matt
Sep 25, 2014 | Washing Machines
My affinity front load washing machine will not start, there are no lights - nothing. The stackable dryer on top does start. Is there some kind of re start button for the washing machine
To Stranded,
Here is a link that will put you directly to free support and a manual to guide through the trouble shooting function. sparke needs help with Frigidaire Washer on ManualsOnline com . If you are familiar with a meter to troubleshoot and identify voltages. Start there. If the display is functional. Here is another forum you can tap for resources to compare. Basics first. How to enter diagnostic mode on Frigidaire ATF7000 washer Appliance... .
And you will need to take it apart.. here is the link for that solution.
Frigidaire Affinity Washer Disassembly
Say how you made out and if this approach helped please?
Fare. Well.
Sep 19, 2014 | Frigidaire Affinity ATF7000E Front Load...
Get my frigidaire washer to start. The lights go on as soon as I close it. Usually I have to push the start button for this to happen.
It sounds like it could be a possible issue within your control panel or door lock assembly. If the door is not making that connection it is closed the washer will not start. I would recommend having a professional come out to properly diagnose your appliance to avoid any unnecessary part purchases. -Matt
Sep 13, 2014 | Frigidaire Affinity ATF7000E Front Load...
Washer will not start
Hello Friend, this is Z. Thank you for allowing me to assist you!
I have interpreted that you are having trouble with your Frigidaire washer not starting. Double-check to ensure that the door is closed. If it is secure, reset the power to your washer for roughly ten minutes. You can do this by either unplugging it or flipping your circuit breaker into the off position. If the issue continues, it could either be the door lock assembly or a communication problem with the control board. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds. I hope these troubleshooting tips help you in some small way. Best!
Sep 13, 2014 | Frigidaire Washing Machines
Frigidaire washer atg6000fsi goes of and on blinks doesn't run I held the start button in it seams like it reset should I still get the repair man in ??
Hello friend, thank you for your post!
I understand that your Frigidaire washer is not starting but just blinks on and off. It sounds like it could be an issue within you door lock assembly or control panel. I would recommend resetting your appliance which can be done by unplugging power to your appliance or flipping the household circuit breaker for roughly ten minutes.
If that step does not correct the issue I would recommend having a professional come out since it could be any one of the under lying issues. -Matt
Washer states sensing with a buzz sound?
Hello keisha, thank you for your post!
I understand that your Frigidaire washer is making a buzzing sound until the cancel or start button has been pushed. It sounds like it could be a possible issue within the door either not being fully closed or it could be a defective switch. I would recommend resetting your appliance which can be done by disconnecting power to the appliance for roughly ten minutes. Please comment back if that did not help correct the issue. -Matt
Sep 05, 2014 | Frigidaire Affinity ATF7000E Front Load...
My control light blinks and beeps when pushing the start button. I have already replaced the door lock and switch assembly. Door lock light does not illuminate at any time.
Based off the information you have provided it sounds like it could be a possible issue within the control panel of your Frigidaire washer. I understand that you have replaced your door lock and switch assembly but it could also be an issue with the keypad of your appliance. I would recommend having a professional come out to properly diagnose your appliance to avoid unnecessary part purchases. I hope this is helpful. - Matt
Aug 21, 2014 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Green normal light is on but none of the buttons including start button work
I understand that the light on your Frigidaire dishwasher is lit as it normally is, except it will not operate. It is possible that your dishwasher may have an issue within the keypad or control panel. You can perform a reset, in the case that it is a miscommunication error within the dishwasher. You can reset the dishwasher by flipping the household circuit breaker off for at least ten minutes. If this does not help correct your issue I would recommend seeking assistance from a professional technician for a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Nov 22, 2013 | Frigidaire FFBD2406NS Built In Dishwashers
I have a frigidaire front load washer. When I start a new load it starts with a couple of seconds of water then stops. Does not go into a wash mode, the timer shows it's going thru the cycles but
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 08, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
108 people viewed this question
Top Washing Machines Experts
