Question about Cartier Pasha W3103755 Wristwatch
My pasha stops operating within only several minutes of no or limited wrist motion. I have tried manually winding it as well. Perhaps I'm winding it incorrectly. Nonetheless, it shouldn't stop operating so quickily after taken off or during periods of minimal motion. Help!
  • 11,800 Answers
This watch has an automatic winding mechanism - one in which the mechanism of the watch is powered by the movement of an excentric situated inside the case which winds the spring. You can actually see the excentric moving in the back crystal cap.
You actually can't wind this watch by hand. The mechanism stops immediately after you put the watch down because the spring isn't winded - that is a mechanical fault, the spring has failed.
You must take the watch to a good watch repair shop to have the spring replaced. This will be quite expensive.
Posted on Oct 08, 2010
Why doesn't it keep running?
It needs to be worn to self wind. I actually bought a winding box so I put watch away it will be turned as if on your wrist. These vary and having owned a couple of winders I chose one that is belt driven, found on Amazon.
if you wear it to sleep it may wind down.
Playing video games ,little wrist motion, may find it stopped.
you mentioned someone to.d you it was fully wound! How can they tell. I cannot wind mine if yours needs winding from stem you may not have real Rollex.
Feb 28, 2016 | Rolex Datejust Watches
Tip
HOW TO START YOUR AUTOMATIC WATCH
mcdevito75 here,The Automatic feature in your WATCH consists of a counter-weight attached to the MAIN SPRING by a gear that allows a SLOW but steady wind of your watch with the motion of your WRIST, ARM. Once, only in HIGH END watches, today almost all watch manufacturers have this feature in some of their models. Everyone who owns an AUTOMATIC watch knows, you can START your AUTOMATIC watch by WINDING THE STEM and you can continue to wind the stem with no end. This will at least START your AUTOMATIC watch and, this is true to some extent BUT, does this apply to my watch you ask?, Here"s how to tell if your AUTOMATIC watch will START with a few winds of the stem or not. ------- Very Simply, Hold your AUTOMATIC watch to your ear and wind the stem, if you hear a sound as though something is DRAGGING or the stem feels slightly stiff one way you wind the stem and you hear a clicking sound when you wind in the other direction, then you have the TYPE of AUTOMATIC watch that will start with a few winds of the stem, approx, 20 turns or winds. If on the other hand you hear nothing when you wind the stem and the stem feels very loose when turnning then you have the TYPE of AUTOMATIC watch that winds only with the motion of your wrist / arm, to start this type of AUTOMATIC watch, simply hold the watch in your hand and rock your watch back and forth, say from the 12 O"clock to the 6 O"clock, and or, Hold your watch securely in your hand a make circular motions with your hand, any movement to get your watches counter-balance to turn and thus wind your watch. Approx. 1 minute of this extra motion will start your AUTOMATIC watch, then simply wear your watch and your wrists / arm motion will keep it wound.
on Jul 06, 2010 | Watches
Watch stops after wearing for a few hours
Self winding watches need motion ( wrist twist) without they can stop. Sometimes just shake your wrist for a few seconds. I purchased a winder box for times I don't wear. ( Amazon)!
it is belt driven winder, rotates watch 5 minutes every hour.
Apr 21, 2015 | Rolex Submariner Oyster Watch for Men
I have a new, purchased ar an auction so no paperwork a Cartier pasha woman's wristwatch. I don't know how to wind it. Please tell me
There are several models of this watch and you don't say which one you have but thi range are either automatic (which means that it is self winding) or quartz (battery driven).
If it is not going it could be
(1) (for a quartz watch) the winder has been pulled out (push it back in) or the battery has expired. (Do you know how old the watch is?).
(2) If the watch says "automatic" on the face, then it haas probably just run down (they run for 2-3 days if they are not used). If this is the case, holding the watch horizontally, swing it gently from side it side for a few minutes (this will operate the self winding mechanism) and the watch should then start. To keep an autimatic watch operating it needs to be worn daily or placed on a winder when not in use.
Aug 23, 2010 | Watches
My new lucien Piccard 28116BK will not run. It is an automatic winder. If I swing it back and forth the the main wheel will start oscillating but will stop again in about a minute. I've tried to wind it...
You should be able to wind it manually. Pull out the crown to the winding position and wind fully. With any automatic watch you should do a manual wind periodically.
Aug 13, 2010 | Lucien Piccard 26024 Wrist Watch
My rolex datejust watch has stopped working...rolex watches don't operate on batteries right? Why has it stopped ticking?
mcdevito75 here, The answer is no, Rolex watches do not operate with a battery. Most Rolex watches are Automatic winding with the motion of your wrist / arm. Of course if you leave your Rolex on the dresser for say 30 hours, it will run down, simply hold the watch in your hand and with a gentle rocking motion say from 6--to 12 O'Clock for about 30 seconds, this will give your automatic Rolex an initial wind up, from there you just wear the watch and it will continealy wind itself. You may also have the non automatic Rolex in which case you would have to wind it dailey. If your Rolex will not run at all no matter what you try, Check out the repair service directory here at fixya, bottom of the page click on repair service directory then watches.
Aug 01, 2010 | Watches
Emporio armani 4211
mcdevito75 here, There are 2 ways to wind your Armani Emporio watch, I'm figureing it"s an automatic watch, on some automatics you can start an initial ticking by winding the stem in any direction, if when you wind the stem you feel any resistance then this is the type of automatic watch you Start with about 20--30 winds of the watch. If on the other hand when winding the stem feels very loose and free, no resistance at all, then this is the type of automatic that relize on pure wrist and arm motion to start ticking, simply hold the watch in your hand and make small circle motions, or rocking motion, you should detect something moveing inside the watch, this is the winding counter balncer it's normal, rock or circle the watch for approx. 30 seconds to get it started. In both cases, after the watch starts, the motion of your wrist / arm keeps it wound as you wear it.
Jul 10, 2010 | Giorgio Armani Emporio Armani watches...
WILL RUN A SHORT TIME THEN STOP
mcdevito75 here, I would imagine your Rolex is an automatic, not all Rolexes are. After 2 days not running at all your Rolex needs a very good start not just putting it on and that"s it. Sorry to say!, I would ask you to do this, With your watch close to your ear I would like you to wind the watch, listen closely, if you haer a clicking or a drag sound you know you have to give about 20 winds to your watch before you put it on, after the 20 winds the automatic takes over. If the stem just spins and no sound, Click or drag, then your rolex is fully automatic, after you put it on you"ll have to ttwist your wrist back and forth to get the automatic moveing to wind your watch somewhat. Twist your wrist back and forth maybe 20--30 times, this way your watch has an initial wind and as you wear it the winding continues with the motion of your wrist, after it"s wound pretty good if it stops and goes, have the watch serviced.
Jul 01, 2010 | Rolex Day-Date President 118238 Wristwatch
Bulova Watch Millennia Motion 96B17 - stops - needs battery????
Dude, of course it stops during the night - it's a perpetual motion / kinetic watch. It doesn't have a conventional battery. When you move your arm (while wearing it), the natural motion of your arm will 'automagically' wind the watch. There's nothing wrong with it - these types of watches always have to be re-set in the morning if you don't wear it to bed (or you don't toss and turn in bed).
May 30, 2009 | Bulova Millennia World Time 98G66 Wrist...
I can't get my head around how to manually wind my Fossil ME1020
You are not supposed to wind the watch, in simply winds itself with the motion of your wrist. A weighted wheel located in the back of the watch winds a spring that powers the second hand. The minute and hour is power by quartz and a battery.
Apr 05, 2009 | Fossil ME1020 watch
Cartier Pasha W3103755 Wristwatch Logo
102 people viewed this question
Top Cartier Watches Experts
k24674
Jimmy Accardi
Are you a Cartier Watch Expert? Answer questions, earn points and help others
