Question about CTX S762A 17" LCD Monitor
Hello Guys, i my monitor will not display anything even if the system unit is running? and processor is abnormally heating, i just bought a new vga card and it started this, i have intel core 2 duo @ 1.86GHZ, Asus Radeon EAH5670 VGA, 2GB RAM. The VGA require 400W power and i have 450, for the past 3 days my pc has not been stable, but i was working after i installed the new VGA. But now it wont display and the processor keeps heating. Please help a brother out, if you have any idea send to raskabroni@yahoo.com
  • 31 Answers
Hurm,try change the processor fan.. or your monitor did not support the vga card.... monitor have the resolution.. or you can change the power supply to 500w..
Posted on Oct 08, 2010
I have hp compaq 6910p laptop, which worked at its best for several weeks after it was bought. but few days back it started freezing, taking too much time in startup and to run programs aswel. I was t
Instructions
Plug one end of the VGA connection cable into the VGA port on the external display. Tighten the knobs on the VGA connector to secure the cable to the monitor.
Plug the other end of the VGA connection cable into the VGA port on the on your Compaq 6910P. The VGA port is located on the back of the device. Tighten the knobs on the VGA connector to secure the cable to the laptop.
Plug the external display's power cord into a wall outlet. Power on the device by clicking its "Power" button.
Boot your Compaq 6910P.
5
Click on the "Start" button in your task menu.
6
Select "Control Panel," then click "Appearance and Personalization."
7
Click "Personalization" in the window that appears.
8
Select "Display Settings."
9
Select "Mirrored" from the New Display Detected dialog box to have your displays mirror each other.
10
Select "Extended" from the New Display Detected dialog box to have your display function like one, large workspace.
11
Select "External Display Only" from the New Display Detected dialog box to use only your external monitor.
12
Click the "OK" button to keep the changes and exit the setup.
Jan 10, 2013 | HP Compaq 6910p Notebook PC PC Notebook
Laptop won't boot
It sounds like a motherboard problem.
Just like you sometimes need a mechanic to repair your car,sometimes you do need a technician to diagnose and identify the fault or faultson your computer. Not only does a good service technican have the experience todeal with this type of problem, they also have the equipment that allows themto look at things the average computer user can't see, and he has a collectionof replacement parts that can be used to quickly test individual components onyour computer.
Apr 13, 2012 | HP Pavilion Computers & Internet
Why is my lap top screen covered with vertical red stripes/HP Pavilion dv9825nr
Ik EXACTLY why u have lines in ur laptop computer screen. how many years have you had it? if u have had it for quite sometime or someone sat threw, or jumped on it but that would crack the screen if u hae like 1 or 2 lines, idk what side mine were on the left and it started 1 line, 2 lines, 3 lines, now my moms dell laptop that we have had for a loong time has about 8 line 3/4 of the screen. It means that ur computer is about to go on u, it could crash like the hard drive but im 100% sure ur screen is just old and im warning u i would go out if u want ur info and get an external harddrive hook it up with a usb while there are only a few lines and same as a USB just put everything onto an external harddrive. the are cheap now. they are a square and they have to be a bigger GB than what ur Computer has, like if ur comp has 250gb of memory then get a 300 gb external hard drive. U better off getting the external harddrive and get a new laptop and put ur info on it instead of paying like $25 an hr to have a new screen put in plus $300 for the screen. u can geta new one for $300. good luck and that is the problem 1,000,000,000% sure
Feb 26, 2012 | HP Pavilion DV9825NR Notebook
Sony VAIO vgn cs series laptop, after changing the fan - no display
You could have accidently pulled the lead out that connects the screen to the motherboard, or just loosened it.
It could also be the screen backlight or inverter.
Jan 29, 2012 | Computers & Internet
Hey guys. Built a new computer and decided to add a video card instead of using the onboard video. Bought an EVGA Geforce GTX570 SC 1280MB GDDR5. Pretty sweet. But I cant get it to work. Got the...
Hello, Your on-board vga is still active and by default your computer will use this for displaying graphics. You will need to disable it to use your new card or change priority so that it searches for an external display first. To do this restart your computer, go into the bios and turn it off or change priority. Refer to your computer manual for the proper location of this setting.
Please bear in mind that some systems do not give you the option of disabling your on-board vga. I believe this is to allow you to still use your computer should the external vga fail.
Hope this helps, thanks for using FixYa
Aug 31, 2011 | Evga GeForce GTX 570 HD 1280MB GDDR5 SC...
Hi guys, i need some advice on setuping my new system. here is the spec of my new system: casing- collermaster HAF 912 motherboard- MSI P67A-GD55 processor- INTEL I5 3.1 GHZ ram- 4gb x 4 total...
YES THIS GRAPHIC CARD WILL BE ACCEPTED BY MSI P67A-GD55 BOARD..
BELOW SHOWN IMAGE IS A VIEW OF NVIDIA GEFORCE GTS 450
THIS CARD ONLY SUPPORTS TWO DISPLAYS AT A TIME
May 24, 2011 | MSI N450GTS-M2D1GD5/OC GeForce GTS 450...
I run the computer for about 30 min. sudenly it will stop showing anything in the monitor i try it to open but there is no boot and no picture , and i check even the processor heat sink is not produce heat
hmm!! there is problem with your processor's heat sink only!!! your system is getting over heated so it shut downs automatically to prevent damage!! i have also gone through this problem!!! try changing the processor's fan!!
Oct 24, 2009 | ASUS A8N-SLI Deluxe Motherboard
I have the same problem
Dear! If monitor showes power but not showes display its means that monitor requires heat and it very better if you can give sun-rays. I assure your monitor will work if you do that for 4 hours. Check your monitor sepreatly with another system or computer if it works that means your VGA card not supported so you should change your VGA card but first check your monitor.
Thank You
Jul 30, 2009 | ASUS P5RD1-VM Motherboard
Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Jul 21, 2009 | LG 22" FLATRON LCD Monitor
Dual monitors in XP Pro - HP Pavilion zd7000 laptop & I-Inc CY199 monitor
in that case u need a video hub, like : display booster. we call it a vga display booster. this may increase the quality of a picture. because when we attach any display unit, the image appears in two portion. it's gain is to low. to make it more sharp, monitor itself add some colour to that picture. the vga signal is fixed from inside of the monitor with resistance, so u can't make any variations in picture. that's why u guys need that VGA booster.
Jan 14, 2008 | Computers & Internet
CTX S762A 17" LCD Monitor Logo
Top CTX Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Martin Murray
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
