Question about Candy CPCA240FFK Bottom Freezer Refrigerator
Fridge freezer icing up
Candy cpc240ffk ,iceing up having to turn the fridge/freezer off evertday for couple of hours everyday.please let me what could be problem.thanks
  • jim mc cormick Jul 15, 2008
    candy f/freezer mod. cpca240ffk is running continuously & freezing/icing .
    do i need to replace the temp sensing probe or or the electronic board behind front panel. how can i test the probe?
    the unit runs continuously, do i need to replace the temperature reading probe or the electronic control panel on the front of the unit
I have a Baumatic fridge freezer and I need to defrost the freezer. We have no Instructions please advise
Posted on Jul 15, 2008
    Genius:
  • 1,122 Answers
YOUR DEFROST TIMER COULD BE STUCK,FIND IT ON BACK OR FRONT OR INSIDE TURN SLOW CLOCKWISE TILL CLICK,IF FRIG. IS RUNNING IT SHOULD TURN OFF AND GO TO DEFROST,ALSO THE DEFROST HEATER IN FREEZER COULD BE BAD,OR THE TERMINATOR IN FREEZER COULD BE BAD OR THE FREEZER FAN MIGHT HAVE STOPPED,LET ME KNOW WHAT YOU KIND,THANKS-MIKE
Posted on May 30, 2008
  • MIKE major Jun 03, 2008
    don't know why you gave me thanks for trying i give you all the info you needed to fix it!!!!!!!! mike
Fridge Icing up on N1B Candy frost free fridge freezer
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Sep 02, 2009 | Refrigerators
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 | Freezers
Candy Fridge - The freezer part is not cold enough, fridge ok!
A couple of things to check-
- Is the condensor cooling fan running? This will be located to push air through the external cooling coils, wherever they are located.
- Does the auto-defrost timer work? It may have failed and stayed in a position that has left the heating elements (for defrosting) turned on.
- Does it seem to be running way too long and not turning off as it once did? This could indicate either a loss of coolant (would need recharge and leak detection) or the compressor is reaching its end of life. If the latter is the problem, expect a cost of $200-$400 US.
Apr 07, 2009 | Whirlpool Gold Series GI15NDXT 15"...
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH & KEEPS RUNNIN
remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
Mar 31, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
My Candy fridge freezer CPC240FFK seems to turn itself off - light goes out and no sound. If I turn it up to Super it does work, but the fridge is too cold, and when I turn it down it goes off again. Now...
i recently found out that there is a component in a fidge called a control board this basically tells the fridge what to do i recently had a variety of problems with my candy F/F starting with the interior light not working it turned out to be the CB had this replaced and now working fine i have been told a CB (control board) can pack up from somethng as simple as a light bub blowing so possibly might be your solution all the best
dmb
Jan 02, 2009 | Candy CPCA240FFK Bottom Freezer...
Ice is building up on the back wall of fridge
Option 1 defrost fridge manually by switching off power for 24 hours, allowing built up ice & frost to melt.
Option 2 Switch off mains power and using a hair drier blow hot air into the freezer supply vents. This shuold shift the ice in a couple of hours
Nov 12, 2008 | Candy CPCA240FFK Bottom Freezer...
Candy CFC 290 FF
Candy frost free freezers have a 'self defrost' mechanism to remove excess ice build up. What happens is the ice gets packed around the heat exchanger in the back of the freezer and it can't self defrost. This is easy to fix but will require the fridge to be left switched off with the door open for a couple of days so all the ice can melt. Make sure you left the appliance off for as long as you can as if there is any ice left the problem will just come back.
Aug 30, 2008 | Candy CPCA270FFK Bottom Freezer...
Iceing up
switch off your refrigerator.. and open the frizeer door. it will start melting and after 3 hour it will completly defrosted
Jul 04, 2008 | Candy CPCA270FFK Bottom Freezer...
It sounds like a Freon leak. The compressor is running and it gets a little cold. THis is not something you can fix yourself. You have to have certification to buy freon and gauges and know exactly how to use them. Besides in most cases you can't find the leak and will have to keep recharging it.
Jun 28, 2008 | Freezers
Candy CPCA240FFK Bottom Freezer Refrigerator Logo
714 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
