Need to remove computer case on the Sony VPCM121AX/L to install a RAM upgrade. It has six screws on the bottom, which I removed. But I cannot tell how to get the cover off in order to get to the mamory card. Not sure if I slide it, pry it up, push some release button or what. I am trying not to break it. I contacted sony and they would not tell me. They said I have to bring it to one of their repair sites. the closes is 200 miles away. There has to be an easy way to do it, but I cannot find any help via google search.
  • 2427 Answers
SOURCE: Computer won't power on right away
Wll it could be your pci controller is damaged.. (In thic case the only solution is to buy a new board)
Or you bios might need flashing..
Unplug your system
Open up the system,
put back in your network card
remove the battery on the main board
hit the power button 7 times
replace the battery
plug it back in and try to boot now
When it boots, you need to enter the setup and load your default settings then save and exit..
Posted on Jan 24, 2008
suisboy
  • 175 Answers
SOURCE: p4m800-m7 Rev:3.1 RAM PROBLEM!
the problem is with the new ram.
its phsically damged.
may be little bit that you cant see it.
try checking the other 1GB ram.
Posted on Nov 08, 2008
colliewob
  • 781 Answers
SOURCE: Sony Vaio not detecting 512Mb sticks as 256Mb
Check in BIOS to see if set correctly
Posted on Nov 12, 2008
techcrazy
  • 72 Answers
SOURCE: Power to everything but CPU fan and case fan - won't boot
Hi this is tech crazy
The solution to the problem is as follows
The main reason for CPU fan overworking or not working is due to the load we put on the syatem while operating.So,the first reason for fan not working may be due to the SMPS malfunctionality.Better check out for it.The reason if fan is working but Overworking is due to viruses is system.So go in for format
Hope this solution helps you
Please do rate me on the above said solution
Posted on Feb 04, 2009
bronk50
  • 27725 Answers
SOURCE: tried to upgrade my ram
what type of ram did you upgrade with it should have been DDR and keep the same brand/type of ram modules the same check the ram sockets make sure they are clean and the ram is securely seated The ram modules should have either of these 2 the same 1 GB 184-pin DIMM DDR PC 2700 memory module 1 GB 184-pin DIMM DDR PC 3200 memory module
Posted on Jul 01, 2011
How do you install a macintosh internal Superdrive CD-DVD in a macbook pro?
Assuming you are wanting to replace a faulty drive, turn the computer off and then flip it upside down. With a small eyeglasses phillips-head screwdriver, remove the 10 tiny scores on the bottom of the case. Be sure to arrange the screws in such a way that you replace the screws in the spots you took them out because they sometimes don't seat flush when you put them in difference holes.
Locate the super drive. Disconnect the SATA cable and power cable (they may be one harness or two separate plugs). Remove the screws that hold the drive in place. Install the new drive, replace screws and connect SATA and power.
Replace the case bottom and secure with the screws you removed earlier.
The whole project should take less than 15 minutes. You might want to consider upgrading your memory while you have the case apart. It's very simple, and the memory is pretty cheap these days.
Aug 12, 2015 | Computers & Internet
HOW TO UPGRADE RAM ON VAIO VPCM121AX LAPTOP
Memory Upgrade for Sony VAIO VPCM121AX Netbook Laptop, the Sony VAIO VPCM121AX Netbook Laptop takes the PC2-6400 DDR2 SDRAM SODIMM 200pin memory Memory Type, and comes installed with 1GB (Removable) of Memory.
You can upgrade your Sony VAIO VPCM121AX Netbook Laptop to up to a maximum of 2GB Memory, the system has 1 Socket to install Memory, already with 1GB (Removable) standard Memory installed.
For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
Power off the computer, and unplug it from the power source. Close the computer and turn it over.
Slide off the battery cover and remove the battery.
Locate the memory bay and remove the screws in the cover.
Remove your old RAM board(s) by pushing the metal clips and holding it down and outwards until the RAM board pops up. Then pull it out at a 30-degree angle. (If you only need to add more RAM to your existing RAM and you have enough available empty RAM slots, you will not need to remove the RAM.)
5
Insert the new RAM board into an empty slot at a 30-degree angle until you hear it click. Then push it flat down into the slot.
6
Replace the cover and screw it back in.
Upgrade the Sony VAIO Hard Drive
7
Locate the hard drive bay and remove the screws from the cover. Then slide the cover off.
8
Pull the hard drive out of the bay.
9
Remove the screw securing the hard drive with the magnetic screwdriver.
10
Pull the hard drive out of the bay by the black tab connected to it.
11
Re-insert your new hard drive into the bay and replace the cover.
hope it helps
Jul 15, 2012 | HP Pavilion dv7 Keyboard (483275-001)
How do I upgrade my ram on my Gateway All in one zx4250?
I too purchased a Gateway ZX4250 and a 4 GB RAM upgrade kit. It took me awhile to figure out how to open the case. Here is what I found.
1) Remove the two rubber pads at the bottom of the case (don't worry they pop right back on).
2) Open the small back cover.
3) Remove the one screw.
*****CAREFUL****
4) This part is a little difficult but just be careful not to use too much force. Take two small flat head screwdrivers and slowly separate the plastic silver front panel from the plastic black back panel. Start at the bottom where the two rubber pads were removed. Work your way around the case, you can see how the clips are connecting the two panels as you work your way around the all-in-one. It shouldn't be too hard just be careful on how much force you use.
5) Once the panels are separated you can now access the hard drive, optical drive and some other components.
6) Disconnect the Hard drive sata cable from the motherboard.
7) Disconnect the other cable right next to the sata cable on the motherboard (I'm not sure as to the purpose of this cable.
8) Remove the screws from the metal plate covering the motherboard. Take careful note that a grounding cable is connected to one screw.
9) Install your RAM.
10) Reverse the procedure to put everything back together.
This whole procedure to upgrade my RAM took about 15 minutes. I hope this helps some of you that are trying to upgrade your RAM. If you have any questions PM me.
Jan 03, 2012 | Gateway ZX493131e Notebook
How to open and upgrade RAM memory of gateway netbook model LT2704u?
This netbook is really the Acer Aspire One D255. You have to pop off the keyboard, then remove 4 screws that hold the back panel in place, which will allow you to remove that back panel in order to get to the memory.
Here's a video - blurry but it tells the story: http://www.youtube.com/watch?v=6KYNTvF0-5M
A better video on removing he keyboard: http://www.youtube.com/watch?v=FoTwln2SyQ4
Mar 01, 2011 | Gateway Computers & Internet
How to open the case to upgrade rams
to open your cae make sure you unplug your power cable so that we can lesser the error..
first you need a scew driver...commonly screw driver is needed,
just remove the two scte in the back of your casing..then open it...inside you will surely see your old ram..remove it if you want or try to put the new one with the old one..
try your pc if it will turn on and go to your windows...
sometimes the it will not boot up,because the memories are not compatible with each other...
you'll need to replace the older one with the new one...
hope i've help you.. rate me,,
Feb 05, 2010 | Gateway 7200X PC Desktop
S7310n disassemble
This is HP Support, and the download page for the Upgrading and Servicing Guide,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=1156509&
On this page scroll down to - Upgrading and Serving Guide, and left-click on it.
(Second file listed)
This is a PDF file download. The computer you are using has Adobe Reader on it, which uses PDF files.
After you click on the Upgrading and Servicing Guide, file name, you will Not see anything happening for up to 30 seconds, or so.
Be patient, as the file is downloading in the background.
The Upgrading and Servicing Guide tells you, and shows you, how to open the computer case. (Page 7)
Barring that you are not able to download this PDF file, I will attempt to tell you how to open the computer case. (If you are using a Dial Up network connection, you may be as old as me, before the file downloads)
1) Computer off unplug the power cable FROM the surge protector. (Not shouting)
THEN unplug the power cable from the back of the computer. (Power Supply)
Now unplug all cables connected to the computer.
2) Lay the computer on a towel on top of a table. Keeps the table, and the computer from being scratched.
Lay the computer on it's Right side. (Computer facing you, the right side is to the right. Hey, don't laugh, lol!)
Loosen and remove the three computer cover screws, on the back of the computer's case.
The computer cover that removes is an L shape. It comes down the Left side from the top, and wraps under the bottom.
Looking at the Top/Back of the computer, there is a screw to remove on the Top, of the Left side of the computer case. (Top/Left side corner)
Looking at the Bottom/Back of the computer, there is a screw to remove from the Bottom, of the Left side.
(Bottom/Left side corner)
Looking at the Bottom/Back of the computer, there is a screw to remove from the Bottom, of the Right side.
(Bottom/Right side corner)
After these three screws are removed, the Left side of the computer cover is slid back about 1/2 inch, (1.25cm), and lifted straight up.
BEFORE you reach inside! (Not shouting)
Your body carries STATIC electricity.
Static can fry out, (Short Circuit), the hardware components inside the computer.
TOUCH the metal frame of the open computer case, to relieve your body of Static electricity.
If you get up, walk away, then return, Touch the metal frame again.
Now, do you wish to disassemble this desktop computer completely, or just remove, and replace a few hardware components?
The above Upgrading and Serving Guide from HP Support tells you, and shows you,
1) How to remove, and replace the computer cover
2) How to remove, and replace Ram Memory
3) How to remove, and replace an optical drive.
(CD/DVD Drive)
4) How to remove, and replace a PCI card, that is in a white PCI expansion slot, on the motherboard.
5) How to remove, and replace the CMOS battery
6) How to remove, and replace a Harddrive
Should you need further disassembly guidance, let me know in a comment.
Feb 01, 2010 | HP Pavilion s7310n (EN996AA) PC Desktop
I want to upgrade my ram on the dimension 4500. how do i open the computer to replace the 256mb with 2 each 512mb chips
unplug your pc from power.
on the back of your case there are two screws on the right. one top and one at the bottom. unscrew these and remove the side of the case.
then you will see the motherboard. to remove the rams there are two plastics on each end of the ram. push them aside and remove the ram.
see here for video
http://www.ehow.com/video_4445703_remove-ram-upgrade-motherboard.html
Jan 21, 2010 | Computers & Internet
How do you open a compaq presario sr1630nx computer to install memory upgrades
Viewing the back of your computer, you will see a large thumb screw, on the right side of the computer case.
It's to the right of that round ventilation opening. (Round shape with multiple holes in it)
Unscrew the thumb screw to the Left, to loosen it.
The side panel that the thumb screw is in, pulls back towards the rear of the computer.
If you look, there is a place to put your fingers at the end of the side panel.
(Raised 'Hump' in the sheet metal of the panel)
Hold the top of the computer case with one hand, pull the side panel back with the other hand.
NOTE*
The computer MUST be unplugged from power before proceeding!
Not only is there a possible issue for Your safety, but also the computer's!
You will fry out the Ram Memory stick/s if you remove, or install with the computer plugged into power.
Also,......there is an Anti-Static issue that needs to be addressed, BEFORE you reach inside your computer
Your body carries Static electricity.
Static will fry out the hardware components inside a computer.
(In a Flash!)
Work on a table. Computer unplugged from power, computer case open. TOUCH the metal frame of the computer case BEFORE you reach inside.
TOUCH the metal frame Before, you take those ram sticks out of their protective antistatic bags.
Should you get up for any reason, walk away, then return, Touch the metal frame again.
Refrain from touching the gold plated contact pins, on the bottom of the ram stick.
You can handle the ram stick anywhere, but on those contact pins.
The ram stick is coated with a see-through plastic.
The contact pins are not.
Should you need advice on how to remove, and install ram memory, please state so in a comment. (Top right of page)
This is HP Support, and the download page for the -
Upgrading and Servicing Guide, for the Compaq Presario SR1630NX,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=1122478&
On this page scroll down to - Upgrading and Servicing Guide.
Left-click right on the name.
This is a PDF file download. Give it a few seconds.
After you see the first page, you will note there is a download progress bar.
Let the file download all the way Before looking through it.
Should you wish to save this file to your computer, please come back, and state so in a comment.
The Upgrading and Servicing Guide has illustrations, and instructions for;
1) Opening the computer case. (Side panel)
2) Removing the Front Panel
3) Locating hardware components inside the computer
4) Removing and Adding a Drive. (Harddrive and Optical Drive)
5) Adding Memory
And a host of other information you may find useful.
Jan 06, 2010 | HP Compaq Presario SR1630NX PC Desktop
Help to upgrade memory of Dell Dimension 8100
Im sure you mean 1GB of ram.
Upgrading ram is possibly the easiest upgrade to a pc.Firstly shut down the computer and remove the wall plug.
Remove the casing
Make sure you touch something metal away from the case before entering the chassis of the computer... anti static wristbands are good.
As soon as you open the case you will see the dimm slots where the ram goes.
You will find two plastic clips on each ram module, just pull these back to release the ram and insert the new ram.You may need to push firmly down to lock them in.The clips will auto lock.
Just be careful not to push to hard as to damage the mainboard.
Nov 11, 2009 | Dell Computers & Internet
I want to add RAM, but I haven't yet found the slots. Can someone tell me where they are?
The slot will be on the bottom (the part of the laptop that sits on the desk). Remove the screw(s) that are holding the cover and you will see the existing RAM (usually a green module about 2 inches in length).
Apr 13, 2009 | Computers & Internet
Computers & Internet Logo
375 people viewed this question
David Payne
David Payne
