Question about Kodak DC290 Zoom Digital Camera
When press power, it turns off inmediately - Kodak DC290 Zoom Digital Camera
    Brigadier General:
  • 3,006 Answers
It's most likely that your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Kodak service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 08, 2010
My pc turns on and inmediately turns off
see if the fan on cpu is working make sure that the cpu has cooling grease. if the heatsink not big enought it will shut down just like that ok
Nov 10, 2013 | ECS Mcp73vt-pm Motherboard Mcp73t-am...
Hp xw6200 orange blinking power light
See the following manual:
http://h50146.www5.hp.com/lib/doc/manual/workstation/hp_workstation/c00213035.pdf
Jan 25, 2013 | HP CTO HP Workstation XW6200 Base...
Treadmill will turn on then quickly stops
by lack of maintenance LUBE schedule in your deck belt, the machine protect itself for electronic system. LUBE inmediately the deck belt, Maybe you have a WORN deck belt.
2) LUBE the rollerrs bearing too.
3) Test the input voltage motor, if there are the motor need repair.
4) Test the drive belt motor, and adjust it or repair or replace.
5) Test the output voltage board, for input voltage motor, if there are NOT voltage the board is faulty.
God bless you
Nov 27, 2012 | Exercise & Fitness
Tread mill wont turn on. it was on then while in use the screen flashed on and off then treadmill shut down and has not turned back on. tried reset button then unpluging for a while but still does not turn...
Dear Sir:
Thank you by your problem, I will help you inmediately.
Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor
is plugged into a properly grounded outlet . Use only a single-outlet surge suppressor
that is UL 1449 listed as a transient voltage surge suppressor (TVSS). The surge suppressor
must have a UL suppressed voltage rating of 400 volts or less and a minimum surge dissipation
of 450 joules. The surge suppressor must be electrically rated for 120 volts AC and 15 amps.
Important: The treadmill is not compatible with GFCI-equipped outlets.
2)After the power cord has been plugged in, make sure that the key is fully inserted into the console.
3)Check the circuit breaker located on the treadmill
near the power cord. If the switch protrudes as
shown, the circuit breaker has tripped. To reset the
circuit breaker, wait for five minutes and then press
the switch back in.
4)Check the on/off switch located on the treadmill
near the power cord. The switch must be in the on
position.
I hope you resolve this. Otherwise, try to reach me. Inmediately.
sincerely.
E.Cuadra
Sep 13, 2011 | Nordic Track NordicTrack Elite zi...
HP VP6111 dlp projector turns on and shuts off inmediately
I think try to check the power supply of the projector and also check if its overheating.
Apr 21, 2011 | Computers & Internet
How do i restore to factory settings on windows 7 starter on a dell inspiron mini?
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps
Feb 01, 2011 | Dell Computers & Internet
Viewsonic VA703 B, the problem is that I was normally using my computer, suddenly the screen got a "fuzzy" display for a second and inmediately turned off. I proceeded to get it on again, but the power led...
angepor, Might need to visit YOUTUBE for video clips on how to refurbish the power supply / inverter board inside the 703b! Look for electrolytic filter capacitors with swollen tops on them. All should be flat!! Also note the name beand printed on the side of the capacitors and let me know with a reply to this response.
12fixlouie
Sep 21, 2010 | ViewSonic VA703B LCD Monitor
My computer doesn't power-up
Sounds like motherboard or cpu have given up ,try booting with no ram checking for beeps,vga etc
Jan 09, 2009 | Intel D915GAG Motherboard
Router WRT54G no Power led on
HAVE YOU PRESSED THE RESET BUTTON ON REAR OF ROUTER (LEFT SIDE).IF NOT TRY THAT OR FOR MORE INFO CONTACT TECH SUPPORT AThttp://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1149562300349&pagename=Linksys%2FCommon%2FVisitorWrapperRICHARDM69
Jan 03, 2009 | Linksys Wireless-G WRT54G Router
Kodak DC290 Zoom Digital Camera Logo
81 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
