AMC cd8a player comes up with disc in display and will not play. This inconsistent as sometimes it works fine. What is the answer?
SOURCE: Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Posted on Dec 21, 2007
SOURCE: dvd "unknown disc" message coming up
When Your DVD shows "LOADING" for quite some time and then if shows "UNKNOWN DISC" or "NO DISC", Open the cover of your DVD Player, Remove the flap over the disc by opening the screws. Remember that you are not keeping your eyes perpendicular to the lens. Now take Colin liquid in an ear buds and rub over the lens. Now with dry end of the bud, rinse it and make it dry. Keep the disc in the space provided for. Put on the Flap over the disc. And try to run it. I hope this would work fine.
Posted on Jul 13, 2009
stonephoenix
  • 563 Answers
SOURCE: No valid disc message displayed. Disc is spinning.
When a DVD player starts doing that, it either needs to be cleaned, or something is going wrong with the DVD mechanism inside of it. You can purchase DVD lens cleaner from any large retail store that has an electronics section. However, if you clean it and the problem persists, it will likely be cheaper to replace the unit rather than trying to have it repaired unless you're under warranty in which case any repair or exchange will be covered by said warranty. If you call the manufacturer they will give you your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 04, 2009
SOURCE: dvd player will not open disc, display lock
press eject and stop at the same time
Posted on Nov 11, 2009
SOURCE: Hyundai CD player displays ''error'' for all functions
my cd player in my sonata keep eject the cd can anybody help
SOS
Posted on Jan 12, 2011
Panasonic BD35 won't play blu ray discs, but will play dvds
You may have come close to what the issue is---Blu Ray for several design reasons is much more critical than DVD---seen a lot with this issue----either a dirty or a failing optical pickup in the unit---I know as when first started seeing it in our shop changed a few and since under warranty found the answer--optical unit was the problem---shortly after that they started just exchanging the cheaper units.
Jun 13, 2012 | Panasonic Televison & Video
I cant play cds on my wharfedale pcd 6200 usb
I think you need to press and hold the Play button (marked PLAY/PAUSE) to switch between CD playback and the USB port (you can store mp3 files on a USB stick and play them directly) on the front of the device.
Try inserting a disc, switching the unit to CD mode, press and hold Play until the display changes and the CD spins up...
Might just work?!
Duncan
Mar 22, 2009 | Audio Players & Recorders
RCA RS2620 - CD works well ocassionally and then not at all
Simple solution - a CD lens cleaner did the job. $11
Feb 19, 2009 | RCA RS2620 Single Cassette Deck
DVD player does not play
Display of my DAV C450 does not work
Jan 13, 2008 | Sony DAV-C450 System
Cant play
Not a solution as much as clues. I was given a SL PD588 by a friend 'cuz it stopped working. When I got around to checking it out it worked fine. Later it quit. It would rotate the turntable, load up a disc when you hit play, try to play the disc, fail, go to the next disc, etc. I pulled the cover, watched it try, could hear the lens seeking focus but the spindle wouldn't kick in and rotate. After cleaning the lens with no luck, my teenage observer decided he would spin the disc himself and maybe faster would help. Damn, if it didn't work. Sort of reminding the unit what it was supposed to do. However, not a permanent fix, 'cuz periodically it would forget and quit again. I would repeat the drill, basically giving it an assist to rotate the disc (clockwise), (maybe a few times) and it would be back functioning.
I have found the problem occurs if I leave the unit on too long, (especially in pause mode ie disc spinning, for a day or two). So I now power off when I'm thru playing discs.
Just went thru the drill again today, cover off, a little nudge to the spindle top when the disc loaded and back in business. Came to FixYa to see if anybody had an answer.
BTW, you can tell if the disc is playing correctly just by watching the track clock on the display.
Too bad the unit is so big 'cuz that means one is always stacking stuff on top of it.
Finally, and it's not like I haven't entirely dismantled this thing looking for an answer. Inside my unit is my long note on how to disassemble the mechanism.
Dec 23, 2007 | Technics SL-PD887 5-Disc CD Changer
Nov 25, 2007 | Televison & Video
Cannot continue to play klh dvd8350
The player mechanism has failed.
Jul 22, 2017 | KLH DVD8350 DVD Player
110 people viewed this question
 Grubhead
Grubhead
