Question about Canon PowerShot A710 IS Digital Camera
Canon Power Shot A710 is
Camera turns on but there is a black screen. The batteries are charged there is hand with parenthesis on the right side of the screen . Everything else is black. Try to take pictures, they are blank. HELP
  • 1 more comment
  • harlowinct Feb 14, 2009
    Is ther a solution to this problem?
  • kva888 Apr 11, 2009
    i do have the same problem.. the display screen in black but i can see all other symbols on the display.
    My display is goes black when i switch on the camera but other symbols are visible in the display.. only few times i get the display... can anyone help me to sort out this problem ?/
    Novelist:
  • 130 Answers
The hand with parenthesis is your image stabilization. It sounds like if your images are turning out black, you may need service.
Try hitting your display button a few times and see if anything shows up on the screen.
Posted on May 30, 2008
    Problem Solver:
  • 6 Answers
Wait a minute and press display button. If battery are faulty (or camera things that battery are faulty) camera start with black screen...
Posted on Feb 09, 2009
Hi,Have got got a canon(powershot a710 is) whenever i turn on the camera i get a few beep noises and the screen remain black with the message'lens error,restart the camera'....and it then turns off.....I...
The lens is jammed. Usually dust or grit gets in the mechanism and causes it to stick. Could try blowing down the side of the lens but it will probably need taking apart and cleaning. It is not an easy job to do but it might be worth trying as it would probably cost too much taking to a repair shop.
Jan 02, 2011 | Canon PowerShot A710 IS Digital Camera
I have a canon power shot A710IS but have lost the instruction manual could you please give me canon camera's address so i could send for one thank you
You can get the manuals from the canon website or download it from here..
PowerShot A710 IS Camera User Guide Basic (PDF, 1.34 MB) PSA710ISCUGba-EN.pdf
PowerShot A710 IS Camera User Guide Camera User Guide Advanced (PDF, 1.82 MB) PSA710ISCUGad-EN.pdf
Software Starter Guide For the Canon Digital Camera Solution Disk Version 29 (PDF, 3.75 MB) DCSDV29-EN.pdf
Direct Print User Guide (PDF, 1.17 MB) DPUG13_EN.pdf
Dec 05, 2010 | Canon PowerShot A710 IS Digital Camera
Camera Canon A710 IS started to ask set time date when turned on
When the camera is left without power for an extended period of time, the time and date settings are gone. You need to reset them and when you're finished, click the set/ok button twice.
Feb 25, 2010 | Canon PowerShot A710 IS Digital Camera
My canon A710 says it needs batteries no matter
My A710 did exactly the same thing. Spoke to Canon support. According to them you have to use Canon 2500 mah batteries (quite expensive - need a different charger as well). I've just bought new rechargable batteries from Sanyo (Eneloop pre-charged). And it solved my problem. I've also changed the batteries quite a few times and it never worked. But this did solve the problem for me.
Nov 04, 2009 | Canon PowerShot A710 IS Digital Camera
Power Shot A640
No, don't use superglue. Super glue will destroy plastic forever... Try other glue or double side scotch tape...
Sep 22, 2008 | Canon PowerShot A710 IS Digital Camera
Image Stabilisation Problem A710 IS
My advice, call Canon for service options.
Jun 19, 2008 | Canon PowerShot A710 IS Digital Camera
Canon Power Shot A 70
The "stuff" you see on your screen is some of the icons that Canon uses and is perfectly normal--the problem is that nothing from the outside world is getting to the screen, so it's black. Could be a broken CCD (not good--see www.usa.canon.com about fixing it) but let's try some easy stuff first, like pressing the DISP. button below your viewfinder once or twice. Also, eliminate the obvious: when you turn on the camera, does the lens pop out? Does the black metal lens cover open up so you can see the lens? Try removing and replacing the batteries. Also, if you feel adventurous, reset the camera to its defaults--i.e., wipe out any changes you may have made by accident--by removing/replacing the CR1220 date battery under the rubber cover at the side of the camera (you'll have to reset the time and date after you reinstall it). Good luck!
Apr 30, 2007 | Canon PowerShot A70 Digital Camera
Canon PowerShot A710 IS Digital Camera Logo
419 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
