Question about Electrolux Vacuums
I HAVE A LUX EPIC SERIES 3500. THERE IS NO POWER. CORD IS GOOD. SWITCH IS GOOD. NOT SURE WHAT TO LOOK FOR THANKS
If reset switch is worn out, how does the unit come apart to replace it?
Posted on Jun 22, 2008
    Problem Solver:
  • 7 Answers
Is there a reset switch in the back just below where the two halves of the body connect it is hidden if the cord is wound up.
Posted on Jun 02, 2008
What kind of bag for the epic series 3500 sr
"U" (upright) style bags, available at any Aerus Electrolux store, or from their consultants. These are the genuine bags made only by Home Solutions. Generic bags WILL decrease the lifespan of the motor.
Contact your local dealer. Free home delivery.
http://www.aerushome.com/storelocator/
Nov 15, 2010 | Electrolux Epic 3500 Vacuum
Does anyone know how to get the bottom off the electrolux Epic 3500 SR I need to check the beater brush? Thanks Jim
Actually the top comes off from the bottom base. Remove the underside screws, flip the machine over and gently remove the gray cover from the motor and brush assembly. Once inside, remove two more screws holding down the brush cover which is also part of the tunnel. It will reveal the brush, belt, and much dirt so be prepared.
Dec 06, 2009 | Electrolux Epic 3500 Vacuum
How to check the belt?
I have listed a link to the manual for your model and a link to the replacement belt you need. Hope it helps!
Manual
Electrolux Epic 3500 Replacement Belt
Oct 29, 2009 | Electrolux Epic 3500 Vacuum
My Electrolux series 3500 SR won't power on.
Most likely the cord has a broken wire you can't see (near the plug) or; the switch is bad.
Either is a fairly simple repair.
Charlie
Aug 21, 2009 | Electrolux Epic 3500 Vacuum
Replace power switch - Electrolux Epic series 6500
well, i post an answer in the wrong field, and i can't find it, so i will type one more time.
slide two vinyl side pieces off, and remove top halves. remove two screws from the switch, and remove it from top halve. between switch and outside button is a plastic rocker, which is broken. you will find two broken pieces, one spring for the rocker piece, and one small plastic rod, which goes inside of the spring for support. i do not know if part is available, but you can for quick fix like me, turn the switch on by the hand, assemble unit, and plug in, and plug out from the wall. whay? i dont have electrolux store close by.
john
Feb 21, 2009 | Electrolux Epic 6500 Vacuum
Electrolux Epic 3500 SR electrical problem
Does anyone know how to get the bottom off the Electrolux Epic 3500 SR????
I need to take a look at the beater brush???
Thanks Jim
Jan 01, 2009 | Electrolux Epic 3500 Vacuum
Electrolux epic series 3500 sr serial v87779 l
Sorry I didn't see this sooner. Your problem may be solved as simply as pushing the small red reset button exposed on top of the power head when you tilt the arm back. Very simple. Hope this helps.
John
Aug 16, 2008 | Vacuums
Vacuums Logo
96 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
