Question about Swintec 7040 Typewriter
Typewriter typing funky letters and ribbon catches on print wheel
  • srinker Nov 18, 2010
    NO. But thank you anyway.
    Genius:
  • 1,456 Answers
Hello
Check that each part of the typewriter is in place and functioning properly.
Check the ribbon and make sure that it is firmly in place, that it rolls smoothly and advances properly. Make sure the scroll wheel advances up and down without hesitation.
Look at all the internal parts to make sure they're not loose or crooked. If they are, adjust them to their proper settings. Check all parts for cleanliness and clean any necessary residue from ink, dust, or other substances that might make parts jam.
Identify the part of the typewriter causing the problem like the ribbon, keys, roller, or the daisy wheel. Check all of the settings on the typewriter to be sure they are correct, such as margins, spacing and function keys.
Verify that your parts are all made to work with the model of typewriter you are using. If you are unsure if a part, such as the ribbon, is compatible, check the manufacturer's website. They will often provide comprehensive lists of items made to work with their products, and often will tell you where you can purchase them if not directly from the company itself.
Replace any necessary products, such as the ink ribbon or correction ribbon. It may not be noticeable to the naked eye, but if either ribbon will not advance any further, it has been used up. Replace the ribbon(s) in the correct position with the correct models.
Posted on Nov 18, 2010
I have a brothers sx-4000 typewriter, i recently bought new ink ribbon. But for some reason my typewriter still does not print the letters at all. I know my typewriter is still good, I dont know why it...
There are two things that people mess up when changing printwheels and ribbons. Is that the ribbon is not in the guides properly. The other is that the latch the holds the type wheel is not locked in the forward position.
Nov 26, 2010 | Brother SX-4000 Typewriter
Swintec 7000 Typing Problem
Try Code comma, peroid or slash one of them will get you out of the overstrike ribbon mode.
DickyO
Jul 08, 2009 | Swintec 7040 Typewriter
Typewriter won't type
check to see that when yu replace the ribbon it has not slipped in front of the print ribbon and that you have not got the button for corection pressed by mistake it is using this to print you letters not the ink ribbon
Jun 11, 2009 | Brother ML-300 Typewriter
Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a
Try typing on a mulipart form. If it types on the copies and not the orinonal the ribbon is the problem. If it dosen't type on the copies then the plastic cap on the print solenoid is broken.
We sell the cap with installation instructions for 20.00 includes shipping.
DickyO
216-241-0027
Jun 02, 2009 | IBM Wheelwriter 30 Typewriter
My typewriter doesn't type..won't display letters, but keys work.
alot of the brother t/w's have 2 cam assemblies under ribbon holder. 1 operates the print hammer and 1 operates the correction ribbon lift. sometimes these will hang or lockup. sometimes turning on and off a few times will take care of it, but sometimes it needs to be worked on by a t/w tech. if you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
hth,
razors
Feb 27, 2009 | Brother Office Equipment & Supplies
When I type it is printing different letters than I am typing.
On most models there is a pitch switch 10.12.15.PS
you need to match the switch to what print wheel is in the typewriter. most common wheels are 10 or 12
move the switch to that area.
if that is not the problem take out the ribbon, corr. tape & print wheel. tuen on the typ. let it home, put the print wheel & ribbon ( Not the corr. tape) turn on let it home tray typing. if works O.K. put in the corr. tape .
Then you are good to go.
Jan 29, 2009 | Office Equipment & Supplies
Simth corona wordsmith typewriter typing charaqcters not letters
turn the power off. Remove the ribbon and print wheel & corr tape. turn the power on close cover let it home. open cover install the print wheel & ribbon try typing. if works reinstall the corr. tape. if not there will be a switch with 10.12.maybe 15 or PS make sher the pitch is in the same number as the print wheel. hope this works. C.W.H.
Jan 22, 2009 | IBM Wheelwriter 30 Typewriter
TYPING II IN PLACE OF LETTERS
the mark you are seeing is the print hammer hitting the paper. remove the ribbon. corr. tape & print wheel. turn on the typewriter. close cover let it home it's self. open cover put in print wheel. close cover let it nome. put in ribbon close cover. try typing if marks are still ther. you will need a new print wheel. if working then put in corr. tape or if you are better at spelling then me you will not need it
Jan 21, 2009 | Smith Corona Wordsmith 200 Typewriter
Erronous letters or numbers
Under the ribbon there is a motor that drives the print wheel try to get some light oil on the front and rear bearings (wd 40 usally works well) its a little hard to get to the rear one.
hope this helps
DickyO
Jan 29, 2008 | Lexmark Wheelwriter 1000 Typewriter
Swintec 7040 Typewriter Logo
223 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
