Hello, i have a yamaha p350 turntable my dad gave me and i just got a new needle for it. but i cant get the table to spin and he said theres some combination of buttons...do you know?
  • 42 Answers
SOURCE: sony ps-lx2 turntable clicks when spinning
It seems something may have come loose over time or history, but you will have to delve inside to see what it is. It sounds as though the fault should be obvious.
If you do not want to do this, a repair shop should have no problem. I assume that the deck is working ok otherwise.
Posted on Jan 25, 2009
  • 42 Answers
SOURCE: Cannot unlock the turntable after shipment
Your submission is incomplete. Please resubmit.
  • 189 Answers
SOURCE: brand new audio technica at-pl120
HELLO!
I don't know which country you are from, but if the mains plug has a fuse in it then replace it with the same type. If that does not do the trick take it back back where you bought it and get a refund or a replacement! There may well be an INTERNAL fuse inside the unit on the power supply unit which may be at fault. If it is under warranty don't open the turntable yourself - take it back - I WOULD!
All the best!
Posted on Jul 22, 2009
  • 1348 Answers
SOURCE: YAMAHA P-220 VINYL RECORDTURNTABLE SPEED PROBLEMS:- HOW CAN I
if you open the bottom,there is variable potentiometers for the speed adjustment.you need a strobe reference disc if you want it exact.
Posted on Aug 15, 2009
SOURCE: Technics SL-5 Turntable will not turn.
now iam using the technics sl-5 turntable.it is tonearm damaged.
replacement tonearm are available? or pl inform tonearm model number
Posted on May 12, 2010
HELP: Stopped spinning
It's likely the belt has slipped of and probably needs replacing. You can do this yourself. It will be found under the turntable matt. The trick though is fitting it back on. But you might find the instructions on-line (enter the model number into google search). Some people have even put YouTube video's on how to replace the belt on popular turntables.
Jun 11, 2014 | Crosley CR74 Turntable
Why does my crosley turntable not turn when I put the needle down on the record
If you manually put the needle on the record, you still have to push the power on button. If you are using the auto on and the turn table isn't turning, either the band from motor to turn table broke (or came off) or the motor for turn table stopped working. All this is as long as there is power to the unit.
May 15, 2014 | Crosley Audio Players & Recorders
Denon dp200usb skips new records
Do you have a a weightscale for the needle pressure, anti-skate right and the table straight. An overhang gauge and set the needle in the right angle. If that't ok make sure the record and needle is real clean, since you often don't see that piece of does which causes it.
Apr 16, 2014 | Denon DP200USB TURNTABLE W USB Turntables...
I cant unlock my lg p350 ..coz my brother entered many incorrect pass word..and it says there"too many pattern attempts!"to unlock ,sign in w/ ur google account..but i dont have an account,,experts i
Hello My Friend::
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 03, 2013 | LG P350 Optimus ME Cell Phone
HOW DO I INSTALL A TURNTABLE BELT FOR A SONY TURNTABLE
Under the felt of the turning section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
May 30, 2010 | Sony PS-LX250H Turntable
Turntable belt is off.
Under the felt of the turning platter section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
May 16, 2010 | Teac GF-600 Turntable
I have a new Yamaha RX-V365 receiver and an older technics turntable, regardless of input setup I cannot get any volume from the turntable, yet all other inputs like CD, Tuner are fine....amp issues in...
Some turn tables do not have a built in amp, especially the older ones, the sound goes from the needle to the output. If the amp your are using does not have a designated phono, turn table, input it may not have the turn table pre-amp built in. Some turn tables have to be grounded to the amp to work properly.
Aug 30, 2009 | Teac DC-D2800 Shelf System
Turn table wont spin.
if its a direct drive turntable then the motor is under the spindle as the spindle is a composite part of the actual motor? Its most likely burnt out i`m afraid? sorry
Jul 14, 2009 | Sony PS-LX250 Turntable
546 people viewed this question
 Grubhead
Grubhead
