Question about ASK Proxima DP6860 Plus Multimedia Projector
Proxima DP6860 is displaying a pink/purple bar on the right side of the screen. When projecting some text shows pink/purple shadowing. The bulb is new - Hitachi brand.
5 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: i have a proxima dp6860 color shadow
the lcd panel may be out of alignment. there really isn't a way adjust it easily. it'll need to go in for repair to an infocus service center. try av solutions in ny. they're really good.
i think it's www.avsolutionsny.com
Posted on Nov 24, 2009
Basti
  • 1447 Answers
SOURCE: multiple reddish pink vertical lines going from
Hi
We can check if the problem is on the hardware(projector) itself or if from source(device connected to projector) try to turn on projector without connecting any other devices to it. If you can still see the pink line- try to remove bulb and reinstall it. If all fails and pink line still visible, there is a problem with projector. If no line is present- check settings and change input signals.
Hope this helps
Posted on Mar 26, 2010
  • 23 Answers
SOURCE: Can the bulb out of Proxima DP6860 work in a
No they will not interchange.
The DP6860 takes a bulb number LAMP-030 and is a 250 watt bulb.
The DP6850 takes a bulb number LAMP-017 and is a 190 watt bulb.
If you could physically make them fit by some means, likely just the wattage difference would cause problems with the projector. These bulbs require much more electronics to light up than what a normal household bulb does. I'm assuming the projector would think the lamp is either burned out or worst case cause damage to the power supply in the projector.
Posted on Mar 30, 2010
Testimonial: "Thanks. "
Tengo mucha experiencia en reparacion de proyectores, hay dos cosas que pueden ser: 1- que tengas dañado un LCD ó
2- debes ingresar al menu de servicio donde existe una opcion para corregir el ghosting, esto puede corregir la falla. Lamentablemente no recuerdo como acceder al service menu. Espero alguien que lo recuerde o sepa nos lo haga saber. Saludos y Suerte.
Posted on Jun 09, 2010
Pink/burgandy dots or shadow on display screen Our church has a new PLC-XU48 - has 70 hours on the lamp life. we use for both video and text display. Last night when we switched from video to text; we...
Does it go away when you switch back to Video? if so then the issue appears to be related to the text mode. Text mode is usually for showing microsoft office documents from your PC, that kinda thing. If you have text within a video then you should leave it on video. It is normal to get the odd pixel burn out and the colors change and look pink or bright, in your manual it will say what the acceptable limit is usually less than 1% i forget what the norm is but a possibility some of the pixels have burnt out, i doubt this is a bulb issue as the bulb just projects what is sees on the small display screen inside. Check the lens is clean, if the item is under 2yrs old you are actually covered regardless of what warranty came with it, more so if you purchased this using a credit card, see martins money shop website for details of how to make a claim via your bank to get full refund, all electrical items are covered for 2yrs against manufacturing faults. You can try resetting everything to default and see if this helps.... another tip, never turn the projector off at the wall straight away after using, you must let the bulb slowly cool otherwise it can break, so always power off with remote or power button then wait until the bulb and fan has stopped before turning off at the wall to prolong the life of the machine. If the issue was the bulk you would not be seeing anything, sounds more like an issue with the mode and media your using but if the spots appear all the time in all modes then it points more towards a manufacturing fault, the display being burnt out in parts, thats my guess.... although if this is the case the fault will show in all modes.
Apr 07, 2014 | SanDisk Sanyo Plc Wxu700 - Lcd Projector
My Epson PowerLite 1725 projector has a wide green bar displayed in the middle of the screen with a purple shadow on its right. Do you think a bulb replacement would fix it?
im afraid that sounds like some dead pixels. and if thats the case then no a bulb wont fix it. call epson tech support and see if they will replace it for free.
Mar 05, 2011 | Canon LV-LP12 Projector Lamp for LV-S1,...
Multiple reddish pink vertical lines going from
take the top cover off and look for the 3 lcd ribbon cables plugged into thr main board. it is a pain in the ****, but the cable must be completely seated into the things on the main board. there should be little brown tabs on the connectors on the main board that you flip up or down, then make sure all lcd cable are pushed all the way in.
May 14, 2010 | ASK Proxima DP6860 Plus Multimedia...
Can the bulb out of Proxima DP6860 work in a DP6850?
Mar 30, 2010 | ASK Proxima DP6860 Plus Multimedia...
Hi
Hope this helps
Mar 26, 2010 | ASK Proxima DP6860 Plus Multimedia...
I have a proxima dp6860 color shadow
Nov 20, 2009 | ASK Proxima DP6860 Plus Multimedia...
A Dark Bar at the top of the screen that looks pink against white
the light engine is defective if you have black bars that look pink.
Sep 05, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Discolored image and lines...
I also am having the same problem. at first it only showed up after the projector was on for about 15 minutes. Now I get a purple vertical bar on the right of the screen. I also get vertical green bars spread across the screen.
Does anyone have a diagram of how this machine is assembled?
greg
Dec 17, 2007 | ASK Proxima DP6860 Plus Multimedia...
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
PINK/GREEN SHADOWS, LINES
Here is what I was able to find out about your problem from sony: This issue is usually caused by some type of nearby magnetic interference, such as unshielded stereo speakers placed too close to the TV. These spots can be small or large and will normally be red, green or blue, but sometimes appear purple or pink. They normally occur on the sides or corners of the screen, but can also appear in the middle. To resolve this issue, move any stereo speakers or other electronic devices away from the TV; a minimum of 2-3 feet is recommended. If the situation is not remedied immediately, unplug the power cord of the TV from the electrical outlet for 20-30 minutes; repeat this process one more time if the issue is not resolved the first time. If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer in your area. Hope this is helpful:)
Sep 04, 2007 | Sony KP-57HW40 57" Rear Projection...
ASK Proxima DP6860 Plus Multimedia Projector Logo
162 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
240cpa
Lyle Siemens
Lyle Siemens
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
