Question about Kenmore Ovens
Wall gas oven igniter does not work. i want to replace on my own - need guidance on how to.
  • 2,272 Answers
First unplug the stove. Remove the ovens racks & oven bottom, also the flame spreader. The spreader is the metal plate attached to the top of the burner. It will have a wing nut securing it to the burner. This is close to what you will see - picture.
Loosen or remove the screws securing the glow igniter to the burner. Follow the two wires attached to the igniter. At the end farthest from the igniter will be a wire pull apart quick disconnect. Disconnect the glow coil at that point.
Install the new coil exactly as you found the existing coil. Replace each part in reverse order. Plug in the stove and turn it on. The oven burner now should work.
Be advise that some new replacement igniters do not come with quick disconnect ends. In this case, it's okay to cut off the quick disconnect from the old igniter and attach it to the new igniter.
Simple clip off the wires several inches above the disconnect on the old igniter, attach to the wires of the new igniter and wire nut the two ends together. Porcelain wire nuts are best - picture.
Porcelain wire nuts parts help - click here.
Repeat the process to attach the other set of wires and wire nut them together. There is no positive nor negative {polarity} to be concerned with.
Glow igniters are fragile & they break easily. Handle and install the new igniter carefully. Glow igniters are a non returnable and non refundable electric component.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 08, 2010
Kenmore wall oven 3052
most likely the igniter is not working at 100% and the gas valve won't open unless it is at 100%. Replace the igniter first.
Aug 12, 2014 | Kenmore 24" Manual Clean Wall Oven 3052
Gas wall oven (Maytag) ignitor and glow coil do not heat up and no gas is coming on.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 16, 2011 | Ovens
The to oven bake doesn't work but the top Broil works. What ever brings on the igniter for the bake isn't working because I get ne power to the egniter. I don't have a wiring diagram to check any futher.
I replaced my Amana Gas wall oven Model AOGD2750E Lower Oven bake Igniter and temp sensor but still not working. I'm Thinking maybe the relay module is at fauly, Any suggestions, I need help!. Thanks
Jan 27, 2011 | Amana AOGD2750 Gas Double Oven
I smell gas when I turn on my oven. I replaced the gas line but have the same result.
Your Maytag wall oven is equipped with
pilotless ignition. Heat from the Glow Bar
ignitor lights the oven burner. With this type of
ignition system, the oven will not operate
during a power failure or if the wall oven is
disconnected from the wall outlet.
if it is plugged in and everything, your glow bar may be broken, which would mean you will either need to replace it, or get professional service.
Dec 25, 2010 | Maytag CWG3100A Gas Single Oven
Oven dont heat up
heatman101
Nov 23, 2010 | GE 24" Built-In Single Gas Wall Oven
My gas valve is not working. my igniter works at 120 volrs
Even though the ignitor glows it does not mean that it is working. It needs to pull X number of amps to allow the gas valve to open.
The ignitor is the first thing you need to replace.
This tip will help you to understand your problem.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
Jan 27, 2010 | Maytag 30" Built-In Double Electric Wall...
Oven does not ignite, nogas coming out
Most likely the ignitor needs replaced. Checking it with a meter will verify. If it is OPEN then replace the ignitor. IF it SHORTED then the gas safety valve will be bad also.
Eric
Sep 14, 2009 | Ovens
Our Frigidaire 24 in wall oven won't light. The igniter glows but there appears to not be any gas present.
The ignitor is weak and needs to be replaced. You can not tell by looking at it. You have to measure the amp draw through the ignitor.
Sep 01, 2009 | Frigidaire 24" Single Gas Wall Oven with...
Oven won't light.
Localwonder gave a more comprehensive answer, but I wanted to share my recent related experience too:
Same model: MGR5750BDW
Oven was not heating up, or would sometimes and not others. Broiler worked fine. The nice thing is that the broiler igniter and the oven igniter are the same part. So I swapped them until I could get a replacement part.
Before I did anything, I turned off the gas!
To take out the broiler igniter: there's one screw right near the front of the oven that holds the burner assembly in place. Remove that, gently pull the assembly off the gas nozzle off to the left. Then where the wires from the igniter go into the back wall, remove the screw that holds the little door, remove that little door, and then gently pull the wires through until the connector comes through the opening. I also found you can go behind the stove, remove the back panel (which is easy) and see the igniter's connector.
The oven one: remove the floor of the oven by lifting it at the back, and then lift it out towards the back of the oven. Then you can see the igniter at the back of the floor of the oven. remove the two mounting screws, and then gently pull the wires until the connector comes through the insulation.
The bad igniter looked like it had burned down to bare metal in a big patch...not sure if that's the actual problem, but in any event, I installed the good igniter in the bottom (gently pushing the reconnected connector through the insulation, and feeding as much of the wires down in there as well), and the bad igniter in the broiler position (since that was the easiest one to access and replace, it'll be easy enough to replace when I get the parts). Tested, and everything worked great. And I could watch the bad igniter light up, and never light, confirming that it was the igniter itself that was the problem.
The best part, for this stove anyway, -- the ONLY tool needed was a #2 phillips screwdriver. Really. All told, maybe an hour of work, nothing intense. And free -- so if they both worked, it would have spared me ordering a part that didn't need to be replaced!
Jul 22, 2009 | Maytag Amana 30 in. Electric Double Wall...
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Ovens Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
