Question about Fossil VT2654 Pocketwatch
I have an Ingersoll Quartz Mens Pocket Watch (90s vintage) and I cannot find the access slot to remove the back and change the battery. Nor does it have key divots for unscrewing. It is a #21001, and it's driving me nuts. I have tried prising the back off, but alas, it seems to be welded on (haha). Can someone please help me?
2 Suggested Answers
SOURCE: to replace battery of pocket watch
My son has a Timex pocket watch-I just got the back off with a very tiny flat-head screwdriver- the niche or indent you're looking for is almost indiscernible; look very closely, the edge of the back barely deviates from where it meets the edge of the front piece. Looks more like a flaw than an intentional point of entry
Posted on Nov 20, 2008
Replace the battery in an ingersoll japan movement
I expect the battery will be where it is to be found in most other watches. Remove the back of the case and the battery should be fairly simple to access.
Oct 21, 2017 | The Watches
How to place the back on
It is highly recommended that you take it to a jeweller's to replace the battery. If the battery is replaced you need to reset the watch by push/short internal reset switch after replacing battery.
Oct 14, 2015 | Timex Mens T2N723 Intelligent Quartz...
Changing the battery in an ADP1646
you need to push the crown or winder in before it will work
Dec 25, 2012 | Adidas Mens ADP1646 Black Resin Quartz...
How to change battery on TW493s steinhausen dunn horitzon quartz watch
The back screws on or it pops on by lifting it from a tab or indention. If there are slots on the back it screws on. Go to Harbor Freight an get the tool used to remove it. It is also avaiable on ebay. Just be careful.
Sep 26, 2011 | Steinhausen TW493S Dunn Horitzon Swiss...
Is it possible to convert a wind-up watch to battery(quartz ?) operation ? Thanks.
Unfortunately no, the only option is to remove the mechanical works and replace it with a quartz circuitry.
Sep 26, 2011 | Sterling J3E Hamilton Antique Pocket Watch
I have a Majestron quartz pocket watch. How do I replace the battery?
  • Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
  • Remove the circular watch battery out of the back of the watch.
  • Take the battery to any department store or watch store and purchase a new replacement battery.
  • Insert the new battery into the back of the watch.
  • Screw on or push on the back of the watch. Set the watch to the correct time.
  • Aug 23, 2010 | Watches
    2003 deer pocket watch Al Agnew is it wind up or Battery
    Often with battery powered watches the word "Quartz" will be written on the dial. In the abscent of that you can look at the mechanism inside (typically by removing the case back).
    Alternately (this may not be an absolute confirmation) with the winder in neutral position i.e. pressed all the way in, turn the crown (winding button) and if it spins freely it's probably quartz. Because unless it's broken most mechanical watches click as the watch is
    wound up (except some automatics which cant be crown wound).
    Plus if it's working and left unworn for a few days yet continues to run it's probably quartz.
    Please rate this solution.
    Jul 26, 2009 | Al Agnew Al Ag 3 Piece Pocket Watch...
    How do I change the quartz battery on a Longines La Grande Class
    Just unscrew the screw at the back if your model have screw if not the other one snap to open.Use a pocket knife then open it look the number battery and replaced it with same number battery. Its you use Renata battery it is swiss 3years to last.
    Hope it may helps;
    Regards;
    VOTIT
    Jun 16, 2009 | Longines La Grande Classique L4.709.2.42.9...
    Fossil VT2654 Pocketwatch Logo
    240 people viewed this question
    Top Fossil Watches Experts
    Ansel Alberto
    Ansel Alberto
    Lyle Siemens
    Lyle Siemens
    Are you a Fossil Watch Expert? Answer questions, earn points and help others
