Question about RCA Lyra RD1072 MP3 Player
Lock switch fell out, unit is now stuck in lock mode and will not turn on. Is there any way to disengage the lock and make the unit useable again?
Get a screw driver and push it up hard it should work than
Posted on Mar 24, 2011
Craftsmen garage door opener stuck in lock mode
Push and hold the lock button on the wall console for 3 seconds and that will unlock it.
Feb 13, 2015 | Craftsman 1/2 HP CHain Drive Garage Door...
Center Differential Lock Stuck
Yes it will, once no power is going to it it should or it could remain locked as well Give it a try . But you should have a look at the relay
1 2
3 4
that is what the pins should look lik 1 - 4 should power it
try grounding pins 1 - 4 this should lick or unlock the diff..
Jul 15, 2008 | 2002 Lexus LX 470
I cannot scan with my scanner: " it says RELEASE THE LOCK SWITCH,DETACH THE USB CABLE
Hi ,
Disconnect your unit from your pc ( usb and power)
Insert your install cd and run the program
Restart your pc
When Windows has settled , connect scanner back to pc .
It should run normaly .
Best regards.
Aug 15, 2014 | Canon CanoScan LiDe110
How to Fix Nissan Elgrand sunroof stuck with lock light on?
press the lock button 4 times quickly after you turn the ignition on. it will go into a beeping mode where you can now move the sunroof in small stages with the switches. set it to the normal closed position and now hold both switches in the back position for a second (or perhaps click the lock button 4 times again)
Aug 05, 2014 | Nissan Elgrand E50 Genuine Grill
1992 geo prizm trunk lock will not lock
The lever arm behind the bodywork that is operated by turning the lock has either rusted and broke or the spring has rusted and fell off
Dec 20, 2013 | Cars & Trucks
My steering wheel keeps getting stuck
Modern vehicles are fitted with a steering lock which is an anti-theft device. It is fitted to the steering column usually below the steering wheel. The lock is combined with the ignition switch and engaged and disengaged either by a mechanical ignition key or electronically from the vehicles electronic control unit. --------------------------------------------------------------------------------
NEXIQ 125032 USB Link Plus
Jan 17, 2013 | 2003 Nissan Altima
Disengaging shift lock
If you mean the gear shirt is stuck and you want to use the shift lock, then beside your gear shift there will be a spot that says disengage shift lock, pry open the cover and usually you can disengage it with a screwdriver sometimes when you pop the cover there is a switch that you can push to disengage shift lock hope this helps you
Jan 05, 2011 | 2002 Hyundai Accent
Kenmore oven locked
Hello dktshopping,
I know you probable don't want to hear this but in you circumstance, I think you would be better off to contact a repair professional. Those oven door locks are meant to keep the door from opening during the oven's self-cleaning cycle. They are both mechanically and temperature controlled so that the door can not be opened when the oven is 950 degrees. It sounds to me as though something is not releasing to allowing the locking mechanisim to disengage from the door even though the lever is in the unlock position. The unit will probably have to be taken apaprt to remedy the problem. Good luck.
Nov 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Lock won't disengage
Try putting it into CLEAN MODE and wait about 3 minutes.... then cancel the clean mode. Sometimes this will release the relay if its stuck.
If that doesn't work, you have a problem with the latch relay and you need service on the unit. You can try and remove the latch assembly yourself, but it can be tricky, and you may create more problems than you fix.
Jul 19, 2008 | Ovens
PHILIPS DVP721 COMBO
You have pressed C.LOCK (child lock) which turns off the control buttons on the front of the unit Press C.LOCK again to switch off the child lock. OFF will appear in the display window. See: http://www.p4c.philips.com/files/d/dvp721vr_05/dvp721vr_05_dfu_eng.pdf
Mar 05, 2007 | Philips DVP721VR DVD Player/VCR
RCA Lyra RD1072 MP3 Player Logo
32 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
