Question about Zyxel (91-004-361002) Wireless Router
Hi, i could not get a dsl connection on my router so i reset it. Now i cannot get a wireless signal from it. What should i do?
  • 340 Answers
Sounds like you need to renew your ip address. To do that you would need to go to start and run, in the run box type cmd, you will have a black box pop up with white lettering. It will say something like C:\user... type the following - ipconfig /release it will go thru a series of numbers and such and take you back to the C:\ type in there ipconfig /renew this will refresh your ip address and you should be able to access the internet again.
Posted on Oct 08, 2010
Signals Internet Wireless Loss No Signal Long time. It have Disputable again But Signals via Lan Cable Very Good.
Hi Good Day,
if your able to connect via LAN CABLE without any problem it means that the wireless capability of your router is already busted or broken.
if this router was provide by your internet provider then you can call them and request for a replacement.
Apr 09, 2011 | 3Com OfficeConnect Wireless 11g Cable/DSL...
I don't have internet access and seem to have lost my connection to my Linksys Wireless-G. What do I do?
check your wireless router if it is turned on.
see if it is getting a signal from your cable or dsl connection.
you can also connect via cat 5 from your laptop and see if your getting a IP on the WAN.
reset your cable/dsl modem if your not getting any signal or IP address.
Mar 20, 2011 | Linksys Wireless-G Broadband Router
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
The DSL light is green but blinking and the Internet light is not even coming on. All computers in house get the wireless signal and says the internet is working, but we don't have internet access.
Welcome to FixYa! What you are experiencing right now is what they called NO SYNC in ISP term. That means that your router is not getting any signal from the server. Please try to follow these method for you to be able to fix the problem.
1. Turn Off the router.
2. Check the DSL cable, the one that is connected from the router to the wall outlet.
3. Check if there's any device between them and remove it.
4. Try to switch the end of the cable.
3. Try to use another cable if possible.
5. Power on the router and wait until the DSL light goes steady.
6. If nothing happens, try to reset the router by pushing the reset button at the back of it.
7. Press and hold it for 30 seconds while the router is on.
8. Turn off the router and after 30 seconds, turn it back on.
If the DSL light is still blinking, there's a possibility that the problem is with the router itself or the line outside your house going to the server itself.
Hope this information will help. Thank you for using Fixya!
Jan 04, 2011 | Actiontec GT704WG Wireless Router...
Dsl wont pass thru router wired or wireless I have reset the router several times, the computer shows connected ,signal strenght excellent, but will not connect to the internet wired or wireless as long as...
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 28, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Constantly locks up and loses connection under moderate traffic(3 users max) never recovers only solution available is to reset
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 18, 2009 | D-Link DSL 500 (DSL-500) Router
2wire att dsl modem/router on vista
Connect your DSL to wireless router and enable automatic ip on wireless. check whether DHCP is enable in DSL router or not.
Apr 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Security password
It is not possible to break the password of WiFii.
Contact with the service provider and get the wireless DSL authentication password .
Enjoy .....WiFi DSL
Awais Shahid
Dec 20, 2008 | 3Com OfficeConnect Wireless Router
Problem with belkin router
assuming you are connecting wirelessly; you may have to check that the router is allocating ip addresses automatically to your pc's. connect one of your pc's to the router via the RJ45 network cable that was supplied and not wirelessly and type 192.168.2.1 in your internet browser, this will take you into the routers setup menu. Look for a menu refering to 'DHCP' and make sure that this is enabled, then look for the channel number that the router is using (normally 6 or 11) and make a note as if you are still experiencing signal loss, you can get back into the router and change to any channel between these numbers incase you are getting appliances interfering with the signal, save and exit from the router menu. disconnect the cable then go to control panel, network connections and right click on the connection you are using whether it is wired or wireles and click on properties. Look for the line TCP/IP and again click on the line and select properties, then make sure automatically obtain ip address is selected, ok and close window. Restart the pc's and you should have a connection.
Jul 08, 2007 | Belkin (F6D3230-4) Router (F6D32304)
Zyxel (91-004-361002) Wireless Router Logo
77 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
