Question about Linksys BEFW11S4 Wireless-B Broadband Router (12503024)
One computer not able to access internet
Receiving error "connecting to access point but internet cannot be found"
  • 48 Answers
You got to make sure the wireless settings of the wireless adapter is the same with the router. usually this problem happens if the wireless encryption or password you used in the computer is not the same wireless password in the router.
Posted on May 29, 2008
Cannot change transmission rate of Linksys WRT160N
1.With an online-capable game inserted into your Nintendo DS, turn on your system and access the game's main menu.
2.Access the Nintendo Wi-Fi Connection settings.
-These settings are typically found by selecting "Nintendo WFC" from the game's main menu. For detailed directions, consult the manual for the game.
3.At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
entryscreen3-cwz5mha2srvvin44vycqgk0s-3-2.jpg 4.Tap a connection file labeled "None."
emptyconnections4-cwz5mha2srvvin44vycqgk0s-3-5.jpg -If no empty connection files are available, select "Erase Settings" followed by "OK" to create an empty connection file.
5.Tap on "Search for an Access Point."
connection1settings-cwz5mha2srvvin44vycqgk0s-3-9.jpg 6.The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
oIf you receive the error message "No Compatible Access Points Within Range," click here.
7.Tap on the name of your wireless router or access point.
oIf there is a gray padlock next to the name of the wireless access point you wish to connect with, this indicates your router is using a security type incompatible with the Nintendo DS.
If prompted, use the keyboard on the bottom screen to enter the password for your wireless router or access point.
enter_wep1-cwz5mha2srvvin44vycqgk0s-3-14.png 8.Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test.
9.The connection test was successful - Your Nintendo DS is now connected online.
Situation Not Resolved:
If the connection test was not successful, you will receive an error code:
·Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
Apr 21, 2017 | Linksys WRT160N Wireless Router
Cisco access point
How to configure wireless access point using a laptop
Wireless technology makes connecting to the Internet possible from anywhere within the range of the network. Unfortunately, not all Internet-capable devices have wireless technology, and many still require an Ethernet port connection. If you have a laptop with a wireless card and an Internet connection, you can make the laptop a wireless access point and share that connection with other devices, whether your laptop runs a Windows or OSX operating system. Windows computers allow other devices to access the wireless network via a physical connection to the laptop, while OSX computers allow AirPort equipped devices to connect as well, creating a second wireless bubble for the network.
Instruction:
WINDOWS
1 Turn on the laptop and the device with which you will share the connection. Ensure the laptop's wireless card is turned on and you have an Internet connection.
2 Connect an Ethernet cord to the port on the laptop, and the other end to the receiving device. You need to make the connection first, or you will not be able to access the sharing options for the connection.
3 Open the list of network connections on the computer. In Windows 7 and Vista, access this list by typing "Network Connections" into the Start menu search bar and pressing "Enter." In Windows XP, click on "Network Connections" in the Network and Sharing Center section of the Control Panel.
4 Right click on the wireless connection and select "Properties," then navigate to the Sharing tab. This tab will not appear unless both devices are connected.
5 Check the box marked "Allow other network users to connect through this computer's Internet connection." Click "OK" to save the changes.
OSX
1 Click on the Apple menu and select "System Preferences." Click the "Sharing" option, then choose "Internet Sharing."
2 Select the Airport and wireless network in the "Share your connection from:" drop-down menu.
Select an output format for the connection in the "To computers using:" drop-down menu. Choose "Ethernet" for a physical connection or "AirPort" for wireless broadcasting.
Turn on the device you wish to receive the connection. Connect the devices with an Ethernet cable, or turn on the receiving device's AirPort card and connect wirelessly.
Dec 12, 2011 | Computers & Internet
I cant access facebook, INTERNET displays that 'web page cannot be displayed'
There are many reasons that Internet Explorer could be encountering this issue. Some examples are connectivity to your ISP, a firewall blocking your connection, or your networking device not functioning properly. Here are some things that you can try:
Method 1: Run the Network Diagnostics tool in Internet Explorer
1. Start Internet Explorer, and then try to access the Web page that is displaying the error message.
2. On the page that displays an Internet Explorer error message, click the Diagnose Connection Problems link. The Network Diagnostics tool will run. When the tool has finished running, it will report one of the following results:
    • It was unable to find a problem.
    • It has detected a problem. Additionally, the tool will provide guidance about the next steps to take to troubleshoot the problem.
3. Click IP Address, and note the IP Address. You may need it for future troubleshooting.
4. Follow the steps in the Network Diagnostics tool to fix any connection problems.
5. Start Internet Explorer.
If you receive the same error message, go to the next method.
Method 2: Reset the modem or the router
1. Disconnect the cable that connects the computer to the modem.
2. Turn off the modem and the router.
Note: If the modem or the router does not have a power switch, disconnect the power to the modem or to the router.
3. Restart the computer.
4. After your computer has restarted, turn on the modem or the router, connect the cable from the computer to the modem or the router, and restart the computer.
5. Make sure that all network cables are securely connected.
6. Start Internet Explorer.
Method 3: Use the Delete Browsing History feature
If resetting the modem or the router did not resolve the problem, deleting your browsing history might help. Follow these steps to remove your temporary Internet files, history, and form data:
1. Start Internet Explorer.
2. Click the Safety button, and then click Delete Browsing History.
3. Select the check box next to each category of information you want to delete.
4. Select the Preserve Favorites website data check box if you do not want to delete the cookies and files associated with websites in your Favorites list.
5. Click Delete. (This could take awhile if you have a lot of files and history.)
6. Close Internet Explorer, start Internet Explorer again, and then try to access the Web page.
Method 4: Use the Internet Explorer (No Add-ons) mode
1. To do this, click Start, point to All Programs, point to Accessories, point to System Tools, and then click Internet Explorer (No Add-ons).
If this resolves the issue, follow these steps to isolate the browser add-on that is causing the issue:
  1. Click Tools, and then click Internet Options.
  2. Click the Programs tab, and then click Manage add-ons.
  3. Click an add-on in the Name list, and then click Disable.
  4. Repeat step 3 until you identify the add-on that is causing the issue.
Oct 13, 2011 | Facebook Computers & Internet
WEBPAGE DOWNLOAD
Aug 09, 2011 | Microsoft Internet Explorer 8
Everytime I try to connect to the internet it wont let me I wanna watch net flix
Sorry to hear your having problems with your wii. You can connect the wii via wifi or wired with an adapter. Check out Nintendo's tutorial for instructions on how to do this:
http://us.wii.com/connect/
You basically goto:
Wii Options at the bottom left corner of your home screen, then Wii Settings, Click the right arrow to goto the next page, Click Internet, Click Connection Settings, Click Connection 1, Click Wireless Connection. Click Search for an Access Point. Click OK to view the found access points. Select the Access point for your wireless internet, enter your encryption key, click Ok and then OK again to save settings, and then OK again to test the connection.
If you have done all these setups make sure your selected network and encryption key are correct. If you have an error code search on that error code online.
Apr 29, 2011 | Nintendo Wii Console
Internet connection says not connected
You basically goto:
Hi,my dsi i set the internet is work yesteday now is no work is sho unable to obtain an IP address. check your access point settings.Error code:052010-1.Ples hel mi.
Hi
Please check whether the below point will be helpful.
  • The DHCP settings of the access point and DS dont appear to be compatible.
  • Please check the DHCP settings of your router and try again.
  • If you have multiple connection files saved to your DS the error message you received can help determine which connection file may be experiencing a problem you error code says problem with connection file 2 .Please check
Feb 28, 2011 | Computers & Internet
Im receiving limited connection
Limited or no connectivity can be due to more then having a weak signal. And I assume you've sat your computer right next to your access point with no solution?
Try connecting your computer to your access point/modem with an ethernet cable and checking the configuration settings by going into an Internet browser and typing in the IP address of the access point, and then the credentials when/if prompted
Apr 16, 2010 | Actiontec GT704WG Wireless Router...
Trying to connect to wifi usb connector and keep getting error code 52203
I'm assuming you are talking about the nintendo DS. Here is the info on that error code straight from nintendo:
Error Code: 52203
The Access Point you are attempting to connect from is not connected to the internet or a firewall is blocking traffic necessary for connecting to Nintendo Wi-Fi Connection. What to do will depend on where you are trying to connect from: What to do:
    If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
    • Errors ending in 0 = connection file 1
    • Errors ending in 1 = connection file 2
    • Errors ending in 2 = connection file 3
    • Errors ending in 3 = Nintendo Wi-Fi USB Connector
  • Verify that your router is connected to the internet when attempting to connect to the Nintendo Wi-Fi Connection. If you are not able to access the internet on your computer, then there is a problem with your internet connection. Contact your Internet Service Provider (ISP) for more information.
  • America Online (AOL) broadband users may experience difficulties when attempting to connect to the Nintendo Wi-Fi Connection. Please contact America Online for assistance.
  • If this error occurs regularly, while you are playing at home, it is likely a connection problem related to your firewall settings. For more information on firewalls and the Nintendo WFC, click here.
If the above information does not work, and you are using the Nintendo Wi-Fi USB Connector, click here for additional assistance.
If the above information does not work, and you are connecting at home with a wireless router, there could be settings on your router that need to be adjusted. Please click here for more information.
Connecting from a non-partnered Hotspot:
  • The access point at the Hotspot may not be experiencing problems. Ask the staff on site if their Wi-Fi network is up and running.
  • If the Hotspot's access point has a built-in firewall or other security that interferes with the necessary transmissions from the Nintendo DS, then the access point will not be compatible with the Nintendo DS.
  • Try another Hotspot. To search for known Hotspots in your area, click here.
Jul 16, 2008 | Nintendo Video Game Consoles & Games
WIFI does not work: internal error 00000001
dont worry its no problen sony did not encode the higher versions it should say no network found but but it is the same thing so dont worry
Oct 05, 2007 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
103 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
