Question about Galaxy Radios DX-44V 40-Channels Base CB Radio
I need to know what each knob and switch on front of radio should be set at. i know about the squelch setting and mic gain (at least i think I do) but not sure about all the other settings for your standard set up for this radio thanks laydgator
    Guru:
  • 773 Answers
To use this radio on the CB band, you set the 10 Khz switch to OFF, and then turn the band switch to A/E.
Here is a Frequency Chart.
When the 10 Khz switch is on OFF, the band switch is E,F,G,H. When the 10 Khz switch is in the ON position, then the band switch is A,B,C,D.
So when you are on band E, which is when the 10 Khz is OFF, and the band switch is in the first position, it is on the E band.
I would get your self a Frequency counter. It makes using a radio like that much easier.
Hope this helps!
Posted on Oct 12, 2010
Why don't I have sound on uniden pc78ltw?
the knob that turns the radio on and off is the volume potentiaometer.turn it 1/2 wayopen.the next knob is the squelch maqke sure it is all the to the left.the next knob is the mic gain and the RF gain.Set the mic gain at 1/2 and the RF gain all the to the right.the next knob is the delta tune,set it 1/2 way the next knob is the calibration knob leave it alone.Now above those knobs are little switches .the third switch from the left is for CB/PA make sure its on CB. check the WX switch and make sure it not on a weather station. and finally the last switch to the right is called a dynamic squelch switch.Make sure it is down. with all said your radio should be on and you should be able to hear sound. If not ,take an external speaker and hook it to the external speaker plug in the back of the radio.If you hear something then you internal speaker is junk.replace it .
Sep 04, 2014 | Radio Communications
Receiving volume is very low, I have to turn the volume up all the way to hear anything (squelch is very low when I turned knob to readjust settings) when before I didn't even need to turn it up halfway to...
was the radio wired direct or with a cigarette lighter plug? try the RF gain knob and the mic gain knob.If they are wide open does the radio rec.any better? if not you may have a problem with the main IC
Jan 04, 2014 | Cobra 29 LTD CB Radio
Where to set rf power on connex 4300 hp
start off at about 1/2 way then adjust to your choosing. Don't forget about the mic gain . Set it the same way . squelch wide open then turn back till it just cracks . should be good.
Mar 30, 2012 | Cobra Radio Communications
My cobra 29 ltd is in a ford truck with a over head camper. i put a magnet mounted wilson 1000 watt ant (4ft.) on top of the cab. I cannot get any squelch to work I did a radio check i believe i was heard...
Assuming you don't have the manual,basic controls for receive are to make sure the switch next to the meter is set to s/rf,switch for cb/pa is set cb,knob for rf gain is at max, squelch knob is fully counterclockwise..squelch can be adjusted if ya don't want to hear static but will start cutting out weaker signals.If none of the above works,try plugging in an external speaker to the jack on the back of the radio,if ya still don't hear anything,check that antenna coax is screwed in tightly in back of the radio.Next step after all that would be the microphone,is the stock mic,power mic..if it is the original stock mic that has not been rewired in any,then I would suggest taking radio to qualified cb repair shop,bring mic with you to shop so they can check it too,in fact I would bring the truck also so they can check antenna and adjust it if needed...Good luck
Sep 04, 2011 | Cobra 29 LTD CB Radio
Looking to buy connex4300hp for 150.00.think its a good deal but dont know that much about it.gonna run 18ft coax to wilson 2000 w/astatic 636L.how do i set-up for best performance?=bands,knobs on...
A new unit goes for $280 range
then conversion to run cb freqency $30.
Tune-up $50 you should get 70 watts older units 90 watts newer units
As far as the knobs go
Band D with channel 19 selected this is 27.185 citizen band if you radio has had the channel expansion done other wise it is not accessible.
Select AM
10 khz switch should be off
mic gain know depends on the tuning of your radio and mic choice.
rf gain full clockwise best reception you will just have to play with this knob and the squelch to your liking
Make sure the thing is working properly before you buy capacitors dry out and the connex radios are know for problems with their pcboards. good luck
Aug 29, 2011 | Connex CX-4300HP CB Radio
Cb has power but no squelch,can't recieve or transmit
Begin with
  • Volume knob 12 o'clock position
  • Squelch knob full counter clockwise
  • RF gain knob full clockwise
  • Pa/CB switch to CB
  • Mic plugged in
  • Check coax and antenna connections.
  • Make sure your antenna gommet/insulator is installed correctly or it will directed gound. Treat antenna shaft as it is the positive portion of circuit.
If you have another CB check the antenna system with that rig. To verify it is a radio issue. Then dig deeper Microphone, PLL chip, Audio chip etc.
Jan 11, 2011 | Cobra 29 LTD CB Radio
I am a new Truck Driver and I had given to me a good used Cobra 29 LTD CLASSIC CB radio for my Truck. It is missing the owners manual. Can you please tell me what I need to know about the settings on the...
I have the same radio as well. If you are running a "stock factory mic".....do this:
VOLUME: set to your comfort
SQUELCH:all the way to the left (if you don't mind hearing everything other wise adjust to the right to illiminate noise)
DYNAMIKE:If you have a factory mic or "noise canceling mic", turn all the way to the right (unless it squeals and then turn the mic gain down slowly until the squealing stops)
RF GAIN:that is your "receive" and I always turn it all the way to the right to maximize reception! In my opinion, this is the dumbest knob ever made since why not hear as good as you can??? thats what the SQUELCH is for!
DELTA TUNE: IT IS "USELESS!!!
SWR CALIBRATE: don't ever trust it! ALWAYS USE A GOOD SWR METER "IN LINE"
Now as for the "SWITCHES"
The top left switch is the SWR and as I stated, do NOT trust it and leave it on "S/RF (TOP)
SWITCH TWO: If you have it on OFF, you may get allot of engine spark plug firing noise so I run mine in the "middle" (ANL)
THIRD SWITCH: CB
FOURTH SWITCH: Brightness is to your liking!
There ya go! You can always set the switches to your liking and comfort.
"WILDCAT" IN LAURELVILLE OHIO
Dec 24, 2010 | Cobra 29 LTD CB Radio
My radio recieves ok but only whistles when i key the mike is this a major fix?
Do you have talkback installed? It my be too loud and causing feed back. Back the mic gain down if so.
Could also be improper mic wiring. If you use a mic that is wired for a different radio, it could just cause a hum, buzz or squeal.
Another thing that can cause a hum, buzz or squeal is a faulty volume and or squelch knob depending on the radio.
  • Turn down or disable talk back.
  • If you cannot turn off or disable talk back, lower mic gain.
  • Try a different mic that you know is wired for cobra.
  • Play with volume and squelch knobs while TX and see if it stops at all. If it does replace knob.
Oct 12, 2010 | Cobra 150 GTL DX Base CB Radio
This is something new to me, what do I set all the buttons and knobs to talk on channel 19,hi-lo band,10khz on or off ,pa-fm-am,e/a-f/b-g/c-h/d, e-tone thanks for any help anyone can give me.
Radio On Volume comfortable Listening level Squelch Open (Hearing Noise) Mic Gain Up unless told by receiving station to reduce it. 10 Khz Off pa-fm-am set to Am e-Tone to off I believe this model has CB on Band C which is switch down on Low and C position you will know when you hear truckers on 19 which band is CB
Aug 06, 2010 | Galaxy Radios DX-44V 40-Channels Base CB...
I dont know were the adjustment nobs should be i just got this radio and dont know that much about the galaxy 959
There are little red dots on the edge of each knob. As a starting point, try these knob positions (starting from the knob on the left)..
Adjust volume as desired.
Adjust squelch all the way counterclockwise (no squelch).
Adjust mic gain so the red dot is at the 12 o'clock position.
Adjust light dimmer as desired.
Adjust RF Power with the red dot at the 12 o'clock position.
Ignore talkback and clarifier for now.
Now for the 5 little slide switches...
Set all of them to the middle position.
Now you should be able to operate transmit and receive.
This is a very good radio, but there are so many adjustment knobs that you can reduce its performance if you just blindly turn knobs.
After you learn how the radio sounds and works with these average settings, play with each knob, adjusting a little and see what it does for your particular antenna setup. Do some "radio checks" with other CBers and find out what your best settings are. Also read the owners manual for guidance on what each knob does...especially mic gain (too low and you won't be heard, too high and you'll be garbled) and RF Power (to little and you won't reach out very far, too much and you'll overload local listeners). This is definitely not a beginners radio. But it is a lot of fun and will enable you to learn a lot.
Jul 10, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy Radios DX-44V 40-Channels Base CB Radio Logo
372 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
