Question about Grohe Plumbing
Grohe kitchen faucet #33 853 leaks at base when turned on. A new cartridge has been installed and it still leaks
4 Suggested Answers
  • 68 Answers
SOURCE: I have a Grohe Europlus Kitchen faucet. The base
there is a couple of plates with a little screw in the center that tightens up the plate got to tighten it up
Posted on Jun 27, 2009
  • 349 Answers
SOURCE: I am looking for a U clip to connect my Grohe
http://www.guillens.com/index.jsp?prevurl=keysearch&path=find&a=1&process=search&category=products&f=Grohe&text=clip
Check this web site out for parts for your faucet. above is clips listed. The link below has more information on the faucet you have.
http://www.guillens.com/Grohe/groptrs30-34.htm
Posted on Jun 06, 2010
Testimonial: "I found just what I was looking for! Thank you for your help."
  • 1015 Answers
SOURCE: my Grohe kitchen faucet leaks in the "Cold" off
I would remove and clean cartridge and replace spout o-rings. Lube o-rings and grooves they set in with heat pruf faucet grease. Wipe off excess grease and reinstall spout. I would also check to make sure you have a good seal between faucet base and sink surface. Look for signs of leaks from around base and remove faucet and put good seal in using plumbers putty. After you secure faucet back to sink top scrape off excess putty and wipe with paper towels till clean. Hope this helps you. Thanks
Posted on Nov 30, 2010
Grohe warranty
GROHE - Warranties - Services for you
https://pro.grohe.com/us/5685/services-for-you/warranties/
  1. Cached
Residential Products: We provide the following warranties on all GROHE products to the original purchaser, installed in a residential setting. This warranty is effective for all faucets sold after January 1, 1997. Mechanical Warranty: A Limited Lifetime Warranty is provided on all mechanical parts to be free from manufacturing ...
Warranty - Grohe
https://www.grohe.ca/en_ca/our-service/warranty/
  1. Cached
We provide the following warranties on all GROHE products to the original purchaser, installed in a residential setting. This warranty is effective for all faucets sold after January 1, 1997. Mechanical Warranty: A Limited Lifetime Warranty is provided on all mechanical parts to be free from manufacturing defects in materials ...
Luxury Bathroom Taps, Shower Heads & Kitchen Mixer Taps ' GROHE
  1. Cached
  2. Similar
GROHE - Luxury fittings for exceptional bathrooms and kitchens. Our range of bathroom taps, showers, shower heads and kitchen mixer taps includes designs to suit all interior styles and budgets.
GROHE Faucets Warranty - eFaucets.com
https://www.efaucets.com/grohe-faucets-warranty.asp
  1. Cached
Limited Lifetime Warranty (U.S.A. Only). Residential Products: GROHE provides the following warranties on its products to the original purchaser, installed in a residential application. This warranty is effective for all faucets sold after January 1, 1997.
calling grohe faucet owners..lifetime warranty? - Houzz
https://www.houzz.com/discussions/.../calling-grohe-faucet-ownerslifetime-warranty
  1. Cached
  2. Similar
Nov 11, 2010 - My parents put in a grohe faucet 25 years ago that has been leaking for the better part of the past 15 years. I JUST noticed the name on the faucet as I was sitting at the counter last night and thought, "hey, I bet this expensive faucet has a lifetime warranty" Can anyone share their expe...
Dec 12, 2017 | Grohe Home
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Loose grohe kitchen faucet Handle
    Probably the cartridge is failing.
    Nov 04, 2013 | Home
    My grohe faucet leaks when turned on from around the base of the device where it goes through the counter top. Wiggling the spiggot makes it leak worse. It is 4 years old The cartridge looks clean. It is...
    There are two O rings in the spout body that need to be replace with new and lube the
    new O rings with vaseline. If your water is too hot, this will dry out the O rings. Normally
    your hot water shouldn't be more than 120 degrees F. You can check this by holding a
    thermometer in the stream of water with the hot on only.
    Grohe has a lifetime warranty on them. I have taken many Grohe's back to the wholesaler
    and they just give me a new one, no questions asked.
    Nov 02, 2010 | Grohe Plumbing
    Grohe ladylux plus is leaking
    I believe there is a cartrige that has some washers in the unit. There may be some debris caught in there since it was a little loose. I would turn the water off and disassymble the unit and replace any obvious washers and clean everthing up. Replace it all and try it again. If it still leaks, contact Grohe for more trouble shooting. Faucets have fantastic warranties and companies usually will send replacement parts free of charge at times. Hope this helps.
    Apr 06, 2009 | Grohe Model 28 206 OOO: Ladylux Plus...
    Plumbing Logo
    119 people viewed this question
    Top Grohe Plumbing Experts
    john h
    Craig Butler
    Craig Butler
    Mike
    Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
