Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My craftsman lawn tractor quit while cutting heavy grass. wouldn't restart..........pushed it to the garage............ took off deck......... still woundn't start replaced battery ......... still will not turnover I can hear the solinoid click........but no turn over repaced the 15amp fuse .......no start ????????????????????????????? what next?
  • 110 Answers
Try using jumper cables and jumping from the positive battery post to the starter lug where the main cable hooks to the starter. If you don't have jumper cables find the solenoid on the inside of the right side panel. Pull the rubber caps off and jump that with an old screw driver if the engine turns and starts on either occasion it is the solenoid. Part # 192507 sells for about $15.00 at searspartsdirect.com
Posted on Oct 25, 2010
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John deere x475 mower will not engage after cutting heavy grass
It is probably full of grass in the mower deck. Clean it out and try again.
Sep 25, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need a troubleshooting manual for a craftsman mod. 917.287070
Went out to cut grass and the blades will not engage and when I put it in gear it does not move. Belts are intact. I cleaned the deck of dirt and grass. Still nothing. Just replaced the cable to engage the blades last year. Cable seems to be working.
Jun 25, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Tractor want move
safety on the seat if the blades were still lowered it will shut down the motor. have to disengage the pto.
Jul 19, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
46" craftsman lawn tractor shuts off when engaging
check the wire from your clutch to were it plugs in. should be on your right side. some have a yellow cover. make sure the wire is not broken. check under your deck and make sure you don't have a large grass build up
Oct 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Uneven grass cutting
I have seen dull blades, blades not installed right and an un-level deck cause that.
Hope this helps.
Sep 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have 12.5 hp craftsman with brigss and stratton engine was cutting grass loud engine knock started and cut off when trying to restart it will just knock did a rod throw
Yes it sounds like the rod broke but to be sure remove the spark plug and push a straw or something flexible about 2 inches into the cylinder and then turn the engine over by hand to see of the piston is moving.
Jul 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
158 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
